Hello all,
This is my code
* File: main.c
* Company: RIOU Glass
* Author: Mateusz WINTER
* Project: This project is to monitor temperature and humidity
* in a beehive by logging and saving data on SD card
// Configuration for DHT Sensor
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
// Configuration for RTC Module
// DS1302 RST -> Arduino Digital 7
// DS1302 DATA -> Arduino Digital 6
// DS1302 CLK -> Arduino Digital 5
//#include <DS1302.h>
//DS1302 rtc(7 , 6, 5);
//Time t;
// Configuration SD card module
// SD card attached to SPI bus as follows:
// MOSI - pin 11
// MISO - pin 12
// CLK - pin 13
// CS - pin 4
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
// Temperature sensors
float Temp_1;
float Temp_2;
// Delay
unsigned long seconds = 1000L; // 1000ms to 1s
unsigned long minutes = seconds * 1; // 900s in 15 minutes
void setup () {
Serial.begin(9600); // Baud rate of 9600
// rtc.halt(false);
// rtc.writeProtect(false);
// rtc.setDOW(THURSDAY);
// rtc.setTime(12, 0, 0);
// rtc.setDate(6, 8, 2010);
Serial.println(F("Beehive data logger"));
while (!Serial) {
Serial.print("Starting SD card...");
if (!SD.begin(chipSelect)) {
Serial.println("Card failed to start or not present");
while (1);
Serial.println(" Card is now operational!");
dht.begin();
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
Temp_1 = analogRead(A0)*5/1023.0; // Read value from analog port A0 voltage range 0V - 5V 1023 is to convert the 10 bit number to a voltage reading.
Temp_1 = Temp_1 - 0.5;
Temp_1 = Temp_1 / 0.01;
Temp_2 = analogRead(A1)*5/1023.0; // Read value from analog port A1 voltage range 0V - 5V 1023 is to convert the 10 bit number to a voltage reading.
Temp_2 = Temp_2 - 0.5;
Temp_2 = Temp_2 / 0.01;
// t = rtc.getTime();
File dataFile = SD.open("testing.txt", FILE_WRITE);
if (dataFile){
// Print to serial
Serial.print(F("Humidity: "));
Serial.print(h);
Serial.print(F("% Temperature: "));
Serial.print(t);
Serial.print(" \t"); // Create tab/space
Serial.print(Temp_1); // Print temperature from temperature sensor 1
Serial.print(Temp_2); // Print temperature from temperature sensor 2
// Save to SD card
dataFile.print(F("Humidity: "));
dataFile.print(h);
dataFile.print(F("% Temperature: "));
dataFile.print(t);
dataFile.print(" \t"); // Create tab/space
dataFile.print(Temp_1); // Print temperature from temperature sensor 1
dataFile.print(Temp_2); // Print temperature from temperature sensor 2
dataFile.println();
else {
Serial.println("There has been an error saving data");
delay(2000);
This is the output I am getting
Beehive data logger
Starting SD card... Card is now operational!
Humidity: 48.00% Temperature: 26.60 30.65 30.16
Humidity: 48.00% Temperature: 26.60 30.16 30.16
Humidity: 49.00% Temperature: 26.60 30.16 30.16
Humidity: 51.00% Temperature: 26.60 30.16 30.16
Humidity: 51.00% Temperature: 26.60 29.67 30.16
Humidity: 53.00% Temperature: 26.60 29.67 30.16
Humidity: 53.00% Temperature: 26.60 30.16 30.16
Humidity: 52.00% Temperature: 26.60 30.16 30.16
Humidity: 50.00% Temperature: 26.60 29.67 30.16
Humidity: 50.00% Temperature: 26.60 30.16 30.16
Humidity: 49.00% Temperature: 26.60 29.67 30.16
Humidity: 48.00% Temperature: 26.60 29.67 30.16
It creates the file but does not save the data, it also gets this error after a while and not sure what is going on.
Any help would be appreciated.
Thanks
