NRF24L01 bi-directional communication with strings
Hi there,
I have a kinda strange problem with communication between 2 arduinos using wifi modules. My goal is sending data to RC car and then send some data back (voltage of battery and RPM of the engine). For that, I need to convert all data to the string, send it and decode at the opposite side. I've already successfully established bi-directional communication but only with sending and receiving just one value (without strings) or only with string at one side (one arduino makes string and sends it, second successfully receives and rotates servos). I can send "non-stringed" value back and receive it as well. But if I try to send and receive string on both sides, it stops working. I discovered, that "Joystick" program can run until I start "Servo". Immediately after it receives 1st message, it stops at radio.write(&stringy[1], sizeof(stringy[1]));. (This function isn't processed.) Arduino is absolutely lagged and only helps to disconnect it from a power supply.
Servo program runs without any issues, I think.
Memset have evidently no effect.
However, I don't need to send strings if there are any other solutions, but I don't know any.
// Joystick code
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define online 3
#define offline 9
RF24 radio(7, 8); // CNS, CE
const byte addresses[][6] = {"00001", "00002"};
boolean overeni = 0;
char stringy[][20] = {"odeslatJoystick", "prijatoJoystick"};
int potValue;
int potValue2;
int angleValue;
int angleValue2;
 pinMode(A2, INPUT);
 pinMode(A0, INPUT);
 pinMode(3, OUTPUT);
 pinMode(9, OUTPUT);
 radio.begin();
 radio.openWritingPipe(addresses[1]); // 00001
 radio.openReadingPipe(1, addresses[0]); // 00002
 radio.setPALevel(RF24_PA_MIN);
 Serial.println("Zacatek loopu");
 // VYSILANI
 delay(5);
 radio.stopListening();
 Serial.println("Vysilani zahajeno");
 potValue = analogRead(A0);
 angleValue = map(potValue, 0, 1023, 0, 180);
 potValue2 = analogRead(A2);
 angleValue2 = map(potValue2, 0, 1023, 0, 180);
 Serial.println("Hodnoty precteny a namapovany");
 sprintf(stringy[1], "%d,%d", angleValue, angleValue2);
 Serial.println("String vytvoren");
 Serial.println("Data odeslana");
 memset( stringy[1], 0, sizeof( stringy[1]));
 // PRIJIMANI
 delay(5);
 radio.startListening();
 if (!radio.available());
 Serial.println("If prijimani");
 radio.read(&stringy[0], sizeof(stringy[0]));
 sscanf(stringy[0], "%d", &overeni);
 Serial.println("Prijato");
 Serial.println(overeni);
 if (overeni == 1) {
   digitalWrite(online, HIGH);
   digitalWrite(offline, LOW);
 else {
   digitalWrite(online, LOW);
   digitalWrite(offline, HIGH);
 memset( stringy[0], 0, sizeof( stringy[0]));
// Servo code
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
int angleV = 90;
int angleV2 = 90;
char stringy[][20] = {"odeslatServo", "prijatoServo"};
Servo myServo;
Servo myServo2;
 pinMode(5, OUTPUT);
 pinMode(3, OUTPUT);
 myServo.attach(5);
 myServo2.attach(3);
 radio.begin();
 radio.openWritingPipe(addresses[0]); // 00002
 radio.openReadingPipe(1, addresses[1]); // 00001
 // PRIJIMANI
 delay(5);
 if ( radio.available()) {
   Serial.println("If proslo");
   while (radio.available()) {
     Serial.println("While proslo");
// Inty
     sscanf(stringy[0], "%d,%d", &angleV, &angleV2);
     Serial.println("Prijmuto");
     Serial.println(angleV);
     Serial.println(angleV2);
     myServo.write(angleV);
     myServo2.write(angleV2);
   // VYSILANI
   delay(5);
   sprintf(stringy[1], "%d", overeni);
   Serial.println("Overeni odeslano");
Try either of these suggestions...
radio.write(stringy[1], sizeof(stringy[1]));
radio.write(&stringy[1][0], sizeof(stringy[1]));
First things first. The nRF24 is not a Wifi module.
This Simple nRF24L01+ Tutorial may help. Get one of the examples working and then extend it to do what you need.
I use the system in the 2nd example (using the ackPayload feature) for radio control of model trains.
...R
Thanks.
I know the NRF24L01 is not a real wifi module, but it's called so because it uses 2,4 GHz, like WiFi.
kubajz22:
Thanks.
No it is not a WiFi module, and only fools would call it one.
kubajz22:
Bluetooth also uses 2.4GHz but you don't call Bluetooth Wifi or call WiFi Bluetooth.
...R
