Obstacle avoiding robot ...randoms
i want the robot...when faces obstacle...turn right or left randomly///....but my code is not working...i am using arduino nano .......and l293d ic...here is my code..plz give me corrections..
long randNumber;
const int EchoPin = 8;
const int TriggerPin = 6;
float Duration;
float Distance;
const int LeftMotorICpin1 = 2;
const int LeftMotorICpin2 = 4;
const int RightMotorICpin1 = 7;
const int RightMotorICpin2 = 3;
//**********************VOID SETUP***************************//
  Serial.begin(9600);//Serial communication bandwith rate : 9600...if your computers bandwith is diffrent
  //            |_________
  //you can edit it from here**
  pinMode(LeftMotorICpin1, OUTPUT);  // Digital pin 10 set as output Pin
  pinMode(LeftMotorICpin2, OUTPUT);  // Digital pin 11 set as output Pin
  pinMode(RightMotorICpin1, OUTPUT);  // Digital pin 12 set as output Pin
  pinMode(RightMotorICpin2, OUTPUT);  // Digital pin 13 set as output Pin
  pinMode(TriggerPin, OUTPUT);
  pinMode(EchoPin, INPUT);
  randomSeed(analogRead(0));
//************************VOID lOOP*****************************//
  digitalWrite(TriggerPin, LOW);
  delay(2);
  digitalWrite(TriggerPin, HIGH);
  delayMicroseconds(10);
  Duration = pulseIn(EchoPin, HIGH);
  Distance = (Duration * 0.034) / 2;
  randNumber = random(2);
  Serial.println(randNumber);
  delay(50);
  if (Distance >= 40) // Forward
    digitalWrite(LeftMotorICpin1, HIGH);
    digitalWrite(LeftMotorICpin2, LOW);
    digitalWrite(RightMotorICpin1, HIGH);
    digitalWrite(RightMotorICpin2, LOW);
  if ( Distance < 20) // Backward
    digitalWrite(LeftMotorICpin1, LOW);
    digitalWrite(LeftMotorICpin2, HIGH);
    digitalWrite(RightMotorICpin1, LOW);
    digitalWrite(RightMotorICpin2, HIGH);
  if (randNumber = 0 & Distance < 40 & Distance >= 20) //Right
  if (randNumber = 1 & Distance < 40 & Distance >= 20) //Left
= for assignment,== for comparison.
&& is for boolean logic (e.g. combining comparisons), & is for bitwise and'ing of all the bits in a variable.
If you get confused, just use the keyword "and" instead of "&&".
  if (randNumber == 1 and Distance < 40 and Distance >= 20) //Left
The main reason it matters, is because of operator precedence.
but now...everything is working fine...but my robot cant turn neither left nor right...i mean it turns a bit left then a bit right.....what do i do?,,,,should i add delay in the random numbers generation?
