Hi!
I have 2 programs in Arduino which run separately, one measuring heartrate, and one measuring temperature. They both work in separate files, but when I combined both of them, only the heartrate monitor was reading any data, and the temperature sensor was returning 0s.
They both work in the setup I have when the programs are ran separately, but when I run the combined code, The temperature sensor doesn't pick up an data.
I am using a Pulse Sensor Heartrate Monitor, and a DHT11 Temperature Sensor.
Heartrate Monitor Code:
/* Getting_BPM_to_Monitor prints the BPM to the Serial Monitor, using the least lines of code and PulseSensor Library.
* Tutorial Webpage: https://pulsesensor.com/pages/getting-advanced
--------Use This Sketch To------------------------------------------
1) Displays user's live and changing BPM, Beats Per Minute, in Arduino's native Serial Monitor.
2) Print: "♥ A HeartBeat Happened !" when a beat is detected, live.
2) Learn about using a PulseSensor Library "Object".
4) Blinks the builtin LED with user's Heartbeat.
#define USE_ARDUINO_INTERRUPTS true // Set-up low-level interrupts for most acurate BPM math.
#include <PulseSensorPlayground.h> // Includes the PulseSensorPlayground Library.
// Variables
const int PulseWire = 0; // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
const int LED = 13; // The on-board Arduino LED, close to PIN 13.
int Threshold = 200; // Determine which Signal to "count as a beat" and which to ignore.
// Use the "Gettting Started Project" to fine-tune Threshold Value beyond default setting.
// Otherwise leave the default "550" value.
PulseSensorPlayground pulseSensor; // Creates an instance of the PulseSensorPlayground object called "pulseSensor"
Serial.begin(9600); // For Serial Monitor
// Configure the PulseSensor object, by assigning our variables to it.
pulseSensor.analogInput(PulseWire);
pulseSensor.blinkOnPulse(LED); //auto-magically blink Arduino's LED with heartbeat.
pulseSensor.setThreshold(Threshold);
// Double-check the "pulseSensor" object was created and "began" seeing a signal.
if (pulseSensor.begin()) {
Serial.println("We created a pulseSensor Object !"); //This prints one time at Arduino power-up, or on Arduino reset.
if (pulseSensor.sawStartOfBeat()) { // Constantly test to see if "a beat happened".
int myBPM = pulseSensor.getBeatsPerMinute(); // Calls function on our pulseSensor object that returns BPM as an "int".
// "myBPM" hold this BPM value now.
Serial.println("♥ A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
Serial.print("BPM: "); // Print phrase "BPM: "
Serial.println(myBPM); // Print the value inside of myBPM.
delay(10); // considered best practice in a simple sketch.
Temp Sensor Code:
#include <dht.h>
dht DHT;
#define DHT11_PIN A1
void setup(){
void loop(){
int chk = DHT.read11(DHT11_PIN);
Serial.print("Temperature = ");
Serial.println(DHT.temperature);
Serial.print("Humidity % = ");
Serial.println(DHT.humidity);
Combined code (program that i have a problem with):
#include <dht.h>
dht DHT;
// Variables
//temp sensor
delay(10);
//heartbeat monitor
Serial.println("Heartbeat detected:"); // If test is "true", print a message "a heartbeat happened".
Any help would be appreciated. Thank you!
