Non-linearity on analog inputs (UNO R3)
Config : UNO R3 + a 10k potentiometer connected to UN0 pins (+5V, GND), and cursor to pin A03.
Program is the one we find in all tutorials (analog read).
The problem is the following :
  • cursor set in the middle of its range. If not connected I have 2.5V, this is ok
  • if I connect cursor to A03, then I have only 0.1V or less, whereas I should have 2.5V and a value around 500.
  • if I connect curost to min, I get a value 0. If I connect cursor to max I get a value of 1023. This is ok.
  • the problem is I can not get values above 500, the value drops immediately from 1000 to 120, typically.
  • it's the same situation with a 100k potentiometer.
Is it a problem with the impedance of A03 input ? what is its value ? (I've not found it in documentation)
The voltages are measured with a multimeter?
The Arduino inputs are very-high impedance so the voltage on the potentiometer's wiper shouldn't change when connected to an Arduino input. (Assuming the Arduino is powered-up.)
If everything is wired correctly and the voltage changes when connected, your Arduino may be damaged.
Have you tried a different analog input?
What is a cursor in this context?
Normally a cursor is a mark on a display where writing is about to appear, but this is a point, not something you can attach to a pin.
ooops, you're right: I changed from A03 to A04 input and now it works :when the cursor is in the middle position I can read a value of ~500 and voltmeter shows ~2.5V (I do the measures with a voltmeter)
Are analog inputs so fragile ? whaouh ...
Pfff .. I should not say that I'm an engineer ... ok ,we learn every day ...
Thank you guys !
what I call cursor is the middle position of the potentiometer (sorry, I'm french ...)
Thanks for the translation.
This implies that the A3 input pin is damaged, or somehow set to be an output with a logic zero on it.
Have you tried another pin for this extra input?
It could be damaged by over-voltage or static discharge (which is also excess voltage). But in most cases when a chip gets damaged the whole chip gets killed.
In my experience a pin can easily become damaged leaving the rest of the chip still working.
