NRF24L01+PA+LNA modules not working
Hello, ive been trying to set up a wireless communication in between 2 arduinos and i am using a teensy 3.2 board as a sender and a arduino pro micro as a receiver. i have hooked up both arduinos as this picture shows:
--> (i have used the picture of the arduino micro to the right for both boards)
https://www.aeq-web.com/media/48572DA07072018225732.jpg
now the problem is that i dont get any output on the receiver.
I have defined the SCI pins for both boards to propper sci compatible pins and the code should also work.
I have used a propper voltage regulator for the arduino pro micro (since it only has a 5v out.)
So there really shuoldnt be any problems and they should work...
Does anyone have any ideas to why there is no communication?
Receiver code:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define SOFT_SPI_MISO_PIN 14
#define SOFT_SPI_MOSI_PIN 16
#define SOFT_SPI_SCK_PIN 15
RF24 radio(8, 9); //Define radio (CE-PIN,CSN-PIN)
const byte rxAddr[6] = "00001"; //RX adress (Same as on TX)
String received_data;
// Start the serial
Serial.println("NRF24 Receiver");
radio.begin();
radio.setPALevel(RF24_PA_LOW); // Transmit Power (MAX,HIGH,LOW,MIN)
radio.setDataRate( RF24_250KBPS ); //Transmit Speeed (250 Kbits)
radio.openReadingPipe(0, rxAddr);
radio.startListening();
if (radio.available())
char text[100] = {0}; //Buffer
radio.read(&text, sizeof(text));
received_data = String(text);
Serial.println(received_data);
delay(20);
Sender code:
#include <SPI.h>
#include <RF24.h>
#define SOFT_SPI_MISO_PIN 11
#define SOFT_SPI_MOSI_PIN 13
#define SOFT_SPI_SCK_PIN 12
const byte rxAddr[6] = "00001"; //TX adress (Same as on RX)
int counter = 0; //Count TX (Only for demo example)
RF24 radio(8, 9); //Define Radio (CE-PIN,CSN-PIN)
radio.begin();
radio.setPALevel(RF24_PA_MAX); // Transmit Power (MAX,HIGH,LOW,MIN)
radio.setRetries(15, 15);
radio.openWritingPipe(rxAddr);
// Disable Receiver
radio.stopListening();
counter++;
String str = "Send Counter: ";
str += String(counter);
int str_len = str.length() + 1;
char char_array[str_len];
str.toCharArray(char_array, str_len);
radio.write(&char_array, sizeof(char_array));
Serial.print("Actual Transmission: ");
Serial.println( char_array );
delay(250);
Antenna and voltage regulator used:
https://www.amazon.de/WayinTop-Empfänger-Transceiver-Breadboard-Kompatibel/dp/B07P95X6HM/ref=sr_1_3?__mk_de_DE=ÅMÅŽÕÑ&dchild=1&keywords=NRF24L01%2BPA%2BLNA&qid=1604582929&sr=8-3
Have a look at this Simple nRF24L01+ Tutorial.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
There is also a connection test program to check that the Arduino can talk to the nRF24 it is connected to. If the first example does not work be sure to try the connection test for both of your Arduinos. Nothing will work if the connection test fails.
A common problem with nRF24 modules is insufficient 3.3v current from the Arduino 3.3v pin. This seems to be a particular problem with the nano. The high-power nRF24s (with the external antenna) will definitely need an external power supply. At least for testing try powering the nRF24 with a pair of AA alkaline cells (3v) with the battery GND connected to the Arduino GND.
If you are using the high-power nRF24s (with the external antenna) it may help to have a distance of about 3 metres between the two nRF24s so that the signal does not overwhelm the receiver. However someone on the Forum has had them working without that separation - I don't have any personal experience with them. If you are new to nRF24s it may be better to start with a pair of low power modules with the pcb antenna.
...R
