Nunchuck not working with arduino
Hi, i bought a cheap ebay nunchuck, and i never gor it to work, i received data through the serial port with it unconnected but as soon as i plugged it in the i2c bus it stops transmitting, i thought it was because it was a cheap nunchuck, so i bought a new ''real'' one by nintendo, but it still doesn't work!! :cry:
i'm sure it's wired correctly, it's like this:
http://www.hardwarebook.info/Wiimote_Expansion_Port
the code i'm using is this:
 * NunchuckPrint
 * 2007 Tod E. Kurt, http://todbot.com/blog/
 * The Wii Nunchuck reading code is taken from Windmeadow Labs
 *   http://www.windmeadow.com/node/42
#include <Wire.h>
  Serial.begin(19200);
  nunchuck_setpowerpins(); // use analog pins 2&3 as fake gnd & pwr
  nunchuck_init(); // send the initilization handshake
  Serial.print ("Finished setup\n");
  nunchuck_get_data();
  nunchuck_print_data();
  delay(100);
// Nunchuck functions
static uint8_t nunchuck_buf[6];   // array to store nunchuck data,
// Uses port C (analog in) pins as power & ground for Nunchuck
static void nunchuck_setpowerpins()
#define pwrpin PORTC3
#define gndpin PORTC2
    DDRC |= _BV(pwrpin) | _BV(gndpin);
    PORTC &=~ _BV(gndpin);
    PORTC |=  _BV(pwrpin);
    delay(100);  // wait for things to stabilize
// initialize the I2C system, join the I2C bus,
// and tell the nunchuck we're talking to it
void nunchuck_init()
  Wire.begin();                      // join i2c bus as master
  Wire.beginTransmission(0x52);      // transmit to device 0x52
  Wire.send(0x40);            // sends memory address
  Wire.send(0x00);            // sends sent a zero.
  Wire.endTransmission();      // stop transmitting
// Send a request for data to the nunchuck
// was "send_zero()"
void nunchuck_send_request()
  Wire.send(0x00);            // sends one byte
// Receive data back from the nunchuck,
int nunchuck_get_data()
    int cnt=0;
    Wire.requestFrom (0x52, 6);      // request data from nunchuck
    while (Wire.available ()) {
      // receive byte as an integer
      nunchuck_buf[cnt] = nunchuk_decode_byte(Wire.receive());
      cnt++;
    nunchuck_send_request();  // send request for next data payload
    // If we recieved the 6 bytes, then go print them
    if (cnt >= 5) {
     return 1;   // success
    return 0; //failure
// Print the input data we have recieved
// accel data is 10 bits long
// so we read 8 bits, then we have to add
// on the last 2 bits.  That is why I
// multiply them by 2 * 2
void nunchuck_print_data()
  static int i=0;
  int joy_x_axis = nunchuck_buf[0];
  int joy_y_axis = nunchuck_buf[1];
  int accel_x_axis = nunchuck_buf[2]; // * 2 * 2;
  int accel_y_axis = nunchuck_buf[3]; // * 2 * 2;
  int accel_z_axis = nunchuck_buf[4]; // * 2 * 2;
  int z_button = 0;
  int c_button = 0;
  // byte nunchuck_buf[5] contains bits for z and c buttons
  // it also contains the least significant bits for the accelerometer data
  // so we have to check each bit of byte outbuf[5]
  if ((nunchuck_buf[5] >> 0) & 1)
    z_button = 1;
  if ((nunchuck_buf[5] >> 1) & 1)
    c_button = 1;
  if ((nunchuck_buf[5] >> 2) & 1)
    accel_x_axis += 2;
  if ((nunchuck_buf[5] >> 3) & 1)
    accel_x_axis += 1;
  if ((nunchuck_buf[5] >> 4) & 1)
    accel_y_axis += 2;
  if ((nunchuck_buf[5] >> 5) & 1)
    accel_y_axis += 1;
  if ((nunchuck_buf[5] >> 6) & 1)
    accel_z_axis += 2;
  if ((nunchuck_buf[5] >> 7) & 1)
    accel_z_axis += 1;
  Serial.print(i,DEC);
  Serial.print("\t");
  Serial.print("joy:");
  Serial.print(joy_x_axis,DEC);
  Serial.print(",");
  Serial.print(joy_y_axis, DEC);
  Serial.print("  \t");
  Serial.print("acc:");
  Serial.print(accel_x_axis, DEC);
  Serial.print(",");
  Serial.print(accel_y_axis, DEC);
  Serial.print(",");
  Serial.print(accel_z_axis, DEC);
  Serial.print("\t");
  Serial.print("but:");
  Serial.print(z_button, DEC);
  Serial.print(",");
  Serial.print(c_button, DEC);
  Serial.print("\r\n");  // newline
  i++;
// Encode data to format that most wiimote drivers except
// only needed if you use one of the regular wiimote drivers
char nunchuk_decode_byte (char x)
  x = (x ^ 0x17) + 0x17;
  return x;
it just doesn't work no matter what... thanks
I failed, the wiring is actually this:
CODE FOR CHEAP EBAY NUNCHUCK
 * NunchuckPrint
#include <Wire.h>
uint8_t ctrlr_type[6];
  delay(100);
byte cnt;
Wire.begin();
// init controller
delay(1);
Wire.beginTransmission(0x52);      // device address
Wire.send(0xF0);                    // 1st initialisation register
Wire.send(0x55);                    // 1st initialisation value
delay(1);
Wire.send(0xFB);                    // 2nd initialisation register
Wire.send(0x00);                    // 2nd initialisation value
delay(1);
// read the extension type from the register block
Wire.send(0xFA);                    // extension type register
Wire.requestFrom(0x52, 6);               // request data from controller
for (cnt = 0; cnt < 6; cnt++) {
    if (Wire.available()) {
        ctrlr_type[cnt] = Wire.receive(); // Should be 0x0000 A420 0101 for Classic Controller, 0x0000 A420 0000 for nunchuck
delay(1);
// send the crypto key (zeros), in 3 blocks of 6, 6 & 4.
Wire.send(0xF0);                    // crypto key command register
Wire.send(0xAA);                    // sends crypto enable notice
delay(1);
Wire.send(0x40);                    // crypto key data address
    Wire.send(0x00);                    // sends 1st key block (zeros)
for (cnt = 6; cnt < 12; cnt++) {
    Wire.send(0x00);                    // sends 2nd key block (zeros)
for (cnt = 12; cnt < 16; cnt++) {
    Wire.send(0x00);                    // sends 3rd key block (zeros)
delay(1);
// end device init
    int cnt=0;
      cnt++;
    if (cnt >= 5) {
    return 0; //failure
  static int i=0;
  int z_button = 0;
  int c_button = 0;
    z_button = 1;
    c_button = 1;
    accel_x_axis += 2;
    accel_x_axis += 1;
    accel_y_axis += 2;
    accel_y_axis += 1;
    accel_z_axis += 2;
    accel_z_axis += 1;
  Serial.print("\t");
  Serial.print(",");
  Serial.print(",");
  Serial.print(",");
  Serial.print("\t");
  Serial.print(",");
  i++;
  return x;
CODE FOR GENUINE NINTENDO NUNCHUCK
 * NunchuckPrint
#include <Wire.h>
  delay(100);
    int cnt=0;
      cnt++;
    if (cnt >= 5) {
    return 0; //failure
  static int i=0;
  int z_button = 0;
  int c_button = 0;
    z_button = 1;
    c_button = 1;
    accel_x_axis += 2;
    accel_x_axis += 1;
    accel_y_axis += 2;
    accel_y_axis += 1;
    accel_z_axis += 2;
    accel_z_axis += 1;
  Serial.print("\t");
  Serial.print(",");
  Serial.print(",");
  Serial.print(",");
  Serial.print("\t");
  Serial.print(",");
  i++;
  return x;
I used these functions here:
“WiiChuck” Wii Nunchuck Adapter Available – todbot blog
You can also connect the 4 wires from the nunchuck cable directly to the analog ports A2 - A5.
A2: white
A3: red
A4: green
A5: yellow
sorry sir .. you don'think that the correct wiring i in pin 2,3,4,5 cable black,red green and blue? and leave the white and yellow??
:slight_smile:
"You can also connect the 4 wires from the nunchuck cable directly to the analog ports A2 - A5. "
The other analog pins are used up by sensors...
What do you mean tatranky?
