nRF24L01+ and ATtiny84
Hello all, I am working on a project, interfacing the nRF24L01+ with the ATTiny84, and I am having issues. Here is my code and wiring diagram:
#include <nRF24L01.h>
#include <RF24.h>
#define CE 2 // CE on PA2
#define CSN 3 // CSN on PA3
#define NO 9 // NO on PB1
#define OK 10 // OK on PB0
RF24 doorBellRadio(CE, CSN); // create an instance of the class RF24
  while(!doorBellRadio.begin()) // try to start radio
    //Serial.println("Failed to start radio...");
    digitalWrite(NO, HIGH);
    digitalWrite(OK, LOW);
    digitalWrite(NO, LOW);
  digitalWrite(OK, HIGH);
  delay(5000);
  // do nothing for now
I am using LEDs named "OK" and "NO" as a debugging tool since the ATTiny84 doesn't have a serial port. So these let me know when the radio fails or loads. My issue right now is that doorBellRadio.begin() always fails. I have verified and reverified my wiring over and over again. I have edited the RF24.cpp (I am using the 1.3.2 version of the RF24 library) file to ensure that the library is calling the correct pins of the ATtiny84. And, I have commented out the lines
//ATTiny
//#elif defined(__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__) || defined(__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__) || defined(__AVR_ATtiny2313__) || defined(__AVR_ATtiny4313__) || defined(__AVR_ATtiny861__)
  //#define RF24_TINY
  //#include "utility/ATTiny/RF24_arch_config.h"
in the RF24_config.h file as well. If anyone knows what I might be doing wrong, I appreciate your help! Also, here is the pinout that I am following for the ATtiny84:
Thanks in advance.
The RF24 lib should be working out-of-the-box with ATTiny 84. There should typically be no need to edit the RF24 files.
If radio.begin is failing, it indicates a basic communication failure between the radio and MCU. This is usually due to bad wiring, pin connections etc and indicates a need to verify the main MISO MOSI and SCK pins.
Using the Arduino IDE to compile the code for the ATTiny84, I kept receiving error messages because of the RF24 library. It had something to do with missing definitions of pins, so that's why I switched over to an older version of the RF24 library.
I was able to program the uC using an Arduino Nano with the basic blink sketch (and an external interrupt via a pushbutton). So I know that I have the correct SPI pins for programming it, but the communication between the uC and the nRF24 radio module fails.
The RF24 library is designed to work with the ATTiny core from SpenceKonde at GitHub - SpenceKonde/ATTinyCore: Arduino core for ATtiny 1634, 828, x313, x4, x41, x5, x61, x7 and x8
Which ATTiny core are you using?
This is the core that I am using. I don't know why I am getting errors then. I will investigate it.
Ok, I just recompiled the code from above, and I didn't get any error messages this time. Weird. I don't know why I was getting those messages before. I know I was doing something wrong, I just don't know what it is.
For the project I was working on, I had to upgrade from an ATTiny84 to a Nano for other reasons, so I am not even working with the Tiny anymore. Thank you for the help though, and sorry for the trouble. I will definitely be working with the ATTiny84 and nRF24 in the near future though.
