Hello everyone,
I am trying to make a wireless gyroscopic mouse with mpu 6050 and nrf24l01, arduino. I am having trouble programing it. I don't know how to store the x,y,z values and send it through the nrf24l01. Can anyone help me and fix my code. I have few errors in my code and I don't know how to fix it can someone tell me so I can fix it.
Thank you
reciever_gyroscopic_mouse_code.ino (627 Bytes)
transmitter_gyroscopic_mouse_code.ino (1.72 KB)
Short programs should be included in your Post using the code button </> so people don't have to download them
Transmitter
#include <Wire.h>
#include <I2Cdev.h>
#include <MPU6050.h>
#include <Mouse.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
MPU6050 mpu;
int16_t ax, ay, az, gx, gy, gz;
int16_t accx, accy, accz;
int vx, vy;
float angle;
int readIndex = 0;
const int numReadings = 20;
int angleReadings[numReadings];
int total = 0;
float averageAngle = 0.0;
int oldZ = 0;
int newZ = 0;
int data [1];
RF24 radio(7, 8); // CE, CSN
const byte addresses[][6] = {"00001", "00002"};
boolean buttonState = 0;
radio.begin();
radio.openWritingPipe(addresses[1]); // 00002
radio.openReadingPipe(1, addresses[0]); // 00001
radio.setPALevel(RF24_PA_MIN);
Wire.begin();
mpu.initialize();
if (!mpu.testConnection()) {
while (1);
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
angleReadings[thisReading] = 0;
total = total - angleReadings[readIndex];
angleReadings[readIndex] = angle;
total = total + angleReadings[readIndex];
readIndex = readIndex + 1;
if (readIndex >= numReadings) {
readIndex = 0;
//accx, accy, accz;
mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
mpu.getAcceleration(&accx, &accy, &accz);
oldZ = newZ;
vx = (gx + 300) / 150; // "+300" because the x axis of gyroscope give values about -350 while it's not moving. Change this value if you get something different using the TEST code, chacking if there are values far from zero.
vy = -(gz - 100) / 150; // same here about "-100"
data [1] = Mouse.move(vx, vy);
radio.stopListening();
radio.write(data, sizeof(data));
angle = atan2((float) ay, (float) ~ax) * (180.0 / PI);
delay(20);
Receiver
#include <Wire.h>
#include <I2Cdev.h>
#include <Mouse.h>
#include <SPI.h>
#include <RF24.h>
Servo myServo;
radio.begin();
radio.openWritingPipe(addresses[0]); // 00001
radio.openReadingPipe(1, addresses[1]); // 00002
delay(5);
radio.startListening();
if ( radio.available()) {
while (radio.available()) {
radio.read(data, sizeof(data));
delay(5);
...R
You seem to be very mixed up.
What is the purpose of sending data - the receiver seems to do nothing with it? And it has no definition for the variable "data"
This (in the transmitter) seems all wrong
AFAIK Mouse.move() sends data to the PC over the USB cable.
Note also that referencing data[1] is incorrect. It should be data[0] as you have created an array with only 1 element.
I suspect what you want to do is send the X Y and Z values to the other Arduino so that it can call Mouse.move() - but I may be wrong. And if I am correct you should send all three values in an array in a single nRF24 message.
Have a look at this Simple nRF24L01+ Tutorial.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
There is also a connection test program to check that the Arduino can talk to the nRF24 it is connected to.
A common problem with nRF24 modules is insufficient 3.3v current from the Arduino 3.3v pin. This seems to be a particular problem with the nano. The high-power nRF24s (with the external antenna) will definitely need an external power supply. At least for testing try powering the nRF24 with a pair of AA alkaline cells (3v) with the battery GND connected to the Arduino GND.
If you are using the high-power nRF24s (with the external antenna) make sure there is sufficient distance between the two nRF24s so that the signal does not overwhelm the receiver - try 3 metres separation. If you are new to nRF24s it may be better to start with a pair of low power modules with the pcb antenna.
...R
Robin 2, thank you so much for your help and I will take a look at the tutorial.
I came up with the final code do you guys think it would work before I test it?
tranmitter code:
#include <Wire.h>
#include <I2Cdev.h>
#include <Mouse.h>
#include <SPI.h>
#include <RF24.h>
MPU6050 mpu;
int vx, vy;
float angle;
int readIndex = 0;
int total = 0;
int oldZ = 0;
int newZ = 0;
int y, x;
radio.begin();
Wire.begin();
mpu.initialize();
while (1);
readIndex = 0;
//accx, accy, accz;
oldZ = newZ;
x = vx;
y = vy;
typedef struct
int x;
int y;
controlDef;
controlDef data;
radio.write(&data, sizeof(data));
delay(20);
reciever code:
#include <Wire.h>
#include <I2Cdev.h>
#include <Mouse.h>
#include <SPI.h>
#include <RF24.h>
radio.begin();
delay(5);
int data = 0;
int x = 0;
int y = 0;
radio.read(&data, sizeof(data));
Mouse.move(x, y);
delay(5);
ardumaster112:
Wrong order. Test first, then ask questions.
If it works you may not need to ask a question. If it does not work you will have a lot of extra information to give us about what actually happens.
The Arduino system is great for learning-by-doing.
...R
