Hi everyone, this is my first post on the forum so I'm not quite sure the question is in the correct place!
Anyway, for my project I need to use a radio and I've gone for the nRF24L01+ with the antenna, over the past couple of weeks I've researched about it and tried to get it to work with the example code using the NRF24 library by maniacbug without any improvement. I've added an extra power source, tried capacitors ranging from 0.1uF to 100uF as well as the radiohead/mirf libraries. At which point I thought my module was broken (i might have connected it to 5V at some point by mistake :S). I then came across the printDetails() function in one of the example sketches and I get some output...(meaning it might not be broken?) but then when I type "T" in the serial box to begin transmission it says sending failed. I've posted pictures of both the output of printDetails() as well as the "sending failed".
I've got no idea what to do, if I should just ditch these modules and get new ones ( I got these off ebay)...any thoughts or ideas would be great!
PS. I was also given two other modules (the standard ones) but they don't work at all...printDetails just gives me all 0's (4/4 broken modules?? how unlucky can I be)
Thanks for your reply. I've read that tutorial, the example sketch they provide was one of the first things I tried. I didn't post my code because it's just the "Getting Started" and "pingpair_ack"example sketch from the nrf24 library...
As a search through this forum will reveal, a number of people have recently been reporting trouble with modules bought on eBay. They are often defective, but 4/4 does seem particularly bad.
Thanks for your replies! the code with the printDetails() is the following:
// March 2014 - TMRh20 - Updated along with High Speed RF24 Library fork
// Parts derived from examples by J. Coliz <maniacbug@ymail.com>
* Example for efficient call-response using ack-payloads
* This example continues to make use of all the normal functionality of the radios including
* the auto-ack and auto-retry features, but allows ack-payloads to be written optionally as well.
* This allows very fast call-response communication, with the responding radio never having to
* switch out of Primary Receiver mode to send back a payload, but having the option to if wanting
* to initiate communication instead of respond to a commmunication.
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8
RF24 radio(7,8);
// Topology
const uint64_t pipes[2] = { 0xABCDABCD71LL, 0x544d52687CLL }; // Radio pipe addresses for the 2 nodes to communicate.
// Role management: Set up role. This sketch uses the same software for all the nodes
// in this system. Doing so greatly simplifies testing.
typedef enum { role_ping_out = 1, role_pong_back } role_e; // The various roles supported by this sketch
const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"}; // The debug-friendly names of those roles
role_e role = role_pong_back; // The role of the current running sketch
// A single byte to keep track of the data being sent back and forth
byte counter = 1;
void setup(){
printf_begin();
Serial.print(F("\n\rRF24/examples/pingpair_ack/\n\rROLE: "));
Serial.println(role_friendly_name[role]);
Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
// Setup and configure rf radio
radio.begin();
radio.setAutoAck(1); // Ensure autoACK is enabled
radio.enableAckPayload(); // Allow optional ack payloads
radio.setRetries(0,15); // Smallest time between retries, max no. of retries
radio.setPayloadSize(1); // Here we are sending 1-byte payloads to test the call-response speed
radio.openWritingPipe(pipes[1]); // Both radios listen on the same pipes by default, and switch when writing
radio.openReadingPipe(1,pipes[0]);
radio.startListening(); // Start listening
radio.printDetails(); // Dump the configuration of the rf unit for debugging
void loop(void) {
if (role == role_ping_out){
radio.stopListening(); // First, stop listening so we can talk.
printf("Now sending %d as payload. ",counter);
byte gotByte;
unsigned long time = micros(); // Take the time, and send it. This will block until complete
//Called when STANDBY-I mode is engaged (User is finished sending)
if (!radio.write( &counter, 1 )){
Serial.println(F("failed."));
}else{
if(!radio.available()){
Serial.println(F("Blank Payload Received."));
}else{
while(radio.available() ){
unsigned long tim = micros();
radio.read( &gotByte, 1 );
printf("Got response %d, round-trip delay: %lu microseconds\n\r",gotByte,tim-time);
counter++;
// Try again later
// Pong back role. Receive each packet, dump it out, and send it back
if ( role == role_pong_back ) {
byte pipeNo;
byte gotByte; // Dump the payloads until we've gotten everything
while( radio.available(&pipeNo)){
radio.writeAckPayload(pipeNo,&gotByte, 1 );
// Change roles
if ( Serial.available() )
char c = toupper(Serial.read());
if ( c == 'T' && role == role_pong_back )
Serial.println(F("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK"));
role = role_ping_out; // Become the primary transmitter (ping out)
radio.openWritingPipe(pipes[0]);
radio.openReadingPipe(1,pipes[1]);
else if ( c == 'R' && role == role_ping_out )
Serial.println(F("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK"));
role = role_pong_back; // Become the primary receiver (pong back)
and I've also used the getting started code (which also doesnt work):
* Getting Started example sketch for nRF24L01+ radios
* This is a very basic example of how to send data from one node to another
* Updated: Dec 2014 by TMRh20
#include <SPI.h>
#include "RF24.h"
/****************** User Config ***************************/
/*** Set this radio as radio number 0 or 1 ***/
bool radioNumber = 0;
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 */
RF24 radio(7,8);
byte addresses[][6] = {"1Node","2Node"};
// Used to control whether this node is sending or receiving
bool role = 0;
Serial.println(F("RF24/examples/GettingStarted"));
radio.begin();
// Set the PA Level low to prevent power supply related issues since this is a
// getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
radio.setPALevel(RF24_PA_LOW);
// Open a writing and reading pipe on each radio, with opposite addresses
if(radioNumber){
radio.openWritingPipe(addresses[1]);
radio.openReadingPipe(1,addresses[0]);
}else{
radio.openWritingPipe(addresses[0]);
radio.openReadingPipe(1,addresses[1]);
// Start the radio listening for data
/****************** Ping Out Role ***************************/
if (role == 1) {
Serial.println(F("Now sending"));
if (!radio.write( &time, sizeof(unsigned long) )){
Serial.println(F("failed"));
radio.startListening(); // Now, continue listening
unsigned long started_waiting_at = micros(); // Set up a timeout period, get the current microseconds
boolean timeout = false; // Set up a variable to indicate if a response was received or not
while ( ! radio.available() ){ // While nothing is received
if (micros() - started_waiting_at > 200000 ){ // If waited longer than 200ms, indicate timeout and exit while loop
timeout = true;
if ( timeout ){ // Describe the results
Serial.println(F("Failed, response timed out."));
}else{
unsigned long got_time; // Grab the response, compare, and send to debugging spew
radio.read( &got_time, sizeof(unsigned long) );
// Spew it
Serial.print(F("Sent "));
Serial.print(time);
Serial.print(F(", Got response "));
Serial.print(got_time);
Serial.print(F(", Round-trip delay "));
Serial.print(time-got_time);
Serial.println(F(" microseconds"));
// Try again 1s later
/****************** Pong Back Role ***************************/
if ( role == 0 )
if( radio.available()){
// Variable for the received timestamp
while (radio.available()) { // While there is data ready
radio.read( &got_time, sizeof(unsigned long) ); // Get the payload
radio.write( &got_time, sizeof(unsigned long) ); // Send the final one back.
radio.startListening(); // Now, resume listening so we catch the next packets.
Serial.print(F("Sent response "));
Serial.println(got_time);
/****************** Change Roles via Serial Commands ***************************/
if ( c == 'T' && role == 0 ){
role = 1; // Become the primary transmitter (ping out)
}else
if ( c == 'R' && role == 1 ){
role = 0; // Become the primary receiver (pong back)
} // Loop
However I think I'm just going to get another two modules tomorrow from my local shop (even though I'm pretty sure they get them off ebay! :P)
