So I tought, if it's possible to for exaple ready every 10th packet (what I mean is that print that in serial monitor, not just ignore some packets) and and the same time for example feed the servo with informations from the pakets? Or I missunderstood your quoth
Or maybe i send too much information (size not speed)?
Update: after i added delay it stopped printing artefacts. But still, it's lasting like 2 times the time before. Also resoldered the ground and vcc because I saw rotation of ground cable affected the amount of messages printed.
If you insist in using delay, I'm not into wasting my time.
There is a list of changes that should improve the performance,
you could add "don't print each packet" as a means to reduce the chance of blocking on Serial.
I do not insist in using delay, I even find it better when theres not delay at all, however it started to print "artefacts". Also I've discovered it's transmiter fault because if I reset transmiter only, receiver will print messages as normal.
There is no use in talking about symptoms of a program that has to be changed.
Change it, then we can talk about symptoms, and we will have more information,
counters for success fail and retry, a moderated packet stream,
and less output generated than Serial can handle.
Okay i did some tests. I tried sending every second paket, It did not work out. I also tried sending every third paket, it lasted less than every second paket. So less flow in pakets doesn't mean lasting longer. I was thinking it might be the data rate which was 250 kbps. I turned it up, but it turned out to be automatic so I just had bigger flow. It did not impact the time it was working. turning off dynamic payloads only affected it by small additional amount of time. My dad told me to delete part of code for example gyro and test it. I did as he told me, I deleted the gyro part and now it has been working for nearly an hour. I'm thinking about changing the library for MPU6050.
transmiter:
#include <nRF24L01.h>
#include <RF24.h>
#include <TinyGPS++.h>
RF24 radio(9, 10); // Utwórz obiekt RF24 i zdefiniuj piny CE i CSN
const byte address[6] = "00001"; // Adres do komunikacji (musi być taki sam w odbiorniku)
TinyGPSPlus gps;
struct SensorData {
uint8_t packetNum;
double latitude;
double longitude;
double altitude;
double speed;
SensorData sensorData;
radio.begin(); // Inicjalizuj moduł nRF24L01
radio.openWritingPipe(address); // Ustaw adres nadawczy
radio.setPALevel(RF24_PA_LOW); // Ustaw moc nadajnika na niską
radio.setDataRate(RF24_250KBPS); // Ustaw szybkość transmisji danych na 250 kbps
radio.enableDynamicPayloads(); // Włącz dynamiczne pakiety
// Odczytaj dane z GPS
while (Serial.available() > 0) {
if (gps.encode(Serial.read())) {
if (gps.location.isUpdated()) {
sensorData.latitude = gps.location.lat();
sensorData.longitude = gps.location.lng();
sensorData.altitude = gps.altitude.meters();
sensorData.speed = gps.speed.kmph();
// Zwiększ numer pakietu
static uint8_t packetNum = 0;
sensorData.packetNum = packetNum;
// Wysyłaj dane
radio.write(&sensorData, sizeof(sensorData));
// Wyświetl dane na Serial Monitorze
Serial.print("Latitude: ");
Serial.print(sensorData.latitude, 8);
Serial.print(", Longitude: ");
Serial.print(sensorData.longitude, 8);
Serial.print(", Altitude: ");
Serial.print(sensorData.altitude);
Serial.print(", Speed: ");
Serial.println(sensorData.speed);
packetNum++;
This is the code that im using right now for an hour, I know it does enable dynamic payloads. Diffrence between old struct size and the one im using now is 6 bytes. Also, the artefacts are only visible on the transmiter (chinese uno), I guess its just some problem with processing the data on worse processor.
dynamicPayloads is useful, but here it worsens you problem slightly,
because you still send on each loop, unmoderateted.
The lower data rate could extend your range.
You still do not care for the transmit results.
You still have no data regarding success, fail or retries.
You still have no data regarding the last successful reception.
double is identical to float on AVRs,
so using double will be problematic if one of your nodes is a 32 bit processor,
and just silly if you don't.
You switched both nodes to RF24_PA_LOW,
maybe switch only the high power module could work better.
It is still true because the transmiter will receive data regard movement of the servos onboard. So I do understand your disapointment that I'm so unproffesional.
would do the job, look cleaner and has less chance to block.
I would also note, whether there was a new fix,
which could also be a flag in the transmit packet.
Why don't you use the packetNumber inside the transmit structure directly?
Well, first im trying to make it so "drone" sends data about it location and rotation. However at the end my plans are that receiver and transmiter will act as transceiver. Because one needs to send it's location and other has to send for example how should flaps act on wing (servo). So I would have to disable something and then enable it again. However I did put radio.stopListening(); in transmiter for now
I do not understand why are you disappointed, im not trying to solve problem Y. I'm trying to solve problem X right now. I want to understand why it stops working and fix it. The plan i told you is far away from being started.
#include <RF24.h>
#include <SoftwareSerial.h>
TinyGPSPlus gps;
RF24 radio(9, 10);
SoftwareSerial gpsSerial(2, 3);
struct SensorData {
uint8_t packetNum;
double latitude;
double longitude;
double altitude;
double speed;
unsigned long lastPacketTime = 0;
unsigned long totalPacketTime = 0;
unsigned long packetCount = 0;
unsigned long failedPackets = 0;
unsigned long retries = 0;
unsigned long successes = 0;
gpsSerial.begin(9600);
radio.begin();
// Ustaw liczbę prób ponownych na 15
radio.setRetries(15, 15);
while (gpsSerial.available() > 0) {
if (gps.encode(gpsSerial.read())) {
// Wysyłaj dane
if (radio.write(&sensorData, sizeof(sensorData))) {
successes++;
// Oblicz czas pomiędzy pakietami
if (packetNum > 0) {
unsigned long currentPacketTime = millis() - lastPacketTime;
totalPacketTime += currentPacketTime;
packetCount++;
retries += 15; // Użyj wartości ustawionej wcześniej
else {
failedPackets++;
lastPacketTime = millis();
// Wyświetl statystyki
Serial.print("Failed Packets: ");
Serial.println(failedPackets);
Serial.print("Retries: ");
Serial.println(retries);
Serial.print("Successful Packets: ");
Serial.println(successes);
Serial.print("Average Packet Time: ");
Serial.print(totalPacketTime / packetCount);
Serial.println(" ms");
packetNum++;
Okay the test lasted for 10 minutes. successful 34314 pakets, Retries 51410, failed 0 average time between pakets is 16ms. Are these results even possible? It seems weird theres 0 failed, and also it's weird how much retries there are.
Long time no see
I figured out what's wrong and it turned out to be very common problem. It's just that Mpu6050 freezes because of I2C problem . When its unplugged everything work's just fine. Thanks for all the help.
