I've been working on a project to send OSC commands to trigger IR codes to control a LED Light.
I've tested and have it working with the Arduino Uno with an Ethernet shield getting triggered via OSC on QLab. But I could only have a maximum of 8 OSC commands before it became too much for the Uno to handle. I then went and bought an Arduino Mega 2560 because it has more processing power but the code doesn't work at all. It just comes up with an error in the serial
message decode error invalid.
any time I send any command (both programmed and unprogrammed commands).
I'm using the following libraries:
IR Remote (GitHub - Arduino-IRremote/Arduino-IRremote: Infrared remote library for Arduino: send and receive infrared signals with multiple protocols)
ArduinoOSC (GitHub - hideakitai/ArduinoOSC: OSC subscriber / publisher for Arduino)
Ethernet (GitHub - arduino-libraries/Ethernet: Ethernet Library for Arduino)
The code I'm using is the following.
#include <ArduinoOSC.h>
#include <IRremote.h>
// Ethernet Settings
const IPAddress ip(10, 0, 100, 1); // device ip
uint8_t mac[] = {0x01, 0x23, 0x45, 0x67, 0x89, 0xAB}; // device mac address
// ArduinoOSC
OscEthernet osc;
const char* host = "10.0.100.100"; // ip for sending OSC
const int recv_port = 10000; // listening port
const int send_port = 53000; // sending port
// IR Settings
IRsend irsend;
const int ledPin = 3;
// OSC ACTIONS
// ir status
void IRStatusOn(OscMessage& m)
Serial.print("[IR] On");
Serial.println("");
irsend.sendNEC(0xFFB04F, 32);
void IRStatusOff(OscMessage& m)
Serial.print("[IR] Off");
Serial.println("");
irsend.sendNEC(0xFFF807, 32);
// ir dim
void IRDimUp(OscMessage& m)
Serial.print("[IR] Dim | Up");
Serial.println("");
irsend.sendNEC(0xFF906F, 32);
void IRDimDown(OscMessage& m)
Serial.print("[IR] Dim | Down");
Serial.println("");
irsend.sendNEC(0xFFB847, 32);
// ir colour (primary)
void IRColourRed(OscMessage& m)
Serial.print("[IR] Colour | Red");
Serial.println("");
irsend.sendNEC(0xFF9867, 32);
void IRColourGreen(OscMessage& m)
Serial.print("[IR] Colour | Green");
Serial.println("");
irsend.sendNEC(0xFFD827, 32);
void IRColourBlue(OscMessage& m)
Serial.print("[IR] Colour | Blue");
Serial.println("");
irsend.sendNEC(0xFF8877, 32);
void IRColourWhite(OscMessage& m)
Serial.print("[IR] Colour | White");
Serial.println("");
irsend.sendNEC(0xFFA857, 32);
// ir colour (mixers)
void IRColourBloodOrange(OscMessage& m)
Serial.print("[IR] Colour | Blood Orange {R1}");
Serial.println("");
irsend.sendNEC(0xFFE817, 32);
void IRColourOrange(OscMessage& m)
Serial.print("[IR] Colour | Orange {R2}");
Serial.println("");
irsend.sendNEC(0xFF02FD, 32);
void IRColourBrightOrange(OscMessage& m)
Serial.print("[IR] Colour | Bright Orange {R3}");
Serial.println("");
irsend.sendNEC(0xFF50AF, 32);
void IRColourYellow(OscMessage& m)
Serial.print("[IR] Colour | Yellow {R4}");
Serial.println("");
irsend.sendNEC(0xFF38C7, 32);
void IRColourLime(OscMessage& m)
Serial.print("[IR] Colour | Lime {G1}");
Serial.println("");
irsend.sendNEC(0xFF48B7, 32);
void IRColourCyan(OscMessage& m)
Serial.print("[IR] Colour | Cyan {G2}");
Serial.println("");
irsend.sendNEC(0xFF32CD, 32);
void IRColourSeaGreen(OscMessage& m)
Serial.print("[IR] Colour | Sea Green {G3}");
Serial.println("");
irsend.sendNEC(0xFF7887, 32);
void IRColourEmerald(OscMessage& m)
Serial.print("[IR] Colour | Emerald {G4}");
Serial.println("");
irsend.sendNEC(0xFF28D7, 32);
void IRColourSkyBlue(OscMessage& m)
Serial.print("[IR] Colour | Sky Blue {B1}");
Serial.println("");
irsend.sendNEC(0xFF6897, 32);
void IRColourPurple(OscMessage& m)
Serial.print("[IR] Colour | Purple {B2}");
Serial.println("");
irsend.sendNEC(0xFF20DF, 32);
void IRColourMagenta(OscMessage& m)
Serial.print("[IR] Colour | Magenta {B3}");
Serial.println("");
irsend.sendNEC(0xFF708F, 32);
void IRColourPink(OscMessage& m)
Serial.print("[IR] Colour | Pink {B4}");
Serial.println("");
irsend.sendNEC(0xFFF00F, 32);
// ir effects
void IREffectFlash(OscMessage& m)
Serial.print("[IR] Effect | Flash");
Serial.println("");
irsend.sendNEC(0xFFB24D, 32);
void IREffectStrobe(OscMessage& m)
Serial.print("[IR] Effect | Strobe {B4}");
Serial.println("");
irsend.sendNEC(0xFF00FF, 32);
void IREffectFade(OscMessage& m)
Serial.print("[IR] Effect | Fade {B4}");
Serial.println("");
irsend.sendNEC(0xFF58A7, 32);
void IREffectSmooth(OscMessage& m)
Serial.print("[IR] Effect | Smooth {B4}");
Serial.println("");
irsend.sendNEC(0xFF30CF, 32);
pinMode(ledPin, OUTPUT);
Ethernet.begin(mac, ip);
// ArduinoOSC
osc.begin(recv_port);
// OSC COMMANDS
// ir status
osc.subscribe("/ir/status/on", IRStatusOn);
osc.subscribe("/ir/status/off", IRStatusOff);
// ir dim
osc.subscribe("/ir/dim/up", IRDimUp);
osc.subscribe("/ir/dim/down", IRDimDown);
osc.subscribe("/ir/colour/red", IRColourRed);
osc.subscribe("/ir/colour/green", IRColourGreen);
osc.subscribe("/ir/colour/blue", IRColourBlue);
osc.subscribe("/ir/colour/white", IRColourWhite);
osc.subscribe("/ir/colour/bloodorange", IRColourBloodOrange);
osc.subscribe("/ir/colour/orange", IRColourOrange);
osc.subscribe("/ir/colour/brightorange", IRColourBrightOrange);
osc.subscribe("/ir/colour/yellow", IRColourYellow);
osc.subscribe("/ir/colour/lime", IRColourLime);
osc.subscribe("/ir/colour/cyan", IRColourCyan);
osc.subscribe("/ir/colour/seagreen", IRColourSeaGreen);
osc.subscribe("/ir/colour/emerald", IRColourEmerald);
osc.subscribe("/ir/colour/skyblue", IRColourSkyBlue);
osc.subscribe("/ir/colour/purple", IRColourPurple);
osc.subscribe("/ir/colour/magenta", IRColourMagenta);
osc.subscribe("/ir/colour/pink", IRColourPink);
// ir effects
osc.subscribe("/ir/effect/flash", IREffectFlash);
osc.subscribe("/ir/effect/strobe", IREffectStrobe);
osc.subscribe("/ir/effect/fade", IREffectFade);
osc.subscribe("/ir/effect/smooth", IREffectSmooth);
osc.parse();
I've tried cutting back the code also on the Mega to the one that works on the Uno and it's still comes up with the same error. Tried modifying the code, using different OSC libraries. But haven't been able to get anything to work and unsure of how to proceed from here.
Any help would be appreciated.
Cheers.
