Hi everyone,
I really need some help here as im super noob to arduino.
The problem: i have a small silo of a product and would like to connect an ultrasonic or LED/laser distance sensor to an arduino which is connected to ethernet and when the volume is low in the silo, i should get a notification on my phone that its low.
Can you guys help me with which components i need and maybe a general way to code it etc? Thanks in advance
You can try the Search Forum function, up to the right in this window.
Split the project into "Ardiono + distance".
Also go for "Arduino + ethernet".
When You master both You can make one code housing both.
Use wifi and an off-the-shelf wifi-camera to view the silage. Your livestock will thank you.
One of my friends is a professor of computer science (not the artistic branch of coding) who could easily build and code this. He opted for an off-the-shelf system, and can monitor his network of cameras from anywhere, at any time, including "in the dark" (with InfraRed).
A popular choice for similar applications is an ultrasonic sensor aimed down from the top.
The cheapest ones have a range of 4 m, but Maxbotics sells much better quality ones with longer ranges.
