I'm trying to program note overlap for my matrix cv keyboard project. I have got to the point where I can play each note but it has to be released before a new note can be pressed.
I have implemented the Multikey code from the keypad library into the main loop which shows press/release/hold/idle key presses in the serial monitor.
I believe i am writing to the DAC + turning gate on when key-pressed and turning gate off when key-released however my DAC value (DACnum) is only printing zero's + gate is not working either.
Can anyone point me in the right direction?
#include <Keypad.h>
#include <stdlib.h>
#include <Wire.h>//Include the Wire library to talk I2C
#include <Adafruit_MCP4725.h>
//This is the I2C Address of the MCP4725, by default (A0 pulled to GND).
#define MCP4725_ADDR 0x60
Adafruit_MCP4725 dac;
#define LED 13 // Arduino Board LED is on Pin 13
#define GATE A0 // Use Pin 0 to output GATE signal
int DACnum = 0;
int LEDval = LOW;
int GATEval = LOW;
const byte numRows = 6;
const byte numCols = 9;
//Code that shows the the keypad connections to the arduino terminals
byte colPins[numCols] = {13, 12, 11, 10, 9, 8, 4, 3, 2}; //Rows 0 to 3
byte rowPins[numRows] = {A1, A2, A3, A4, A5, A6}; //Columns 0 to 3
//keymap defines the key pressed according to the row and columns just as appears on the keypad
byte keymap[numRows][numCols] =
{1, 7, 13, 19, 25},
{2, 8, 14, 20, 26},
{3, 9, 15, 21, 27},
{4, 10, 16, 22, 28},
{5, 11, 17, 23, 29},
{6, 12, 18, 24},
// DAC = 4096/5 V/12 (for 1V per Octave) = 67.9 per step
unsigned int DACpitches[29] =
0, 68, 137, 205, 273, 341, 410, 478,
546, 614, 683, 751, 819, 887, 956, 1024,
1092, 1161, 1229, 1297, 1365, 1434, 1502, 1570,
1638, 1707, 1775, 1843, 1911,
//initializes an instance of the Keypad class
Keypad kpd = Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
unsigned long loopCount;
unsigned long startTime;
String msg;
// initialize the serial communication:
Serial.begin(19200);
pinMode(GATE, OUTPUT); // Set GATE pin to output
Wire.begin();
dac.begin(0x60);
loopCount = 0;
startTime = millis();
msg = "";
//If key is pressed, this key is stored in keyPadNum variable
unsigned int KeyPadNum = kpd.getKey();
unsigned int DACnum = DACpitches[KeyPadNum];
loopCount++;
if ( (millis() - startTime) > 5000 ) {
// Serial.print("Average loops per second = ");
// Serial.println(loopCount/5);
loopCount = 0;
// Fills kpd.key[ ] array with up-to 10 active keys.
// Returns true if there are ANY active keys.
if (kpd.getKeys())
for (int i = 0; i < LIST_MAX; i++) // Scan the whole key list.
if ( kpd.key[i].stateChanged ) // Only find keys that have changed state.
switch (kpd.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
case PRESSED:
msg = "pressed";
dac.setVoltage(DACnum, false);
digitalWrite(GATE, HIGH); //Turn GATE on
Serial.println(DACnum);
case HOLD:
msg = " HOLD.";
case RELEASED:
msg = "Released";
digitalWrite(GATE,LOW); //Turn GATE off
case IDLE:
msg = " IDLE.";
Serial.print("Key ");
Serial.print(kpd.key[i].kchar);
Serial.print(myKeypad.key[i].kchar);
Serial.println(msg);
} // End loop
