Hi guys,
First of all, thank you fr taking your time loking into this, it's much apriciated!
@dlloyd;
I'm just following schematics from a project where many people have used this interface with success, the main difference is that they are hooking it up to a laptop and using RS232 in combination with the MAX232 IC.
Unfortunatly, there isn't any circuit diagram what I can found for the REGO6xx controller inside the heatpump.
All I know is that Communication always using 19200 bps, 8 bit, no parity, 1 stop bit (19200/8N1). 5V CMOS 4000 (TTL) signals. Probably thats why the optocoupler is inverted in the schematics?
From what I have read, the cable on the TTL side in conjunction with REGO controller, must not exceed 50cm, then the link will be unstable, it's also in previous project stated that the REGO 5V isn't able to power anything but a couple of optocouplers.
I don't want to risk the REGO controller, without it my heat pump will not work, and the house gets cold. A new REGO is very expensive and is a very vital component to get the whole pump to work.
Pictures of the board can be found here:
http://www.nekropolis.cz/rego6xx/inside/
@septillion;
I tried to give as much info I have on the setup to make it more easy to get correct help, as stated I'm not good at electrical designs, hence I assumed I need optocouplers since people who have done this before have used optocouplers (and MAX232, because of RS232 interface to laptop)
I'm curious to know, to learn, Why I won't be needing any optocouplers?
@Morgan;
Thanks for the explanation, I know understand the Rx/Tx dilemma! So probably, this schematic from softsolder would work between the Mega --> KNX BTU after all, just revise a bit and connect Rx to Tx, and Tx to Rx instead.
If you are referring to the illustrated diagram with the Pro Mini, then this is not the one I want to opto isolate, because in that case the BCU powers the pro mini, and the only thing connected to the pro mini is temp/humidity sensor, the are on the same ground plane.
It's for this project, where I'm going to use a Mega 2560 with external power supply I want to avoid ground loops and magic smoke
