OLED display bitmap mess up
Hello,
I want to let my adafruit ssd1306 to show logo, but it just show some points that messed. My OLED
SDA and SCL pin is on 13 and 13, not on A4 and A5, and it display text very well. Here's my code
#include <Adafruit_ssd1306syp.h>
#define SDA_PIN 12
#define SCL_PIN 13
Adafruit_ssd1306syp display(SDA_PIN,SCL_PIN);
static const unsigned char PROGMEM cloud_logo_bmp[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x30, 0x60, 0xC0, 0x80,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0x71, 0x10, 0x08, 0x0C, 0x04,
0x06, 0x02, 0x02, 0x02, 0x02, 0x02, 0x06, 0x04, 0x0C, 0x08, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x03, 0x03, 0x02,
0x06, 0x04, 0x80, 0xF8, 0x0E, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x07, 0x00, 0xC0, 0xF0, 0x18, 0x08, 0x08, 0xD8, 0x70,
0x00, 0xC0, 0xF8, 0x00, 0x00, 0xC0, 0xF0, 0x30, 0x00, 0x80, 0xE0, 0x30, 0x18, 0x88, 0xF8, 0xFE,
0x03, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0x40, 0x60, 0x30, 0x10, 0x18, 0x08, 0x00, 0x03, 0x1F,
0x70, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0xC0, 0x40, 0x60, 0x20,
0x30, 0x10, 0x13, 0x30, 0x60, 0xC1, 0x83, 0x02, 0x02, 0x03, 0x81, 0xC0, 0x60, 0x31, 0x33, 0x32,
0x63, 0xC1, 0x83, 0x83, 0xC0, 0x41, 0x63, 0x22, 0x23, 0x61, 0xC1, 0x83, 0x03, 0x00, 0x00, 0x00,
0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01,
0x03, 0x02, 0x02, 0x03, 0x03, 0x01
  display.initialize();
  display.clear();
  display.drawBitmap(20, 10, cloud_logo_bmp, 60, 35, 1);
  display.update();
  display.clear();
Thanks:)!
I know nothing about the device or the library so cannot help with your problem, but I do know that you don't need display.clear() twice in loop() on what are effectively consecutive lines of code because of how loop() works.
hi,here's my library, thanks.
ssd1306syp.h
#ifndef _IIC_SSD1306SYP_H_
#define _IIC_SSD1306SYP_H_
#if ARDUINO >= 100
 #include "Arduino.h"
#else
 #include "WProgram.h"
#endif
#include <Adafruit_GFX.h>
using namespace std;
#define BLACK 0
#define WHITE 1
//common parameters
#define SSD1306_WIDTH 128
#define SSD1306_HEIGHT 64
#define SSD1306_FBSIZE 1024 //128x8
#define SSD1306_MAXROW 8
//command macro
  #define SSD1306_CMD_DISPLAY_OFF 0xAE//--turn off the OLED
  #define SSD1306_CMD_DISPLAY_ON 0xAF//--turn on oled panel
class Adafruit_ssd1306syp : public Adafruit_GFX{
public:
	Adafruit_ssd1306syp(int sda,int scl);
	~Adafruit_ssd1306syp();
	//initialized the ssd1306 in the setup function
	virtual bool initialize();
	//update the framebuffer to the screen.
	virtual void update();
	//totoally 8 rows on this screen in vertical direction.
	virtual void updateRow(int rowIndex);
	virtual void updateRow(int startRow, int endRow);
	//draw one pixel on the screen.
	virtual void drawPixel(int16_t x, int16_t y, uint16_t color);
	//clear the screen
	void clear(bool isUpdateHW=false);
protected:
	//write one byte to the screen.
	void writeByte(unsigned char  b);
	void writeCommand(unsigned char  cmd);
	//atomic control function
	void startIIC();//turn on the IIC
	void stopIIC();//turn off the IIC.
	void startDataSequence();
protected:
	int m_sda;
	int m_scl;
	unsigned char* m_pFramebuffer;//the frame buffer for the adafruit gfx. size=64x8 bytes
#endif
ssd1306syp.cpp
[#include "Adafruit_ssd1306syp.h"
Adafruit_ssd1306syp::Adafruit_ssd1306syp(int sda, int scl):
Adafruit_GFX(SSD1306_WIDTH,SSD1306_HEIGHT)
	m_sda = sda;
	m_scl = scl;
	m_pFramebuffer = 0;
Adafruit_ssd1306syp::~Adafruit_ssd1306syp()
	//release the memory.
	if(m_pFramebuffer){
		free(m_pFramebuffer);
bool Adafruit_ssd1306syp::initialize()
	//setup the pin mode
	pinMode(m_sda,OUTPUT);
	pinMode(m_scl,OUTPUT);
	//malloc the framebuffer.
	m_pFramebuffer = (unsigned char*)malloc(SSD1306_FBSIZE);
	if(m_pFramebuffer == 0){
		return false;
	memset(m_pFramebuffer,0,SSD1306_FBSIZE);//clear it.
	//write command to the screen registers.
	writeCommand(SSD1306_CMD_DISPLAY_OFF);//display off
	writeCommand(0x00);//Set Memory Addressing Mode
	writeCommand(0x10);//00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
	writeCommand(0x40);//Set Page Start Address for Page Addressing Mode,0-7
	writeCommand(0xB0);//Set COM Output Scan Direction
	writeCommand(0x81);//---set low column address
	writeCommand(0xCF);//---set high column address
	writeCommand(0xA1);//--set start line address
	writeCommand(0xA6);//--set contrast control register
	writeCommand(0xA8);
	writeCommand(0x3F);//--set segment re-map 0 to 127
	writeCommand(0xC8);//--set normal display
	writeCommand(0xD3);//--set multiplex ratio(1 to 64)
	writeCommand(0xD5);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
	writeCommand(0x80);//-set display offset
	writeCommand(0xD9);//-not offset
	writeCommand(0xF1);//--set display clock divide ratio/oscillator frequency
	writeCommand(0xDA);//--set divide ratio
	writeCommand(0x12);//--set pre-charge period
	writeCommand(0xDB);//
	writeCommand(0x40);//--set com pins hardware configuration
	writeCommand(0x8D);//--set vcomh
	writeCommand(0x14);//0x20,0.77xVcc
	writeCommand(0xAF);//--set DC-DC enable
	writeCommand(SSD1306_CMD_DISPLAY_ON);//--turn on oled panel
	delay(10);//wait for the screen loaded.
	return true;
void Adafruit_ssd1306syp::clear(bool isUpdateHW)
	memset(m_pFramebuffer,0,SSD1306_FBSIZE);//clear the back buffer.
	if(isUpdateHW) update();//update the hw immediately
void Adafruit_ssd1306syp::writeCommand(unsigned char cmd)
	startIIC();
	writeByte(0x78);  //Slave address,SA0=0
	writeByte(0x00);	//write command
	writeByte(cmd);
	stopIIC();
void Adafruit_ssd1306syp::writeByte(unsigned char b)
	unsigned char i;
	for(i=0;i<8;i++)
		if((b << i) & 0x80){
			digitalWrite(m_sda, HIGH);
		}else{
			digitalWrite(m_sda, LOW);
		digitalWrite(m_scl, HIGH);
		digitalWrite(m_scl, LOW);
		//    IIC_Byte<<=1;
void Adafruit_ssd1306syp::startIIC()
void Adafruit_ssd1306syp::stopIIC()
void Adafruit_ssd1306syp::drawPixel(int16_t x, int16_t y, uint16_t color)
	unsigned char row;
	unsigned char offset;
	unsigned char  preData;//previous data.
	unsigned char val;
	int16_t  index;
	if ((x < 0) || (x >= width()) || (y < 0) || (y >= height()) || ( m_pFramebuffer==0))	return;
	//get the previous data;
	row = y/8;
	offset =y%8;
	index = row*width() + x;
	preData = m_pFramebuffer[index];
	//set pixel;
	val = 1<<offset;
	if(color!=0)
	{//white! set bit.
		m_pFramebuffer[index] = preData | val;
	}else
	{//black! clear bit.
		m_pFramebuffer[index] = preData & (~val);
void Adafruit_ssd1306syp::startDataSequence()
	startIIC();
	writeByte(0x78);
	writeByte(0x40);	//write data
void Adafruit_ssd1306syp::update()
#if 1
	unsigned int  i=0;
	unsigned char m,n;
	for(m=0;m<8;m++)
		writeCommand(0xb0+m);	//page0-page1
		writeCommand(0x00);		//low column start address
		writeCommand(0x10);		//high column start address
		for(n=0;n<128;n++)
			writeByte(m_pFramebuffer[i++]);
		stopIIC();
#else
	updateRow(0,SSD1306_MAXROW);
#endif
void Adafruit_ssd1306syp::updateRow(int rowID)
	unsigned char x;
	unsigned int  index;
	if(rowID>=0 && rowID<SSD1306_MAXROW && m_pFramebuffer)
	{//this part is faster than else.
		//set the position
		startIIC();
		writeByte(0xb0+rowID);
		writeByte(((x&0xf0)>>4)|0x10);//|0x10
		writeByte((x&0x0f)|0x01);//|0x01
		stopIIC();
		//start painting the buffer.
		for(x=0;x<SSD1306_WIDTH;x++)
			index = rowID*SSD1306_WIDTH+x;
	  		writeByte(m_pFramebuffer[index]);
		stopIIC();
void Adafruit_ssd1306syp::updateRow(int startID, int endID)
	unsigned char y =0;
	for(y=startID; y<endID; y++)
		updateRow(y);
}/code]
