Can it be safely used with Arduino Pro mini 5v? I am concerned whether it draws too much amps for Arduino pro pins. It is used only to momentarily turn on and then off the relay.
I did not see a input current requirement listed. The input from the Arduino or RC module looks like is it connected to a transistor then to a PIC, so I doubt it will draw too much.
On another note, the intended input is PWM not digital ON/OFF. There are other modules available that use a digital ON/OFF signal with an opto isolator input to protect and control the arduino output pins. I would suggest looking at those options as well.
The relays coil current is 80 mA, twice the absolute maximum for an Atmega328 output pin, you need a switching transistor like 2N3904 or similar, and a spike suppression diode like 1N4148 across the coil, you could power 1 relay from the 5V pin if it’s only intermittent.
outsider:
I agree that is a proper way drive drive a standalone relay. That cannot be said of the aforementioned relay module. It looks like it has some smarts and stuff between the Arduino and the relay coil.
adwsystems:
I agree, it looks like it has some RC specific components on it.
Hence the part name “Pololu RC Switch w/ Relay”
