Non specific baud rate, and 9 bit UART
Hi!
(sorry for my english)
I would like to build a serial ethernet converter with arduino mega boards. The problem is, the serial communication operating on a non standard baud rate and data bit length. (571430bit/s, 9bit, no parity, 1 stop bit)
(This is a sony camera controller btw)
I tried to set the baud rate, but arduino still working on the closest (500.000bit/s) speed.
There is a way to set arduino on a specific baud rate? Or there is any additional controller, that could help on my problem?
Thanks! :slight_smile:
Can you give a link to that sony camera controller ?
Can you give a source for the 571430 baudrate for that controller ?
16 MHz / 28 = 571428.57
60 MHz / 105 = 571428.57
That is almost 571429 and not 571430.
That means any board that runs at 16 MHz or 60 MHz or multitude of that can make that baudrate (depending on a fixed prescaler). There are many Arduino boards, ESP boards and Teensy boards that run at those frequencies.
Wormfood calculator: http://ruemohr.org/~ircjunk/avr/baudcalc/avrbaudcalc-1.0.8.php
The Arduino Uno or Mega with 16 MHz turns red, so that is not possible. It would need a crystal of 18.2858 MHz, that is not a standard value.
The hardware can read 9 bits.
What is the 9th bit for ? What does it do ? Is it some kind of parity ?
Computer memory can store 8 bits, not 9 bits.
The 9th bit is the "start bit" for the sequence.
Paul
Assuming you are using an Atmega328P Arduino, the formula for generating the baud rate from a given CPU clock is given in the datasheet
So for a 16 MHz Arduino, changing the UBRR register to 1749 would give you the 571.43 bps
The Atmega328 also supports 9 bit data
We need to know if the dot in "571.430" is a separator or a decimal. We also need to know if that is really the baudrate.
An example of a Sony Camera Controller, the RM-IP500.
According to its Remote Camera System Guide the baudrate is either 9600 or 38400. That makes sense.
There is another camera controller with the same 9600 or 38400.
Koepel:
Any professional sony broadcast camera and RCP communicate at this baud. The protocol is not documented on the internet, I calculated it with a logic analyzer.
Thank you, this page is very useful. As I see, the 18.432Mhz would work. If I understand correctly, an atmega328P (which could run even on 20Mhz) with an 18.432Mhz crystal would work with this baud rate. Am I correct?
The 9th bit is an adress bit, not a parity bit.
Koepel:
Sorry! It's 571430 bit/s, so a little more than half Mb/s. And yes, it is completley sure. I measured it with a logic analyzer too.
It seems that crystals with that frequency actually exist :o
You can also buy a Arduino (or compatible) board with a higher frequency. Almost every board is a multitude of 16 or 60 MHz.
Is that with 5V levels or 3.3V levels ?
Can you show us a screendump of the logic analyzer ?
The hardware of the ATmega328P can deal with 9th bits, but the Arduino Serial library can not. You have to write your own code. The ATmega328P has a hardware buffer of 1 byte. Your code will have trouble keeping up with that high baudrate. A faster board makes it easier.
But I don't know which board can also do 9-bits and can do that baudrate.
Koepel:
It's a 5V signal. The communication between the two device is on RS422 protocol, but I converted it with a max490e ic.
Here is the screendump :slight_smile:
Thank you.
The ESP32 should be able to set that baudrate, but it has only 5, 6, 7 or 8 databits: UART — ESP-IDF Programming Guide v3.1.7-73-g2060ee9a5 documentation.
The Arduino Zero and MKR boards have a SAMD21G processor. It can work with 9 bits. It is even defined in the low level SERCOM.h. I don't know if the baudrate is possible. It seems that the full 48MHz is used for the baudrate generator, then it is no problem.
The Arduino MKR is a 3.3V board, you would have to change the voltage level.
Why not try both ? The Arduino with the special crystal and a MKR board with SAMD21G processor.
P.S.: You don't have to quote my whole message. What I wrote is already there :wink:
