I'm trying to implement a automation system for three lights: two by switches in the dashboard and one by a PIR sensor. I can put the PIR code in the loop function and it works fine but I think is more efficient to call a onChange function every time the PIR state change, I understand this functions only works if there is a change in the dashboard for this reason I put a switch in the dashboard linked to the PIR cloud variable but the program doesn't enter in this function. Can you help me?
Sketch generated by the Arduino IoT Cloud Thing "casa_26"
https://create.arduino.cc/cloud/things/dc4deab8-bec8-4f8e-b41c-310c3356a0b1
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
CloudDimmedLight comedor;
CloudDimmedLight sala;
CloudLight patio;
bool sensor;
bool trigger;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#define led03 3
#define led05 5
#define led06 6
#define pir 12
int pwm;
int contador=0;
bool lectura_pir;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
//Ubicar nuevo codigo de configuracion
pinMode(led03,OUTPUT);
pinMode(led05, OUTPUT);
pinMode(led06, OUTPUT);
pinMode(13,OUTPUT);
pinMode(pir, INPUT);
//Verificacion de funcionamiento de lamparas
digitalWrite(led03,HIGH);
digitalWrite(led05,HIGH);
digitalWrite(led06,HIGH);
delay(2000);
digitalWrite(led03,LOW);
digitalWrite(led05,LOW);
digitalWrite(led06,LOW);
ArduinoCloud.update();
deteccion();
//Ubicar nuevo codigo de operacion
void deteccion()
sensor=digitalRead(pir);
trigger=sensor;
Serial.print("Estado del PIR orig: ");
Serial.println(digitalRead(pir));
Serial.print("Estado del PIR: ");
Serial.println(sensor);
Serial.print("Estado de TRIGGER: ");
Serial.println(trigger);
Since Sala is READ_WRITE variable, onSalaChange() is
executed every time a new value is received from IoT Cloud.
void onSalaChange()
// Add your code here to act upon Sala change
if(sala.getSwitch())
pwm=map(sala.getBrightness(),0,100,20,255);
analogWrite(led05,pwm);
analogWrite(led05,0);
Since Comedor is READ_WRITE variable, onComedorChange() is
void onComedorChange()
// Add your code here to act upon Comedor change
if(comedor.getSwitch())
pwm=map(comedor.getBrightness(),0,100,20,255);
analogWrite(led06,pwm);
analogWrite(led06,0);
Since Patio is READ_WRITE variable, onPatioChange() is
void onPatioChange()
// Add your code here to act upon Patio change
Since Sensor is READ_WRITE variable, onSensorChange() is
void onSensorChange()
// Add your code here to act upon Sensor change
Serial.print("Funcion onSensorChange");
void onTriggerChange()
// Add your code here to act upon Trigger change
if(digitalRead(pir)==true)
patio=true;
contador++;
Serial.print("Detecciones: ");
Serial.print(contador);
if(contador>=3)
digitalWrite(13,HIGH);
delay(100);
digitalWrite(13,LOW);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
contador=0;
else if(digitalRead(pir)==false)
patio=false;
