nRF24L01 + Arduino Uno + 3 servos + Joystickshield
i try to use nRF24L01 to control 3 servos , but i cannot work.
JOYSTICK_SHD_V2.0.pdf (40.5 KB)
jixieshoubiRX.ino (5.78 KB)
but i cannot work.
Conveys absolutely no useful information that we don't already know. You would not be here if it worked.
Did you develop that code a little at a time, testing each piece before adding more?
groundfungus:
yes, i test each part with test code, it work perfectly. But than i use the code for robotarm, it cannot work. I try to fix it, but it didn't work. I guess there are some problems in nRF24L01.
groundfungus:
i test nRF24L01 again, not working!!! I think it is one of the reason for that.QAQ
Maybe this Simple nRF24L01+ Tutorial will help.
Debugging wireless is always difficult so get that part working first and then add the other parts piece by piece testing at each step.
...R
Robin2:
...R
you know what happened? I tested the one of the nRF24L01 with RX code:
#include <SPI.h>
#include <Mirf.h>
#include <nRF24L01.h>
#include <MirfHardwareSpiDriver.h>
int value;
Mirf.spi = &MirfHardwareSpi;
Mirf.init();
Mirf.setRADDR((byte *)"FGHIJ");
Mirf.payload = sizeof(value);
Mirf.channel = 90;
Mirf.config();
Serial.println("Listening...");
if(Mirf.dataReady()) {
Mirf.getData((byte *) &value);
Serial.print("Got data: ");
Serial.println(value);
It printed "Got data:0 or -1 or 3969" , even the transimitter didn't exist! QAQ
TX code:
#include <SPI.h>
#include <Mirf.h>
int value;
Mirf.init();
Mirf.setRADDR((byte *)"ABCDE");
Mirf.channel = 90;
Mirf.config();
Mirf.setTADDR((byte *)"FGHIJ");
value = random(255);
Mirf.send((byte *)&value);
while(Mirf.isSending()) delay(1);
So i guess this nRF24L01 went wrong, i need a brand-new one to test again.
