Hello everyone,
I have some problems with nRF24L01 module(with antenna), I have bought two recently and I tried to connect them and transmit and receive some data but I wasn't able to do that. I'm using standard RF24 library. When I tried example "GettingStarted" I got that in response:
RF24/examples/GettingStarted
*** PRESS 'T' to begin transmitting to the other node
*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK
Now sending
failed
Failed, response timed out.
Now sending
failed
Now sending
failed
When I chose to receive I got nothing(nothing happened, just blank serial monitor).
The same thing happens for both modules connected to different arduinos. I did some research but none of the methods I found worked(adding capacitors, changing wires, or even adding radio.setAutoAck(false); into code). Below I have my connection checks(code found on some website)
Module 1:
FIRST WITH THE DEFAULT ADDRESSES after power on
Note that RF24 does NOT reset when Arduino resets - only when power is removed
If the numbers are mostly 0x00 or 0xff it means that the Arduino is not
communicating with the nRF24STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0x65646f4e31 0x4141417852
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0x65646f4e31
RX_PW_P0-6 = 0x20 0x20 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x02
RF_CH = 0x4c
RF_SETUP = 0x03
CONFIG = 0x0e
DYNPD/FEATURE = 0x00 0x00
Data Rate = 1MBPS
Model = nRF24L01+
CRC Length = 16 bits
PA Power = PA_LOWAND NOW WITH ADDRESS AAAxR 0x41 41 41 78 52 ON P1
and 250KBPS data rateSTATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
EN_AA = 0x3f
EN_RXADDR = 0x02
RF_CH = 0x4c
RF_SETUP = 0x23
CONFIG = 0x0e
Data Rate = 250KBPS
Model = nRF24L01+
PA Power = PA_LOW
Module 2:
RX_ADDR_P0-1 = 0xe7e7e7e7e7 0xc2c2c2c2c2
TX_ADDR = 0xe7e7e7e7e7
RX_PW_P0-6 = 0x00 0x00 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0e
Data Rate = 1MBPS
Model = nRF24L01+
PA Power = PA_MAXAND NOW WITH ADDRESS AAAxR 0x41 41 41 78 52 ON P1
RX_ADDR_P0-1 = 0xe7e7e7e7e7 0x4141417852
RX_PW_P0-6 = 0x00 0x20 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x27
CONFIG = 0x0e
Data Rate = 250KBPS
Model = nRF24L01+
PA Power = PA_MAX
From what I can gather, it doesn't look like it's something wrong with those modules.
One thing I noticed was that when I disconnected the CSN pin I was getting some values transmitted:
Now sending
failed
Sent 3287208, Got response 0, Round-trip delay 101584 microseconds
Now sending
Sent 4390232, Got response 0, Round-trip delay 29324 microseconds
Now sending
Sent 5420960, Got response 0, Round-trip delay 24708 microseconds
Now sending
Sent 6447064, Got response 0, Round-trip delay 21316 microseconds
What am I doing wrong? Can anyone help?
Thanks in advance.
