Odd error message
Started to get a very cryptic message
Waiting for gdb server to start...[2023-04-22T13:47:00.003Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session connected. You can switch to "DEBUG CONSOLE" to see GDB interactions.
"C:\\Users\\rtcno00225\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\openocd\\0.10.0-arduino7/bin/openocd" -c "gdb_port 50000" -c "tcl_port 50001" -c "telnet_port 50002" -s "d:\\Arduino sketches an libs\\GPSLocation" -f "C:/Program Files/Arduino IDE/resources/app/plugins/cortex-debug/extension/support/openocd-helpers.tcl" -f "C:\\Users\\rtcno00225\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.13/variants/mkr1000/openocd_scripts/arduino_zero.cfg"
Open On-Chip Debugger 0.10.0+dev-gf0767a31 (2018-06-11-13:36)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.org/doc/doxygen/bugs.html
CDRTOSConfigure
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
none separate
adapter speed: 400 kHz
cortex_m reset_config sysresetreq
Info : Listening on port 50001 for tcl connections
Info : Listening on port 50002 for telnet connections
Error: unable to find CMSIS-DAP device
[2023-04-22T13:47:00.383Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session closed
GDB server session ended. This terminal will be reused, waiting for next session to start...
Anyone ?
Hi @Ballscrewbob. What were you doing when you saw the error message?
This error would normally occur when the user clicks the "Start Debugging" button without a debug probe connected between the computer and the MKR1000 board:
That was it !
Not 100% up to speed on 2.x
Though it may just parse the code.
OK, great. I'm glad we identified the cause. In case you haven't seen it already, I'll share the link to some more information about the Arduino IDE's integrated sketch debugger feature:
It is necessary to connect a CMSIS-DAP compliant or J-Link debug probe to the SWD header on the MKR1000 board in order to use the feature.
If you have an Arduino Zero board, that board has an on-board debug probe so is more convenient to use with the debugger.
