system
February 16, 2013, 2:43am
1
hi im trying to make 2 arduinos communicate via nrf24l01 library but the following code is not working
arduino micro + nrf24l01
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
RF24 radio(8,7);
const uint64_t pipe = 0xE8E8F0F0E1LL;
byte a[10];
int i;
Serial.begin(57600);
printf_begin();
radio.begin();
radio.openReadingPipe(1,pipe);
radio.startListening();
radio.printDetails();
if (radio.available())
boolean done = false;
while(!done)
done = radio.read( a, 10 );
for(i=0;i<=10;i++)
Serial.println(a[i]);
Duemilanove with 168 bootloader + nrf24l01
#include <SPI.h>
#include "RF24.h"
#include "printf.h"
RF24 radio(8,7);
byte data[8];
printf_begin();
radio.begin();
radio.openWritingPipe(pipe);
int d,a;
a=1;
d=Serial.read();
switch(d)
case'a':
Serial.println("arming.....");
data[0]=0x00;
data[1]=0x00;
data[2]=0x00;
data[3]=0x00;
data[4]=0x00;
data[5]=0xFF;
data[6]=0x00;
data[7]=0x00;
Serial.println("ARMED......");
case 'b':
Serial.println("Disarming....");
data[0]=0x00;
data[1]=0x00;
data[2]=0x00;
data[3]=0x00;
data[4]=0x00;
data[5]=0x00;
data[6]=0xFF;
data[7]=0x00;
Serial.println("disarmed.......");
case 'c':
data[0]=0x00;
data[1]=0x64;
data[2]=0x00;
data[3]=0x00;
data[4]=0x00;
data[5]=0x00;
data[6]=0x00;
data[7]=0x00;
Serial.println("MED");
case 'e':
data[0]=0xFF;
data[1]=0xFF;
data[2]=0x00;
data[3]=0x00;
data[4]=0x00;
data[5]=0x00;
data[6]=0x00;
data[7]=0x00;
Serial.println("MAX");
radio.write( data, 8 );
is there any programming error or the logic is itself wrong ?
thanks in advance.
system
February 16, 2013, 2:50am
2
Have you run the sample ping sketch to confirm the hardware is working correctly?
system
February 16, 2013, 3:21am
3
yeah it is working but even if i switch off the transmitter the receiver is getting a reply
i have attached the ce and csn pin to 8 and 7 and i have declared it in the program will it affect the transmission in a negative way ?
system
February 16, 2013, 1:53pm
4
CyrilAnthony:
Huh?
Could you explain that in a bit more detail?
system
February 16, 2013, 6:38pm
5
this is a part of the output which i get irrespective of the pong back status
micro + nrf24l01
Now sending 86805...ok...Got response 4294967295, round-trip delay: 86807
Now sending 87808...ok...Got response 4294967295, round-trip delay: 87810
Now sending 88810...ok...Got response 4294967295, round-trip delay: 88813
Now sending 89814...ok...Got response 4294967295, round-trip delay: 89816
Now sending 90816...ok...Got response 4294967295, round-trip delay: 90818
Now sending 91819...ok...Got response 4294967295, round-trip delay: 91822
Now sending 92822...ok...Got response 4294967295, round-trip delay: 92824
Now sending 93825...ok...Got response 4294967295, round-trip delay: 93827
Now sending 94827...ok...Got response 4294967295, round-trip delay: 94830
Now sending 95830...ok...Got response 4294967295, round-trip delay: 95833
Now sending 96833...ok...Got response 4294967295, round-trip delay: 96835
Now sending 97836...ok...Got response 4294967295, round-trip delay: 97839
and this is what i get in the pong back side irrespective of the transmitter side
mega 1280+nrf24l01
RF24/examples/pingpair/
ROLE: Pong back
Got payload 4294967295...Sent response.
just to be sure have i wired it correctly?
nrf24l02----->Arduino
gnd----->gnd
vcc----->3.3v
ce----->9
csn----->10
sck----->13
MOSI---->11
MISO----->12
IRQ----->2
i have used RF24 library and arduino ide 1.0.3
im suspecting a radio interference
Do you have reason for connecting the IRQ? I understood it is usually unnecessary.
system
February 17, 2013, 1:10am
7
CyrilAnthony:
Does that demonstrate "even if i switch off the transmitter the receiver is getting a reply" somehow? I'm not seeing it.
system
February 17, 2013, 3:53pm
8
well i found that the problem is with my micro it is not going well with my nrf24l01 module when i test it with my mega and uno pair it is working well
I just hit the exact same issue with my Arduino Micro. And, I have a solution!
The RF24 library uses digital pins 11, 12 and 13 for SPI communication with the nRF24L01. However, on Arduino Micro, the SPI pins are different! If you check the documentation http://arduino.cc/en/Main/arduinoBoardMicro , you'll find this:
Note that the SPI pins are not connected to any of the digital I/O pins as they are on the Arduino Uno, they are only available on the ICSP connector and on the nearby pins labelled MISO, MOSI and SCK.
Essentially, instead of connecting the nRF24L01's pin 5, 6 and 7 to Arduino's 11, 12 and 13, connect it to the SCK, MOSI and MISO pins:
Arduino Micro -->
nRF24L01
SCK
5
MOSI
6
MISO
7
