I am working on a new project to detect obstacle , and after detecting it will turn off the device. So for this purpose i am using Tof10120 , initially i was thinking abouT PIR sensor but ambient will be warm so used this instead but the problem is now after plugging to Arduino in my serial monitor it is showing 0mm , i have found the code in dronebot workshop forum, kindly help.
TOF10120 Distance Sensor Demonstration
TOF10120-Demo.ino
Demonstrates use of TOF10120 Distance Sensor
Adapted from code from SurtrTech
Displays results on Serial Monitor
DroneBot Workshop 2019
https://dronebotworkshop.com
#include <Wire.h>
unsigned char ok_flag;
unsigned char fail_flag;
unsigned short lenth_val = 0;
unsigned char i2c_rx_buf[16];
unsigned char dirsend_flag=0;
Wire.begin();
Serial.begin(9600,SERIAL_8N1);
printf_begin();
int x=ReadDistance();
Serial.print(x);
Serial.println(" mm");
int serial_putc( char c, struct __file * )
Serial.write( c );
return c;
void printf_begin(void)
fdevopen( &serial_putc, 0 );
void SensorRead(unsigned char addr,unsigned char* datbuf,unsigned char cnt)
unsigned short result=0;
// step 1: instruct sensor to read echoes
Wire.beginTransmission(82); // transmit to device #82 (0x52)
// the address specified in the datasheet is 164 (0xa4)
// but i2c adressing uses the high 7 bits so it's 82
Wire.write(byte(addr)); // sets distance data address (addr)
Wire.endTransmission(); // stop transmitting
// step 2: wait for readings to happen
delay(1); // datasheet suggests at least 30uS
// step 3: request reading from sensor
Wire.requestFrom(82, cnt); // request cnt bytes from slave device #82 (0x52)
// step 5: receive reading from sensor
if (cnt <= Wire.available()) { // if two bytes were received
*datbuf++ = Wire.read(); // receive high byte (overwrites previous reading)
*datbuf++ = Wire.read(); // receive low byte as lower 8 bits
int ReadDistance(){
SensorRead(0x00,i2c_rx_buf,2);
lenth_val=i2c_rx_buf[0];
lenth_val=lenth_val<<8;
lenth_val|=i2c_rx_buf[1];
delay(300);
return lenth_val;
