An easy way to handle such a task is to pick an absolute reference frame and count in only one unit.
For example, why not convert the hours to minutes, and then count minutes from the start of the day. ie. 0100 hrs = 60 minutes and 0200 hrs = 120 minutes.
Now you can specify a range for which you’d like the output to be on. For example:
if (minute >= 60 && minute <= 120) //Turns on the output at 0100 hrs and turns off at 0200 hrs
digitalWrite (13, HIGH);
Not sure i can do that as the time is also output to a lcd disply so the code is in hours and minutes
The conversion from one reference frame to another will be quite trivial. In your case, lets assume that minutes was an int which contains the number of minutes since the start of the day.
int hours_to_display = minutes / 60; //will truncate the decimal points, but stores whole hours in hours_to_display
int minutes_to_display = minutes % 60; //will store remaining minutes into minutes_to_display
Not sure why you have braces around those lines of code.
Try this code. I just made a minor modification. I added a few lines which print the current value of int hourmin to the serial terminal. Monitor serial and see if you can figure out what the issue is. Post back with the results.
I had to include c stdlib for the itoa function which converts an int to a string, used to print hourmin.
#include <Wire.h>
#include <LiquidCrystal.h>
#include <stdlib.h> //used for itoa. Feel free to remove if not using that function
LiquidCrystal lcd(49, 48, 47, 53, 52, 51, 50);
int fan = 13; // fan on pin 13
int pin = 0; // analog pin
int tempc = 0,tempf=0; // temperature variables
int samples[8]; // variables to make a better precision
int maxi = -100,mini = 100; // to start max/min temperature
int i; // temp varialbe
#define DS1307 0xD0 >> 1 // shift required by Wire.h (silly...)
// DS1307 clock registers
#define R_SECS 0
#define R_MINS 1
#define R_HRS 2
byte second = 0x00; // default to 01 JAN 2007, midnight
byte minute = 0x00;
byte hour = 0x00;
byte wkDay = 0x02;
byte day = 0x01;
byte month = 0x01;
byte year = 0x07;
byte ctrl = 0x00;
pinMode(fan, OUTPUT); // digital pin for fan as output
Wire.begin();
lcd.clear();
//second = 0x45; // remove to set time then replace
//minute = 0x31;
//hour = 0x17;
//wkDay = 0x07;
//day = 0x13;
//month = 0x04;
//year = 0x09;
//ctrl = 0x00; // disable SQW output
//setClock();
for(i = 0;i<=7;i++){ // gets 8 samples of temperature
samples[i] = ( 5.0 * analogRead(pin) * 100.0) / 1024.0;
tempc = tempc + samples[i];
tempc = tempc/8.0; // better precision
tempf = (tempc * 9)/ 5 + 32; // converts to fahrenheit
// if (tempc > 21) // value for fan on pin 13
//digitalWrite(13, HIGH); // fan on
// if (tempc < 21) // value for fan off on pin 13
// digitalWrite(13, LOW); // fan off
int hourmin = (hour * 60) //hours * 60 = variable hourmin
char string_buffer[12]; //used to store hourmin when converted to string
Serial.printLn(itoa(hourmin, string_buffer, 10)) //convert hourmin to decimal (base 10), and store into string_buffer. Also print to serial
if (hourmin + minute > 1500) // hourmin + minute > 1500 minutes
lcd.setCursor(0,1);
lcd.print(tempc,DEC);
lcd.println(" Celsius ");
lcd.setCursor(0,0);
tempc = 0;
delay(0000); // delay before loop
getClock();
printHex2(hour);
lcd.print(":");
printHex2(minute);
lcd.print(" ");
lcd.print(" ");
printHex2(day);
lcd.print("/");
printMonthName(bcd2Dec(month));
lcd.print("/");
printHex2(year);
lcd.println();
void setClock()
Wire.beginTransmission(DS1307);
Wire.send(R_SECS);
Wire.send(second);
Wire.send(minute);
Wire.send(hour);
Wire.send(wkDay);
Wire.send(day);
Wire.send(month);
Wire.send(year);
Wire.send(ctrl);
Wire.endTransmission();
void getClock()
Wire.send(R_SECS);
Wire.requestFrom(DS1307, 8);
second = Wire.receive();
minute = Wire.receive();
hour = Wire.receive();
wkDay = Wire.receive();
day = Wire.receive();
month = Wire.receive();
year = Wire.receive();
ctrl = Wire.receive();
byte bcd2Dec(byte bcdVal)
return bcdVal / 16 * 10 + bcdVal % 16;
void printHex2(byte hexVal)
if (hexVal < 0x10)
lcd.print("0");
lcd.print(hexVal, HEX);
void printDec2(byte decVal)
if (decVal < 10)
lcd.print("0");
lcd.print(decVal, DEC);
void printMonthName(byte m)
switch (m) {
case 1:
lcd.print("01");
case 2:
lcd.print("02");
case 3:
lcd.print("03");
case 4:
lcd.print("04");
case 5:
lcd.print("05");
case 6:
lcd.print("06");
case 7:
lcd.print("07");
case 8:
lcd.print("08");
case 9:
lcd.print("09");
case 10:
lcd.print("10");
case 11:
lcd.print("11");
case 12:
lcd.print("12");
Well its partly working, The serial print hour all ways shows 1440.
I have altered the byte,hour from 00 to 01 and the serial shows
60
1440
1440
I think im not using the right “hour” for the calculations, only problem now is i cant seem to find the right “hour” and i will probably have the same problem with the minutes when i get the hours sorted.
Serial.print("hour: ");
Serial.printLn(hour);
Serial.print("minute: ");
Serial.printLn(minute);
Serial.print("hourmin: ");
Serial.printLn(); //prints a carriage return
As you can see above, ive added more debugging messages. Give that a shot and see if you can figure out whats funky.
Full code can be found below:
#include <Wire.h>
#define R_SECS 0
#define R_MINS 1
#define R_HRS 2
byte minute = 0x00;
byte hour = 0x00;
byte wkDay = 0x02;
byte day = 0x01;
byte month = 0x01;
byte year = 0x07;
byte ctrl = 0x00;
Wire.begin();
lcd.clear();
//minute = 0x31;
//hour = 0x17;
//wkDay = 0x07;
//day = 0x13;
//month = 0x04;
//year = 0x09;
//setClock();
lcd.setCursor(0,1);
lcd.setCursor(0,0);
tempc = 0;
getClock();
printHex2(hour);
lcd.print(":");
printHex2(minute);
lcd.print(" ");
lcd.print(" ");
printHex2(day);
lcd.print("/");
lcd.print("/");
printHex2(year);
lcd.println();
void setClock()
Wire.send(R_SECS);
Wire.send(second);
Wire.send(minute);
Wire.send(hour);
Wire.send(wkDay);
Wire.send(day);
Wire.send(month);
Wire.send(year);
Wire.send(ctrl);
void getClock()
Wire.send(R_SECS);
if (hexVal < 0x10)
lcd.print("0");
if (decVal < 10)
lcd.print("0");
switch (m) {
case 1:
lcd.print("01");
case 2:
lcd.print("02");
case 3:
lcd.print("03");
case 4:
lcd.print("04");
case 5:
lcd.print("05");
case 6:
lcd.print("06");
case 7:
lcd.print("07");
case 8:
lcd.print("08");
case 9:
lcd.print("09");
case 10:
lcd.print("10");
case 11:
lcd.print("11");
case 12:
lcd.print("12");
Its odd that hourmin is printing 1440 when hour has been set to 01. It appears to print 60 minutes correctly for the first cycle, but printing 1440 after those cycles is odd.
