Not able to Upload my Code any more, help!
I have tried everting
I always get the same message.
Upload started
Programming with: Serial
Flashing with command:/Users/maxpenfold/.arduino-create/esp32/esptool_py/3.0.0/esptool --chip esp32 --port /dev/cu.usbserial-01E02E5A --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 /var/folders/dn/9dxfb1qx4mvglmsmq0c1n2l80000gn/T/extrafiles555273803/tools/partitions/boot_app0.bin 0x1000 /var/folders/dn/9dxfb1qx4mvglmsmq0c1n2l80000gn/T/extrafiles555273803/tools/sdk/bin/bootloader_dio_80m.bin 0x10000 /var/folders/dn/9dxfb1qx4mvglmsmq0c1n2l80000gn/T/arduino-create-agent825469852/Load_Cell.bin 0x8000 /var/folders/dn/9dxfb1qx4mvglmsmq0c1n2l80000gn/T/extrafiles555273803/Load_Cell.partitions.bin
usage: esptool write_flash [-h] [--erase-all]
[--flash_freq {keep,40m,26m,20m,80m}]
[--flash_mode {keep,qio,qout,dio,dout}]
[--flash_size FLASH_SIZE]
[--spi-connection SPI_CONNECTION] [--no-progress]
[--verify] [--encrypt]
[--ignore-flash-encryption-efuse-setting]
[--compress | --no-compress]
<address> <filename> [<address> <filename> ...]
esptool write_flash: error: argument <address> <filename>: [Errno 2] No such file or directory: '/var/folders/dn/9dxfb1qx4mvglmsmq0c1n2l80000gn/T/arduino-create-agent825469852/Load_Cell.bin'
And in red it says Executing command. exit status 2
I am using a M1 Mac Book Pro. And I am using a Adafruit ESP32 Huzzah Board. I have the Agent installed, even the Beta version for Chromium.
Please can any one help with this issue. My Old Computer did the Job fine, but is not with us any more.
Greetings
Max
Same error as this thread that I posted yesterday.
Seems like a real bug in the Web Tool compiler for ESP32 devices that just appeared.
It works now. I phoned my Internet service Provider. And they said they would make on of my Ports on there router a bridgeport. And now works.
Hope this might help some one else too.
