NRF24 sending 6 data problem reading
i am writing two separate code for trasmit 6 data and read 6 data from two differnce arduino i have wrote this in my two code:
this is the reciver at the middle u can find the trasmitter ;
the trasmitter is right, send at me the right thinks and i guess is seanding it at the athor aruino but i don't know why the another arduino can't read the code, can somebody give me an help
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define pin_M1A 2                                       //motore avanti 1
#define pin_M1I 3                                       //motore indietro 1
#define pin_M2A 4                                       //motore avanti 2
#define pin_M2I 7                                       //motore indietro 2
#define pin_VM1 5                                       //velocità motore 1 in uscita
#define pin_VM2 6                                       //velocità motore 2 in uscita
int M1A = 0;                                       //motore avanti 1
int M1I = 0;                                       //motore indietro 1
int M2A = 0;                                       //motore avanti 2
int M2I = 0;                                       //motore indietro 2
int VM1 = 0;                                       //velocità motore 1 in uscita
int VM2 = 0;                                       //velocità motore 2 in uscita
int WS = 0;                                       //analogico avanti indietro
int AD = 0;                                       // analogico destra sinistra
RF24 wireless(10,9);
const byte address1[6]= "00001";
const byte address2[6]= "00010";
const byte address3[6]= "00011";
const byte address4[6]= "00100";
const byte address5[6]= "00101";
const byte address6[6]= "00110";
wireless.begin();
wireless.setChannel(125);
wireless.openReadingPipe(0,address1);
wireless.openReadingPipe(1,address2);
wireless.openReadingPipe(2,address3);
wireless.openReadingPipe(3,address4);
wireless.openReadingPipe(4,address5);
wireless.openReadingPipe(5,address6);
wireless.setPALevel(RF24_PA_LOW);
wireless.startListening();
pinMode(pin_M1A, OUTPUT);
pinMode(pin_M1I, OUTPUT);
pinMode(pin_M2A, OUTPUT);
pinMode(pin_M2I, OUTPUT);
pinMode(pin_VM1, OUTPUT);
pinMode(pin_VM2, OUTPUT);
  wireless.read(&VM1,sizeof(VM1));
  Serial.println(VM1);
  analogWrite(pin_VM1,VM1);
  wireless.closeReadingPipe(0);
  wireless.read(&VM2,sizeof(VM2));
  Serial.println(VM2);
  analogWrite(pin_VM2,VM2);
  wireless.closeReadingPipe(1);
  wireless.read(&M1A,sizeof(M1A));
  Serial.println(M1A);
  digitalWrite(pin_M1A,M1A);
  wireless.closeReadingPipe(2);
  wireless.read(&M2A,sizeof(M2A));
  Serial.println(M2A);
  digitalWrite(pin_M2A,M2A);
  wireless.closeReadingPipe(3);
  wireless.read(&M1I,sizeof(M1I));
  Serial.println(M1I);
  digitalWrite(pin_M1I,M1I);
  wireless.closeReadingPipe(4);
  wireless.read(&M2I,sizeof(M2I));
  Serial.println(M2I);
  digitalWrite(pin_M2I,M2I);
  wireless.closeReadingPipe(5);
// this is the trasmitter code
#include <SPI.h>
#include <RF24.h>
#define pin_WS A5                                       //analogico avanti indietro
#define pin_AD A4                                       // analogico destra sinistra
wireless.begin();
wireless.openWritingPipe(address1);
wireless.openWritingPipe(address2);
wireless.openWritingPipe(address3);
wireless.openWritingPipe(address4);
wireless.openWritingPipe(address5);
wireless.openWritingPipe(address6);
wireless.stopListening();
  WS=analogRead(pin_WS);
  AD=analogRead(pin_AD);
  if(WS>=520)                                                         // avanti
    M1A=1;
    M2A=1;
    M1I=0;
    M2I=0;
    if(AD>=520)                                                       //rotazione a destra
      VM1=(map(WS,520,1023,0,255));
      VM2=((map(WS,520,1023,0,255))-(map(AD,520,1023,0,255)));
    else if(AD<=500)                                                  //rotazioen a sinistra
      VM1=((map(WS,520,1023,0,255))-(map(AD,520,0,0,255)));
      VM2=(map(WS,520,1023,0,255));
    else                                                              // avanti senza rotazione
  else if(WS<=500)                                                    //indietro
    M1A=0;
    M2A=0;
    M1I=1;
    M2I=1;
      VM1=((map(WS,500,0,0,255))-(map(AD,520,1023,0,255)));
      VM2=(map(WS,500,0,0,255));
    else if(AD<=500)                                                  //rotazione a sinistra
      VM1=(map(WS,500,0,0,255));
      VM2=((map(WS,500,0,0,255))-(map(AD,500,0,0,255)));
    else                                                              // indietro senza rotazione
    VM1=0;
    VM2=0;
    M1A=0;
    M2A=0;
    M1I=0;
    M2I=0;
wireless.write(&VM1,sizeof(VM1));
Serial.print("VM1 ");
delay(10);
wireless.write(&VM2,sizeof(VM2));
Serial.print("VM2 ");
delay(10);
wireless.write(&M1A,sizeof(M1A));
Serial.print("M1A ");
delay(10);
wireless.write(&M2A,sizeof(M2A));
Serial.print("M2A ");
delay(10);
wireless.write(&M1I,sizeof(M1I));
Serial.print("M1I ");
delay(10);
wireless.write(&M2I,sizeof(M2I));
Serial.print("M2I ");
delay(10);
From the reading code....
Copied from setup nyt then it's done again in loop. No expert in RF but it looks strange to me.
A bit the same is found in the transmitter, for writing. Is that correct to do?
i don't realy know i try it beacause i want to start the write in that pipe at the setup and in the loop i mean to say "write in this pipi this" with that open Writing Pipe" i have explain my self?
The same here. Look closer to RF example code, in the IDE, and see how they do it there!
i try to found one but i didn't found anything...
if somebody can give me an exemple of code
They are already there. Look into IDE examples!
I would highly recommend using a library like RF24Network or RF24Mesh for this
Wireless communication can be complex, and there are a number of things you will want to implement when using your own code for multi-device communication. One example is a header, containing a counter, to prevent data loss when repetitive data is sent. The nRF24 devices will often reject duplicate data with a matching CRC, so a header is recommended.
This is just the start, there are still lots of things to consider when communicating with multiple devices.
For an addressing tutorial with the base nRF24 lib, see:
