Hi all,
this is my first question, I hope I choose the topic right.
I arrange this 2 circuits:
Transmitter Circuit: Arduino Uno, nRF24L01+PA+LNA, BMP280
Receiver Circuit: Arduino Uno, nRF24L01+PA+LNA, LCD I2C 20x4
I can see BMP 280 works at the transmitter circuit from the serial monitor.
The receiver circuit should have no problem too... But, the LCD in Receiver circuit can't get the data from BMP280:
This is the transmitter code:
//Include Libraries
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Adafruit_BMP280.h>
Adafruit_BMP280 bmp; // I2C Interface
//create an RF24 object
RF24 radio(9, 10); // CE, CSN
//struct MyData {
// float a;
// float t;
// float p;
//MyData data;
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 2000;
//const byte address[6] = "00001"; //channel
const byte slaveAddress[5] = {'R','x','A','A','A'};
while (!Serial);
Serial.println("nRF24L01 and BMP280 Project: Tx");
Serial.println("with Arduino UNO R3 by Glanz and Freya");
if (!bmp.begin()) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring!"));
while (1);
/* Default settings from datasheet. */
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL,
Adafruit_BMP280::SAMPLING_X2,
Adafruit_BMP280::SAMPLING_X16,
Adafruit_BMP280::FILTER_X16,
Adafruit_BMP280::STANDBY_MS_500);
//Setup the transmitter
radio.begin();
radio.setDataRate(RF24_1MBPS);
radio.setRetries(3,5);
//radio.openWritingPipe(address);
radio.openWritingPipe(slaveAddress);
radio.setPALevel(RF24_PA_LOW); // set the Power Amplifier level
// if using a higher level it is recommended to
// use a bypass capacitors across GND and 3.3V
// to have more stable voltage while operating.
radio.stopListening();
//radio.setAutoAck(false);
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis) {
send();
prevMillis = millis();
int i = 1;
void send() {
while (i>0) {
//The "975.7" is the pressure(hPa) at sea level in day in your region
float temperatureValue = bmp.readTemperature();
float pressureValue = bmp.readPressure()/100;
float altitudeValue = bmp.readAltitude(975.7);
if (isnan(temperatureValue) || isnan(altitudeValue) || isnan(pressureValue)){
Serial.println(F("Failed to read from BMP280 sensor!"));
return;
else {
Serial.print(F("# "));
Serial.print(i);
Serial.print(F("Temperature = "));
Serial.print(temperatureValue);
Serial.println(" °C");
Serial.print(F("Pressure = "));
Serial.print(pressureValue);
Serial.println(" hPa");
Serial.print(F("Approx altitude = "));
Serial.print(altitudeValue);
Serial.println(" m");
float dataToSend[3];
dataToSend[0] = temperatureValue;
dataToSend[1] = pressureValue;
dataToSend[2] = altitudeValue;
radio.write(&dataToSend, sizeof(dataToSend));
i++;
delay(2000);
the Receiver code:
//Include Libraries
#include <SPI.h>
#include <RF24.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
float temperatureValue;
float pressureValue;
float altitudeValue;
bool newData = false;
while (!Serial);
Serial.println("nRF24L01 and BMP280 Project: Rx");
lcd.init();
lcd.clear();
lcd.backlight();
lcd.clear();
lcd.print("Glanz");
// Setup the receiver
radio.begin();
//radio.setPALevel(RF24_PA_LOW);
radio.openReadingPipe(1, thisSlaveAddress);
radio.startListening();
//set the address
//radio.setDataRate(RF24_250KBPS);
int i = 1;
void loop(){
while (i > 0) {
getData();
showData();
i++;
delay(2000);
void getData(){
if (radio.available()){
float dataToReceive[3];
radio.read(&dataToReceive, sizeof(dataToReceive));
temperatureValue = dataToReceive[0];
pressureValue = dataToReceive[1];
altitudeValue = dataToReceive[2];
newData = true;
void showData(){
if (newData == true){
Serial.print("Data received\t");
Serial.print(i);
lcd.setCursor(6,0);
lcd.print("#: "),lcd.print(i),lcd.print(" "),lcd.print(altitudeValue),lcd.print(" m");
lcd.setCursor(6,1), lcd.print(temperatureValue),lcd.print(" C");
lcd.setCursor(6,2), lcd.print(pressureValue),lcd.print(" hPa");
newData = false;
delay(2000);
