OPCUA - UaExpert Arduino Ethernet Shield
Hello,
I have an Arduino Uno and a Temeprature Sensor. I want to use the Arduino with an Ethernet Sheild as a server and give the data to my PC. I Want to use OPCUA UaExpert. I use the opc.h library and the example code that ist given.
The code ist the following:
 * A generic sketch for use with the Arduino OPC or Visual OPC Builder from www.st4makers.com
#include <OPC.h>
#include <Bridge.h>
#include <Ethernet.h>
#include <SPI.h>
 * Declaring the OPC object
OPCEthernet myArduinoUno;
 * MAC address from Ethernet shield sticker under board
byte mac[] = { 0xA8, 0x61, 0x0A, 0xAE, 0xAA, 0x8D };
 * Set your network configuration
IPAddress ip(192, 168, x, XX);
IPAddress gateway(192, 168, X, X);
IPAddress dns_server(192,168,X,X);
IPAddress subnet(255,255,255,X);
 * Server listen port
const int listen_port = 80;
opcOperation digital_status_input[14], analog_status_input[6];
bool readwrite_digital(const char *itemID, const opcOperation opcOP, const bool value)
  byte port;
  port = atoi(&itemID[1]);
  if (opcOP == opc_opwrite) {
    if (digital_status_input[port] == opc_opread) {
      digital_status_input[port] = opc_opwrite;
      pinMode(port,OUTPUT);
    digitalWrite(port,value);
    if (digital_status_input[port] == opc_opwrite) {
      digital_status_input[port] = opc_opread;
     // pinMode(port,INPUT);
    return digitalRead(port);
int readwrite_analog(const char *itemID, const opcOperation opcOP, const int value) {
  byte port;
    if (analog_status_input[port] == opc_opread) {
      analog_status_input[port] = opc_opwrite;
    analogWrite(port,value);
    if (analog_status_input[port] == opc_opwrite) {
      analog_status_input[port] = opc_opread;
      //pinMode(port,INPUT);
    return analogRead(port);
  byte k;
  for (k=0;k<14;k++) digital_status_input[k] = opc_opread;
  for (k=0;k<5;k++)  analog_status_input[k] = opc_opread;
   * OPC Object initialization
  myArduinoUno.setup(listen_port,mac,ip);
  myArduinoUno.addItem("D0",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D1",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D2",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D3",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D4",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D5",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D6",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D7",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D8",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D9",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D10",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D11",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D12",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("D13",opc_readwrite, opc_bool, readwrite_digital);
  myArduinoUno.addItem("A0",opc_readwrite, opc_int, readwrite_analog);
  myArduinoUno.addItem("A1",opc_readwrite, opc_int, readwrite_analog);
  myArduinoUno.addItem("A2",opc_readwrite, opc_int, readwrite_analog);
  myArduinoUno.addItem("A3",opc_readwrite, opc_int, readwrite_analog);
  myArduinoUno.addItem("A4",opc_readwrite, opc_int, readwrite_analog);
  myArduinoUno.addItem("A5",opc_readwrite, opc_int, readwrite_analog);
  myArduinoUno.processOPCCommands();
I use UaExpert as my client to read the Sensor data. Now I have the problem that I get the Error Code:
"Discovery Findservers on opc.tpc://192.168.X.X failed (BadTimeout)"
opc.tpc://192.168.X.X is the URL that I use to connect to the Arduino uno.
Can someone help me?
Did you replace the X and XX in the IPAddress with real values?
Yes I did, I used the Arduino Ethernet Example code to get the IP. I can also Ping the Server with "cmd". But I cant connect the Server with the UaExpert.
