Noob C questions
Hello and thanks fof looking in advance.
I am not sure if i have found a bug or just an issue with my programming.
Code in question
#include <IRremote.h>
int RECV_PIN = 4;
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned long lastCode;
const int ledPin2 =  LED_BUILTIN;// the number of the LED pin
int ledState2 = LOW;
  irrecv.enableIRIn(); // Start the receiver
  pinMode(ledPin2, OUTPUT);
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    Serial.println(results.value, DEC);
//    lastCode = results.value;
      // BELOW IS REPEAT CODE ACTION
   if (results.value == 4294967295) {
      results.value = lastCode;}
          // ABOVE IS REPEAT CODE ACTION
   if (results.value == 550720173) {
    Serial.println("Small Power button press");
    lastCode = results.value;}
   if (results.value == 550726293) {
      Serial.println("Other button 9 press");
      if (ledState2 == LOW) {
        ledState2 = HIGH;
        ledState2 = LOW;
      digitalWrite(ledPin2, ledState2);
    irrecv.resume(); // Receive the next value
If i use the remote (NEC IR chip) destined for this code it works fine. The repeat code does what its suppose to however if i use a different remote that uses the NEC chip IR chip as well to control volume the 0xFFFFFFFF repeat code gets sent and the arduino responds even though it shouldn't.
Output from correct remote single press:
20D352AD
550720173
20D36A95
550726293
Output from correct remote multiple press:
20D352AD
550720173
20D36A95
550726293
20D36A95
550726293
FFFFFFFF
4294967295
FFFFFFFF
4294967295
Output from INCORRECT remote multiple press:
8C23D
574013
FFFFFFFF
4294967295
FFFFFFFF
4294967295
FFFFFFFF
4294967295
The last code that was triggered by the correct remote gets triggered again with the incorrect remote because they both use the same IR encoding chip that uses fffff for repeat.
how can i fix it?
I did come up with this idea whilst i was writing this.
How can i make my code repeat the loop ( if (results.value == 550720173) {
Serial.println("Small Power button press") ) x amount of time depending how long its pressed for. Then i could in theory remove the "Repeat code action."
Thanks again for looking at my post.
Don't you want to assign to lastCode every time you receive a new code, not just when it happens to match something?
int RECV_PIN = 4;
      //lastCode = results.value;
        ledState2 = HIGH;
        ledState2 = LOW;
      results.value = lastCode;   <———<<<<   very odd  ;-)
Learn about formatting your code with the key combination
blh64:
int RECV_PIN = 4;
       ledState2 = HIGH;
       ledState2 = LOW;
Yes thank you so much. It works as it should. ish
All though I don't understand how its now working as there is no reference to "lastCode" any more. I'm sure there is something very simple I have over looked. Maybe its referenced in "IRremote.h"
when I press the power button with your code it shows up twice in the serial console and the second instance is all ready printing FFFFFFFF
I just tried adding a delay with Millis with no success.
Here is new code:
int RECV_PIN = 4;
unsigned long startMillis;
const unsigned long period = 20000;
bool timerRunning = false;
  if ( timerRunning ) {
    if ( millis() - startMillis >= period ) {
      startMillis = millis();
      timerRunning = true;
        ledState2 = HIGH;
        ledState2 = LOW;
And output after button is pressed once. What is strange is it didn't do that before
20D352AD
550720173
FFFFFFFF
4294967295
larryd:
      results.value = lastCode;  <———<<<<  very odd  :wink:
Learn about formatting your code with the key combination <CTRL><T>
Ok I'm starting to see now why you would say that.
In my defence I am only using what I've self taught over the years looking at other ppls code.
No problem, it takes time.
@sparkie37
Your sketch in post #3 still has:
results.value = lastCode; // <------<<<< No
The sample code below demonstrates a few ideas that may be of interest to you.
Notice the repeat function is demonstrated also.
The NEC key pad may be different than yours, but you should be able to convert to your values for your keypad.
#include "IRremote.h"
//Sketch to demonstrate using an IR hand remote to control Arduino outputs.
//The remote used here uses the NEC protocol.
//This remote sends the button code (example 0xFF629D) then a repeat code 0xFFFFFFFF
//The repeat code is re-sent as long as an IR remote button is pressed.
//The IR receiver used is the TSOP4838
/*  17 IR button remote layout   http://i.imgur.com/X1KIdqI.png
< OK  >
   v
1  2  3
4  5  6
7  8  9
*  0  #
const byte RECV_PIN = 2;   //IR receive pin
IRrecv irrecv(RECV_PIN);   //create instance of 'IRrecv'
decode_results results;    //create instance of 'decode_results'
unsigned long   TimerUp;   //UP arrow on the remote
boolean         TimerUpFlag      = false;
unsigned long   TimerDown; //DOWN arrow on the remote
boolean         TimerDownFlag    = false;
unsigned long   TimerIntensity;
unsigned long   TimerIncDec;
boolean         intesityUpFlag   = false;
boolean         intesityDownFlag = false;
int             brightness;
unsigned long   dummy;
unsigned long * TimerPtr = &dummy; //pointer to the current timer
const byte upLED        = 13;  //turns on as long as the UP button is pressed
const byte downLED      = 12;  //turns on as long as the DOWN button is pressed
const byte leftLED      = 11;  //toggles on/off
const byte rightLED     = 10;  //toggles on/off
const byte intensityLED =  9;  //a LED which can have its intensity adjusted
//                           s e t u p ( )
  irrecv.enableIRIn(); //start receive
  pinMode(upLED, OUTPUT);
  pinMode(downLED, OUTPUT);
  pinMode(leftLED, OUTPUT);
  pinMode(rightLED, OUTPUT);
  pinMode(intensityLED, OUTPUT); //this is a PWM output pin
} //                    E N D  O F  s e t u p ( )
//                            l o o p ( )
  if (irrecv.decode(&results)) //is there IR remote button code
    //Serial.println(results.value);
    processButton(); //process button press
    irrecv.resume(); //restart for next button press
  //**********************                                //Turn off upLED
  //if timing is enabled, is it time to stop
  if (TimerUpFlag && millis() - TimerUp >= 250)
    TimerUpFlag = false; //disable timing
    TimerPtr = &dummy;   //pointer to dummy timer
    digitalWrite(upLED, LOW);
  //**********************                                //Turn off downLED
  if (TimerDownFlag && millis() - TimerDown >= 250)
    TimerDownFlag = false; //disable timing
    digitalWrite(downLED, LOW);
  //**********************                                //LED intensity
  //are we still within the adjustment time
  if (millis() - TimerIntensity <= 300)
    //is it time to increase/decrease the intensity
    if (millis() - TimerIncDec >= 200)
      TimerIncDec = millis();
      if (intesityUpFlag == true)        //Increase
        brightness += 5;
        if (brightness > 255)
          brightness = 255;
      else if (intesityDownFlag == true) //Decrease
        brightness -= 5;
        if (brightness < 0)
          brightness = 0;
      analogWrite(intensityLED, brightness);
      //Serial.println(brightness); //debug
  //stop increasing/decreasing intensity
  //Other non blocking code goes here
} //                   E N D  O F  l o o p ( )
//                       F U N C T I O N S
//                   p r o c e s s B u t t o n ( )
//process IR remote button presses
void processButton()
  switch (results.value)
    case 0xFF629D:                                           //UP Arrow
        Serial.println("UP");
        TimerPtr = &TimerUp;  //point to this timer
        TimerUpFlag = true;   //enable timing
        digitalWrite(upLED, HIGH);
        TimerUp = millis();
    case 0xFFA857:                                           //DOWN Arrow
        Serial.println("DOWN");
        TimerPtr = &TimerDown;  //point to this timer
        TimerDownFlag = true;   //enable timing
        digitalWrite(downLED, HIGH);
        TimerDown = millis();
    case 0xFF22DD:                                           //LEFT Arrow
        Serial.println("LEFT");
        digitalWrite(leftLED, !digitalRead(leftLED));       //Toggle LED
    case 0xFFC23D:                                           //RIGHT Arrow
        Serial.println("RIGHT");
        digitalWrite(rightLED, !digitalRead(rightLED));      //Toggle LED
    case 0xFF42BD:                                           // * button
        Serial.println("*");
        TimerPtr = &TimerIntensity;  //point to this timer
        intesityUpFlag = true;       //enable intensity up adjustment
        TimerIntensity = millis();
    case 0xFF52AD:                                           // # button
        Serial.println("#");
        intesityDownFlag = true;     //enable intensity down adjustment
    case 0xFF02FD:
      Serial.println("OK");
    case 0xFF6897:
      Serial.println("1");
    case 0xFF9867:
      Serial.println("2");
    case 0xFFB04F:
      Serial.println("3");
    case 0xFF30CF:
      Serial.println("4");
    case 0xFF18E7:
      Serial.println("5");
    case 0xFF7A85:
      Serial.println("6");
    case 0xFF10EF:
      Serial.println("7");
    case 0xFF38C7:
      Serial.println("8");
    case 0xFF5AA5:
      Serial.println("9");
    case 0xFF4AB5:
      Serial.println("0");
    case 0xFFFFFFFF: //Repeat code
        Serial.println("REPEAT");
        *TimerPtr = millis();       //reset the current timer
  } // END switch case
} //             E N D  o f  p r o c e s s B u t t o n ( )
//                        E N D  O F  C O D E
In this modified sketch from post #3, what is not working as you want?
//Version 1
int RECV_PIN = 4;                         //sparkie37 remote
//int RECV_PIN = 2;                       //LarryD Remote
    //if (results.value != 0xFFFFFFFF)
    if (lastCode == 0x20D352AD)      //550720173 = 0x20D352AD  "sparkie37 remote"
    //if (lastCode == 0xFF629D)      //LarryD Remote
    if (lastCode == 0x20D36A95)      //550726293 = 0x20D36A95  "sparkie37 remote"
    //if (lastCode == 0xFFA857)      //LarryD Remote
        ledState2 = HIGH;
        ledState2 = LOW;
    irrecv.resume();
  } //END of   if (irrecv.decode(&results))
} //END of loop()
larryd:
//Version 1
        ledState2 = HIGH;
        ledState2 = LOW;
    irrecv.resume();
} //END of loop()
It responds as if I pressed and held down the power button when in reality on have only pressed it once.
If you have some time, suggest you review the sample code in post #6 for some new techniques.
Tell us 'exactly' how you want things to work in your sketch.
//Version 2
int RECV_PIN = 4;
const unsigned long powerButton  = 0x20D352AD;
const unsigned long otherButton  = 0x20D36A95;
//int RECV_PIN = 2;
//const unsigned long powerButton = 0xFF629D;
//const unsigned long otherButton = 0xFFA857;
      case 0xFFFFFFFF:
      case powerButton:
      case otherButton:
          ledState2 = !ledState2;
    irrecv.resume();
} //END of loop()
