I just discovered word wrap in IDE 2.2.1 and it's a wonderful thing! Now I don't have to scroll the window to read those long error messages!
It is just a shame that it is not a "sticky" setting
Copy/paste to TTS
You mean I could have this:
"C:\Users\User\AppData\Local\Temp\arduino\sketches\4C996461D98DC3A4EA73787BFBB2439C/manipulate_64_bit_gfvalvo_swap_upper_lower_via_xor.ino.eep"
uninitialized in this function [-Wuninitialized]
Serial.println(upper32, HEX);
read out to my earbuds?
Ugh!
Meaning it'll disappear next IDE update I do?
No, just that from memory the IDE does not remember the setting when closed, but I could be wrong
You are correct, it's not persistent.
But, there's an easy enough keyboard shortcut to turn it on/off - Alt+Z.
Changed thread title so it's more accurate.
I know how to turn it on and off using the shortcut but the question is why should I have to ? Once set it should be persistent rather than needing to turn it on every time an instance of the IDE is started
No argument there.
