Nrf24l01 fails to receive data
I am currently working on a radio controlled robot tracked chassis with a robotic arm. I have 3d printed a controller for the robotic arm rather than just using a 'bank' of variable resistors.
I am really pleased with how everything is working, the code is stable and the arm works really nicely. That is until I add some code to control the jaws on the arm.
The jaws open and close with push button switches, one side connected to ground thru 10k resistors. On the transmit ( crawler base) side I have debugging information which is telling me that everything is working as it should.
However, on the receive (crawler) side there is no received data.
The data doesn't get received when I add the code for the bush button switches.
Code for transmitter side:
* Sketch for :
* V7 Adding jaws open and close
* V6 Is not of any use
* V5A  Cleaning up radio tx rx
* V5  Tweaking steering
* V4  Test using joystick for rotate CCW and CW, no buttons
* V3 Including 3 pos switch for video switching
* Sending steering joystick fwd/rev data
* Push buttons to rotate crawler on its axis
* Sending arm controller data including push button jaws
//#include <SPI.h>        //
#include <nRF24L01.h>               //
#include <RF24.h>                  // Including radio Libraries
#include <Wire.h>      //I2C serial comms
RF24 radio(9, 10); // CE, CSN
const byte address[6] = "00001";      //set array which contains the addrress
int Speeds[12];  // Array for sending data
int LTSpeed;
int RTSpeed;
int LeftX;
int RightX;
int JoystickX;            // Define variables
int PotVal = 0;
int Speed;
int GearPin = 2;    // Define digital pin 2
int FwdRev = 0;
int RotCW = 0;
int RotCCW = 0;
int SwitchPos1 = 5 ;   //3 pos switch for camera switching
int SwitchPos2 = 6;
int PosPWM = 0;
int JawCloseButton = 7;
int JawOpenButton = 8;
int JawOpen;                // specify variables
int JawClose;
int JawPos= 45;
int controlBase;
int controlShoulder;
int controlElbow;       // Integers for reading pot values
int controlWrist;
int controlRotate;
//int controlJaws;
int mtrDegreeBase;
int mtrDegreeShoulder;
int mtrDegreeElbow;
int mtrDegreeWrist;      //integers for how many degrees to move servos
int mtrDegreeRotate;
//int mtrDegreeJaws;
  pinMode(GearPin, INPUT);
  pinMode( SwitchPos1, INPUT);
  pinMode( SwitchPos2, INPUT);
  pinMode(JawCloseButton, INPUT);
  pinMode(JawOpenButton, INPUT);
   radio.begin();
  radio.openWritingPipe(address);      // Define reading and writing addresses
  radio.setPALevel(RF24_PA_LOW);
  radio.setDataRate(RF24_250KBPS);
  radio.setChannel(125);
  radio.stopListening();
    JoySend();
    ArmSend();
    CamSwitch();
    if ((digitalRead(JawCloseButton) ==HIGH)||(digitalRead(JawOpenButton) ==HIGH))
    JawSend();   }
    radio.write(&Speeds, sizeof(Speeds));  //Send the array
void JoySend(){
PotVal = analogRead(A1);      //  Read the pot value which is the speed
Speed = map(PotVal, 0, 1023, 0, 255);  //Map potvalue to 255
   JoystickX = analogRead(A0);    // Read the Left Right movement of joystick
   if (JoystickX <=498) {
     LeftX = map(JoystickX, 498, 2, 0, Speed);   //Clever bit here, map to Speed value
     RightX = 0;
    if (JoystickX >= 498)      {
       RightX = map(JoystickX, 498, 1022, 0, Speed);
       LeftX = 0;
    LTSpeed = Speed - 1.1*RightX;    //making LTSpeed go slightly negative for ccw
    RTSpeed = Speed - 1.1*LeftX;     // making RTSpeed go slightly negative for ccw
    if ( LTSpeed<0){
      RotCCW = HIGH;
    else {
      RotCCW = LOW;
      if (RTSpeed<0) {
        RotCW = HIGH ;
      else {
        RotCW = LOW;
FwdRev = digitalRead(GearPin);
  Speeds[0] = LTSpeed;    //Write the LTSpeed into the Speeds array slot 1
  Speeds[1] = RTSpeed;    //Write the RTSpeed into the Speeds array slot 2
  Speeds[2] = FwdRev;
  Speeds[3] = RotCW;
  Speeds[4] = RotCCW;
 Serial.print("JoyX = ");
  Serial.print(JoystickX);
  Serial.print(" LeftX = ");
  Serial.print(LeftX);
  Serial.print( " RightX = ");
  Serial.print(RightX);
  Serial.print( " LSpeed= ");
  Serial.print (LTSpeed);
  Serial.print( " RTSpeed= ");
  Serial.print(RTSpeed);
  Serial.print(FwdRev);
  //Serial.print(RotCW);
  //Serial.println(RotCCW);
void CamSwitch () {
if ((digitalRead(SwitchPos1) == LOW) && (digitalRead(SwitchPos2) == LOW)) {
      //CamSwitcher.write(80);
      PosPWM = 80;
      Serial.print( "SAng=80 ");
    if ((digitalRead(SwitchPos1) == HIGH) && (digitalRead(SwitchPos2) == LOW)) {
      //CamSwitcher.write(45);
      PosPWM = 45;
      Serial.print( "SAng=45 ");
     if ((digitalRead(SwitchPos1) == LOW) && (digitalRead(SwitchPos2) == HIGH)) {
     // CamSwitcher.write(120);
      PosPWM = 120;
     Serial.print( " SAng=120 ");
Speeds[5] = PosPWM;
void ArmSend(){
  controlBase = analogRead(A2);
  mtrDegreeBase = map(controlBase, 0, 1024, 0, 180);
controlShoulder = analogRead(A3);
  mtrDegreeShoulder = map(controlShoulder, 100, 570, 0, 180);
  controlElbow = analogRead(A4);
  mtrDegreeElbow = map(controlElbow, 170, 660, 0, 180);
  controlWrist = analogRead(A5);
  mtrDegreeWrist = map(controlWrist, 1023, 600, 0, 180);
  controlRotate = analogRead(A6);
  mtrDegreeRotate = map(controlRotate, 1023, 0, 0, 180);
Speeds[6] = mtrDegreeBase;
Speeds[7] = mtrDegreeShoulder;
Speeds[8] = mtrDegreeElbow;
Speeds[9] = mtrDegreeWrist;
Speeds[10] = mtrDegreeRotate;
  Serial.print(" B =");
  Serial.print(mtrDegreeBase);
  Serial.print(" S =");
  Serial.print(mtrDegreeShoulder);
  Serial.print(" E =");
  Serial.print(mtrDegreeElbow);
  Serial.print(" W =");
  Serial.print(mtrDegreeWrist);
  Serial.print(" R =");
  Serial.println(mtrDegreeRotate);
 void JawSend() {
  if (digitalRead(JawCloseButton) ==HIGH) {         //When button pressed
JawPos = JawPos + 1;
  //delay(15);
  if (JawPos >=120) {
    JawPos = 120;  }             // Go to function close jaws
Serial.print ( "Jaw Pos Angle = ");
Serial.println(JawPos);
Speeds[11] = JawPos;
//radio.write(&Speeds, sizeof(Speeds));  //Send the array
 if (digitalRead(JawOpenButton)==HIGH)   {
  JawPos = JawPos - 1;
 // delay(15);
  if (JawPos <=0) {
    JawPos = 0;  }                          // When button pressed go to open jaws
Code for Receiver side:
* Sketch to:
* V6 No real use
* V4   Test to use joystick for rotate ccw cw
* Includes camera switching using pwm o/p on pin 2
*  receive steering data
*  Added rotating on crawler axis
*  receive arm data
//#include <SPI.h>
#include <RF24.h>            // include libraries
#include <Wire.h>
#include <Servo.h>
// Include Adafruit PWM Library
#include <Adafruit_PWMServoDriver.h>
#define MIN_PULSE_WIDTH       650
#define MAX_PULSE_WIDTH       2350
#define FREQUENCY             50
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
Servo SwitchCam;     // Initialise pwm for camera switching
// Define Motor Outputs on PCA9685 board
int motorBase = 0;
int motorShoulder = 1;
int motorElbow = 2;
int motorWrist = 3;
int motorRotate = 4;
int motorJaws = 5;
// Define Motor position variables
int mtrDegreeBase;
int mtrDegreeElbow;
int mtrDegreeWrist;
int mtrDegreeJaws;
int pulse_wide;
int pulse_width;
int Speeds[12];   //Array size for receiving data
int RTSpeed;       // Define variables
int LTSpeed;
int Rotate;
int FwdRev = 0;
int RotCW = 0;
int RotCCW = 0;
int i = 0;
int CamSwitcher[1];
int PosPwm;
//Motor A pins for driver card
int enA = 5;
int in1 = 7;
int in2 = 8;
//Motor B  pins for driver card
int enB = 6;
int in3 = A0;
int in4 = A1;
  pinMode(enA, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(enB, OUTPUT);   //Set outputs to motor drivers
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  radio.begin();   //Initialise radio
  //Setting radio parameters
  radio.openReadingPipe(0,address);
  radio.startListening();
  // Setup PWM Controller object
  pwm.begin();
  pwm.setPWMFreq(FREQUENCY);
  SwitchCam.attach(2);
    while (radio.available()) {
      radio.read(&Speeds, sizeof(Speeds));   // Receive Speeds array
      LTSpeed = Speeds[0];    // Assign variables to array contents
      RTSpeed = Speeds[1];
      FwdRev = Speeds[2];
      RotCW = Speeds[3];
      RotCCW = Speeds[4];
      PosPwm = Speeds[5];
      mtrDegreeBase = Speeds[6];    // Assign variables to array contents
      mtrDegreeShoulder = Speeds[7];
      mtrDegreeElbow = Speeds[8];
      mtrDegreeWrist = Speeds[9];
      mtrDegreeRotate = Speeds[10];
      mtrDegreeJaws = Speeds[11];
  JoyRx();   // function to receive speed/steering/spin data
  CamSwitchRx();   // function to receive pwm value for cam switcher
  ArmControlRx();     // function to receive arm control data
        void JoyRx() {
   // When joystick is fully one way sets motors to rotate CW
       while (RotCW == HIGH) {
        digitalWrite(in1, HIGH);
       digitalWrite(in2, LOW);
       analogWrite(enA, LTSpeed);
       digitalWrite(in3, LOW);
       digitalWrite(in4, HIGH);
       analogWrite(enB, RTSpeed);
       Serial.print("LTSpeed = ");
       Serial.print(LTSpeed);
       Serial.print("  RTSpeed = ");
       Serial.println ("  Spin CW");
      //Check if CW state is still applicable for while loop
       }// Check button state
      RotCW = Speeds[3];
       //When joystick is fully the other way, set motors to rotate CCW
         while (RotCCW == HIGH) {
          digitalWrite(in1, LOW);
       digitalWrite(in2, HIGH);
       analogWrite(enA, RTSpeed);
       digitalWrite(in3, HIGH);
       digitalWrite(in4, LOW);
       analogWrite(enB, LTSpeed);
       Serial.print(" LTSpeed = ");
      Serial.println ("  Spin CCW");
      // Read radio to see if CCW is still valid
      RotCCW = Speeds[4];    //Check button state
      //For driving in reverse
          if (FwdRev == LOW) {
Serial.print( " Rev ");
       Serial.print( " LTrack = " );
       Serial.print( " RTrack = " );
        //For driving forward
         else {
      Serial.print( " Fwd ");
       delay(3);
void CamSwitchRx()  {        //Function to receive PWM value
    SwitchCam.write(PosPwm);       //Write to outut pin for cam switcher
    Serial.print( " CamPWM = ");
    Serial.print(PosPwm);
    delay(10);
       void ArmControlRx() {
pulse_wide = map(mtrDegreeBase, 0, 180, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
  pulse_width = int(float(pulse_wide) / 1000000 * FREQUENCY * 4096);
  //Control Base Motor
  pwm.setPWM(motorBase, 0, pulse_width);
   pulse_wide = map(mtrDegreeShoulder, 0, 180, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
  //Control Shoulder Motor
  pwm.setPWM(motorShoulder, 0, pulse_width);
  pulse_wide = map(mtrDegreeElbow, 0, 180, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
  //Control Elbow Motor
  pwm.setPWM(motorElbow, 0, pulse_width);
pulse_wide = map(mtrDegreeWrist, 0, 180, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
  //Control Wrist Motor
  pwm.setPWM(motorWrist, 0, pulse_width);
pulse_wide = map(mtrDegreeRotate, 0, 180, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
  //Control Rotate Motor
  pwm.setPWM(motorRotate, 0, pulse_width);
  pulse_wide = map(mtrDegreeJaws, 0, 180, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
  //Control Jaws Motor
  pwm.setPWM(motorJaws, 0, pulse_width);
  Serial.print(mtrDegreeRotate);
 Serial.print(" J =");
  Serial.println(mtrDegreeJaws);
The problem arises when I added this piece of code into the void() loop.
JawSend(); }
Even if a comment out the JawSend() function nor even add the JawSend value to the send array the receiver receives no data. It stops working with that couple of lines of code. I've even tried while loops, adding the code into the void ArmSend() function but nothing seems to work.
It is a really weird one, I have spent hours trying to figure out why adding that bit of code results in no data being received.
If anybody has any ideas, I would much appreciate it as it is really stumped me!
Thanks
Steve
So are you really saying that adding
if ((digitalRead(JawCloseButton) == HIGH) || (digitalRead(JawOpenButton) == HIGH))
// JawSend();
to the loop breaks the otherwise working programs?
a7
Yes....I know. It is really weird.
Haha, I got nothing.
But. How are the switches wired, and have you tried using INPUT_PULLUP on those pins.
Yes, it should makes no difference. I might as well be asking "have you tried turning it off then back on again". :wink:
a7
I have resistors to ground on the switches.....On the Tx side the code works fine. All the arm, steering/speed, cam switching PWM and jaw opening and closing data is there it just doesn't make it to the Rx side.
And yes, I have turned the whole thing on/off many, many times!!
It is quite honestly doing my head in...along with England going out on penalties it hasn't been a good weekend!
In your transmitter, the "Speeds" array is send for each iteration of loop, even if it has not changed - this is not optimal.
EDIT: Removed a brainfart.
Danois, thanks for that.
I have tried your suggestion but get exactly the same outcome.
All the data gets sent and is received perfectly well until I add the JawSend() function.
Sorry, I made a mistake. Try to change your "JawSend()" and "loop()" functions to this:
void loop()  {
    JoySend();
    ArmSend();
    CamSwitch();
    JawSend();
void JawSend() {
  if (digitalRead(JawCloseButton)  == HIGH)  {         //When button pressed
    JawPos += 1;
    if (JawPos > 120) JawPos = 120;             // Go to function close jaws
    //delay(15);
  if (digitalRead(JawOpenButton) == HIGH)   {
    JawPos -= 1;
    if (JawPos < 0) JawPos = 0; // When button pressed go to open jaws
    // delay(15);
That should work for the transmitter part.
Danois,
I can see what you are getting at with your last suggestion, I was hopeful because I hadn't tried that approach....Result....No data at the receiver.
It is really, really odd. I just do not understand why with that extra code all data is lost at the Rx end.
I have tried combining the JawSend() code into the ArmSend() function as well with exactly the same result.
I am at my wits end!
In your receiver code, you have multiple "while (radio.available()) {...}" loops. All these loops should be removed and replaced with a single "if (radio.available()) { radio.read(...); }" as the first in the "loop()" method.
Danois,
I was wondering about having multiple while loops....Anyway, changed to a single if (radio.available()) { radio.read(...); and guess what?
No data received.
I say no data...But I suppose a '0' is data rather than gobbledegook. I receive all zeros.
LOL.. I think the penny just dropped.. Try this:
radio.write(&Speeds, sizeof(Speeds)); //Wrong, pointer to a pointer
radio.write(Speeds, sizeof(Speeds)); //Right, pointer to an array
Same goes for the receiver (remove the "&").
I had no idea what the '&' does in there. Taking it out makes........No difference...
Still zeros.
Thanks for spending so much time improving my understanding of coding.
I know that it will be help from you or this forum that sorts this because for the first time in my short coding history, I have never been so clueless of why something is happening!!
If the code in #2, an empty if statement (the call commented out) is breaking your program… it makes no sense to tinker with the code.
It is basically “impossible”.
Please reiterate your confident assertion that adding an empty if statement breaks the program.
What is the reported memory use at the bottom of the window when you compile both programs?
Straw clutching.
It is possible that something inadvertent in your code has set up conditions for undefined behaviour. A casual examination of your code does not see anything jump out.
It is possible that there is some kind of issue totally external to what you are up to. Not likely.
a7
Hi A7
I have modified the code after some input from Danois....It is much neater.
Basically what happens now is if I comment out the JawPos() function in the void() loop, I get data at the receiver. So it is something to do with that function which makes no sense.
Sketch uses 6850 bytes (22%) of program storage space.
Global variables use 500 bytes (24%) of dynamic memory, leaving 1548 bytes for local variables.
Here's the slightly modified Tx side code:
* Sketch for :
int LTSpeed;
int RTSpeed;
int LeftX;
int RightX;
int PotVal = 0;
int Speed;
int FwdRev = 0;
int RotCW = 0;
int RotCCW = 0;
int SwitchPos2 = 6;
int PosPWM = 0;
int JawClose;
int JawPos= 45;
int controlBase;
int controlWrist;
int controlRotate;
//int controlJaws;
int mtrDegreeBase;
int mtrDegreeElbow;
   radio.begin();
    JoySend();
    ArmSend();
    CamSwitch();
    JawSend();        // If I comment out this line, everything works great. With it, I get zeros.
//radio.write(&Speeds, sizeof(Speeds) * sizeof(Speeds[0]));
    radio.write(Speeds, sizeof(Speeds));  //Send the array
void JoySend(){
     RightX = 0;
       LeftX = 0;
    if ( LTSpeed<0){
      RotCCW = HIGH;
    else {
      RotCCW = LOW;
      if (RTSpeed<0) {
        RotCW = HIGH ;
      else {
        RotCW = LOW;
  Speeds[2] = FwdRev;
  Speeds[3] = RotCW;
  Speeds[4] = RotCCW;
void CamSwitch () {
      PosPWM = 80;
      PosPWM = 45;
      PosPWM = 120;
Speeds[5] = PosPWM;
void ArmSend(){
void JawSend() {
    JawPos += 1;
    //delay(15);
    JawPos -= 1;
    // delay(15);
In you receiver, you should only "unpack" the array and set the values when a reception occurs. As it is, you code sets values even if nothing is received. Basically all the code in the "loop()" function should be wrapped in an "if (radio.available()) { ... }" statement.
Danois,
I've popped out for a while but will have a look at your suggestion when I'm back home.
Please note however that even if I don't pack the JawPos value into the array, the receiver shows zeros so I'm not loading any extra data to be transmitted.
By simply going to the JawSend function stops the receiver from getting the data.
It's strange.
Danois,
I understand what you are saying. I have done what you suggested.
  //radio.read(&Speeds, sizeof(Speeds) * sizeof(Speeds[0]));
  radio.read(Speeds, sizeof(Speeds));   // Receive Speeds array
  FwdRev = Speeds[2];
  RotCW = Speeds[3];
  RotCCW = Speeds[4];
  PosPwm = Speeds[5];
The same result....Works ok with JawSend() commented out but zeros when function called.
WTF is going on???
Thanks again for your suggestions. They all make complete sense and I feel that I have learned a lot. Just wish the thing would work!
Sorted!!!!!!
I had set JawPos = 45; in the top section and not in the setup loop....Doh.
