notifying doorbell and then some more with pushingbox
well i got it setup using pushing box api. but i want to add more inputs that outputs to pushing box. i have a generator and transfer switch i want to know when it switches.
i have dry contacts off the transfer switch for normal and emergency position. i want the uno to send me alerts when it switches states. can someone help me add more outputs from the inputs??
heres the current code
// General code from http://www.pushingbox.com for Arduino + Ethernet Shield (official)
#include <SPI.h>
#include <Ethernet.h>
// MODIFY HERE //
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x19 }; // Be sure this address is unique in your network
//Your secret DevID from PushingBox.com. You can use multiple DevID on multiple Pin if you want
#define DEVID1 "vCD1F3635179D6F4" //Scenario : "The mailbox is open"
//Numeric Pin where you connect your switch
#define pinDevid1 3 // Example : the mailbox switch is connect to the Pin 3
// Debug mode
#define DEBUG true
//End//
char serverName[] = "api.pushingbox.com";
boolean pinDevid1State = false;
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
pinMode(pinDevid1, INPUT);
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
while(true);
else{
Serial.println("Ethernet ready");
// give the Ethernet shield a second to initialize:
// Listening for the pinDevid1 state
if (digitalRead(pinDevid1) == HIGH && pinDevid1State == false) // switch on pinDevid1 is ON
if(DEBUG){Serial.println("pinDevid1 is HIGH");}
pinDevid1State = true;
//Sending request to PushingBox when the pin is HIGHT
sendToPushingBox(DEVID1);
if (digitalRead(pinDevid1) == LOW && pinDevid1State == true) // switch on pinDevid1 is OFF
if(DEBUG){Serial.println("pinDevid1 is LOW");}
//Sending request to PushingBox when the pin is LOW
//sendToPushingBox(DEVID1);
//Function for sending the request to PushingBox
void sendToPushingBox(String devid){
if(DEBUG){Serial.println("connecting...");}
if (client.connect(serverName, 80)) {
if(DEBUG){Serial.println("connected");}
if(DEBUG){Serial.println("sendind request");}
client.print("GET /pushingbox?devid=");
client.print(devid);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(serverName);
client.println("User-Agent: Arduino");
client.println();
else {
if(DEBUG){Serial.println("connection failed");}
// if there are incoming bytes available
// from the server, read them and print them:
if(DEBUG){
if (client.available()) {
char c = client.read();
Serial.print(c);
if(DEBUG){Serial.println();}
if(DEBUG){Serial.println("disconnecting.");}
client.stop();
Brad,
I am not an expert at the Arduino and especially not at programming (more of a hardware guy) but I am using the same sketch and here is what I found. If you un-comment the "//sendToPushingBox(DEVID1)" shown below:
The program should send a message when the pin goes high and again when it goes low. I tried it and this seems to work. Let me know what you find. Oh and by the way that is a great idea to monitor an emergency generator. I have a generator and will look at my transfer switch first thing in the morning to see if I have a relay closure or other contacts that I can wire to my Arduino or my IOBridge.
Good luck,
Al
Awesome man i didnt see ur post till now. I will try it out tomorrow. Let me know what kinda transfer switch u have and i can help u get some contact points if u aint found em yet. My email
Is bradcox5975 at bellsouth.net its faster!
Will that add 6 more apots for dry contacts?
Bump
HI Brad,
I didn't test it yet but it should work
Just try this (with givin the DEVID2 value):
#include <SPI.h>
 // MODIFY HERE //
#define DEVID2 "vXXXXXXXXXXXXXXX"
#define pinDevid2 4
// Debug mode
#define DEBUG true
 //End//
boolean pinDevid2State = false;
  pinMode(pinDevid2, INPUT);
    while(true);
  else{
      // Listening for the pinDevid2 state
      if (digitalRead(pinDevid2) == HIGH && pinDevid2State == false) // switch on pinDevid2 is ON
        if(DEBUG){Serial.println("pinDevid2 is HIGH");}
        pinDevid2State = true;
        sendToPushingBox(DEVID2);
       if (digitalRead(pinDevid2) == LOW && pinDevid2State == true) // switch on pinDevid2 is OFF
        if(DEBUG){Serial.println("pinDevid2 is LOW");}
        //sendToPushingBox(DEVID2);
    client.println();
  else {
  if(DEBUG){
    Serial.print(c);
    client.stop();
Ill test it as soon as i get home! Thanks!
Can i just keep adding the devid for all the pins?
Hi All,
I'm totally new in this Arduino and pushing box. Managed to find the officiall code from pushingbox.com via Make: Projects
and try our step by step of hardware/software set up, but still could not get notified sms when pressed the doorbell. Can you all help me with it?
Follow the instruction, i changed the mac address which found at the sticker of ethernet shield, and copy/paste the devid code from senarios, please guide me beside these 2, whereelse i need to change?
Thanks for your help, and any guides/suggestion will be much appreciated.
