"Overclock" the R4 family
Hi to all I have read that the R7FA4M1AB3CFM#AA0 could operate up to 64MHz, but the R4 family works at 48. How is it possible to "overclock" the MCU? Is there any avr.h library that works for Renesas MCU?
Hi @the_marox666,
Overclocking requires register access, but it is possible to overclock the RA4M1 if one uses the PLL with an external crystal or an external frequency source.
I am currently running my Minima at 80MHz with an external 10MHz input.
The USB serial still works as the USB module remains running on the internal 48MHz HOCO clock (which can't be changed as the USB has to be at 48MHz). If you don't want the USB function, then you should be able to push the RA4M1 up to 64MHz.
The RA4M1 won't do 85MHz, at least with the default Arduino IDE setup.
Code up on GitHub:
https://github.com/TriodeGirl/Arduino-UNO_R4_HOCO_to_External-Clock_on_EXTAL_pin_change/tree/main
P.S. No AVR libraries as this is a different processor.
Hi @the_marox666
Here's an alternative to fitting a crystal or using an external clock-sorce.
With the PPL divide-by-4 setting, I have test code that is overclocking up to 96MHz, and underclocking down to 6MHz.
I am using the HOCO internal 48MHz clock divided by 4 on the clock monitor output pin D11, with a 12K to 1.8K divider to reduce the voltage, the AC coupled to the EXTAL pin with a 220pF capacitor.
Despite what the RA4M1 data-sheet says, the PLL multiplier works from 2x.
Some code tidy-up needed, but here is an in-progress snapshot.
115200 baud with New Line setting.
Type ? for list of commands.
/*  Arduino UNO R4 code for switching to external-clock input using HOCO / 4 clock on D11 to generate 12MHz
 *  ... USB clock always remains on HOCO 48MHz
 *  Sucessfully run at 96MHz with /4 divider setting, without any changes to the normal RA4M1 clock setups,
 *  ... also reduce PLL Multiplier to 2x (data-sheet minimum says 8x) to run at 6MHz (with /4 divide).
 *  Uses Wake-From-Interrupt to remove unneeded loop() spinning when in PLL mode.
 *  Take care about maximum signal levels on EXTAL pin input:
 *  ... D11 is nominal 5V P/P,  resistor-divider to 1V - then A/C coupled this to EXTAL pin with 220pF cap.
 *  WARNING - Using higher clock frequencies is HIGHLY EXPERIMENTAL !!!
 *  The DAC output with a 15.6Hz sine generated signal can be used to check code operation,
 *  ... with square wave reference clock for triggering on D4.
 *  If in Wake-From-Interrupt mode will need to Double-Press R4's Reset Button to put into bootloader mode when updating code.
 *  Susan Parker - 6th May 2024.
 *    Tested on Minima
 *    USB Serial module remains on HOCO clock source...
 *      so non-standard frequencies can be used in the range 4 MHz to 12.5 MHz
 *      e.g. 12.288 MHZ - Adjust PLL settings to match.
 *  Susan Parker - 18/19th May 2024.
 *    Startup remains with HOCO clocking
 *    Extended code for start and stoping PLL mode
 *    Add /2 or /4 divider options
 *  Susan Parker - 20th May 2024.
 *    Startup with HOCO clocking with /4 clock output on D11
 *    Change for 12MHz input frequency.
 * This code is "AS IS" without warranty or liability.
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
// ARM-developer - Accessing memory-mapped peripherals
// https://developer.arm.com/documentation/102618/0100
// ==== System & Clock Generation ====
#define SYSTEM 0x40010000 // ICU Base - See 13.2.6 page 233
// Register Write Protection - See section 12
// PRC0 Registers related to the clock generation circuit:
//   SCKDIVCR, SCKSCR, PLLCR, PLLCCR2, MEMWAIT, MOSCCR, HOCOCR, MOCOCR, CKOCR, TRCKCR,
//   OSTDCR, OSTDSR, SLCDSCKCR, EBCKOCR, MOCOUTCR, HOCOUTCR, MOSCWTCR, MOMCR, SOSCCR,
//   SOMCR, LOCOCR, LOCOUTCR, HOCOWTCR, USBCKCR
//   *SYSTEM_PRCR = 0xA501;     // Enable writing to the clock registers
//   *SYSTEM_PRCR = 0xA500;     // Disable writing to the clock registers
#define SYSTEM_PRCR  ((volatile unsigned short *)(SYSTEM + 0xE3FE))    // Protect Register
#define PRCR_PRC0           0   // Enables or disables writing to clock generation registers
#define PRCR_PRC1           1   // En/Dis writing to the low power modes and battery backup function registers
#define PRCR_PRC3           3   // Enables or disables writing to the registers related to the LVD
#define PRCR_PRKEY_7_0      8   // Control write access to the PRCR register.
#define PRCR_PRKEY       0xA5   // PRC Key Code - write to the upper 8 bits
#define SYSTEM_SCKDIVCR  ((volatile unsigned int *)(SYSTEM + 0xE020))  // System Clock Division Control Register
                                // SYSTEM_SCKDIVCR = 100010100
#define SCKDIVCR_PCKD_2_0   0   // Peripheral Module Clock D           = 4; 1/16
#define SCKDIVCR_PCKC_2_0   4   // Peripheral Module Clock C           = 1; 1/2
#define SCKDIVCR_PCKB_2_0   8   // Peripheral Module Clock B           = 1; 1/2
#define SCKDIVCR_PCKA_2_0  12   // Peripheral Module Clock A           = 0
#define SCKDIVCR_ICK_2_0   24   // System Clock (ICLK) Select          = 0
#define SCKDIVCR_FCK_2_0   28   // Flash Interface Clock (FCLK) Select = 0
#define SYSTEM_SCKSCR  ((volatile unsigned char *)(SYSTEM + 0xE026))  // System Clock Source Control Register
#define SCKSCR_CKSEL_2_0    0   // Clock Source Select - See section 8.2.2
#define SYSTEM_PLLCR   ((volatile unsigned char *)(SYSTEM + 0xE02A))  // PLL Control Register
#define PLLCR_PLLSTP        0   // PLL Stop Control; 0: PLL is operating, 1: PLL is stopped
#define SYSTEM_PLLCCR2 ((volatile unsigned char *)(SYSTEM + 0xE02B))  // PLL Clock Control Register 2
#define PLLCCR2_PLLMUL_4_0  0   // PLL Frequency Multiplication Factor Select
#define PLLCCR2_PLODIV_1_0  6   // PLL Output Frequency Division Ratio Select
#define SYSTEM_MEMWAIT ((volatile unsigned char *)(SYSTEM + 0xE031))  // Memory Wait Cycle Control Register
#define MEMWAIT_MEMWAIT     0   // Memory Wait Cycle Select; 0: No wait, 1: Wait
#define SYSTEM_MOSCCR   ((volatile unsigned char *)(SYSTEM + 0xE032))  // Main Clock Oscillator Control Register
#define MOSCCR_MOSTP        0   // Main Clock Oscillator Stop; 0: Main clock oscillator is operating, 1: MCO is stopped
#define SYSTEM_HOCOCR   ((volatile unsigned char *)(SYSTEM + 0xE036))  // High-Speed On-Chip Oscillator Control Register
#define HOCOCR_HCSTP        0   // HOCO Stop; 0: HOCO is operating, 1: HOCO is stopped
#define SYSTEM_MOCOCR   ((volatile unsigned char *)(SYSTEM + 0xE038))  // Middle-Speed On-Chip Oscillator Control Register
#define MOCOCR_MCSTP        0   // MOCO Stop; 0: MOCO is operating, 1: MOCO is stopped
#define SYSTEM_OSCSF    ((volatile unsigned char *)(SYSTEM + 0xE03C))  // Oscillation Stabilization Flag Register
#define OSCSF_HOCOSF        0   // HOCO Clock Oscillation Stabilization Flag; 0: The HOCO clock is stopped or not stable, 1: The clock is stable
#define OSCSF_MOSCSF        3   // Main Clock Oscillation Stabilization Flag; 0: The Main clock is stopped or not stable, 1: The clock is stable
#define OSCSF_PLLSF         5   // PLL  Clock Oscillation Stabilization Flag; 0: The PLL  clock is stopped or not stable, 1: The clock is stable
#define SYSTEM_CKOCR    ((volatile unsigned char *)(SYSTEM + 0xE03E))  // Clock Out Control Register
#define CKOCR_CKOSEL_2_0    0   // Clock Out Source Select; 000: HOCO, 001: MOCO, 010: LOCO, 011: MOSC, 100: SOSC
#define CKOCR_CKODIV_2_0    4   // Clock Out Input Frequency Division Select; 000: ×1, 001: /2, 010: /4, ... , 111: /128
#define CKOCR_CKOEN         7   // Clock Out Enable; 0: Disable clock out, 1: Enable clock out
#define SYSTEM_TRCKCR   ((volatile unsigned char *)(SYSTEM + 0xE03F))  // Trace Clock Control Register
#define TRCKCR_TRCK_3_0     0   // Trace Clock Operation Frequency Select; 0000: /1, 0001: /2, 0010: /4 ( /2 = value after reset )
#define TRCKCR_TRCKEN       7   // Trace Clock Operating Enable; 0: Disable clock, 1: Enable clock
#define SYSTEM_OSTDCR   ((volatile unsigned char *)(SYSTEM + 0xE040))  // Oscillation Stop Detection Control Register
#define OSTDCR_OSTDIE       0   // Oscillation Stop Detection Interrupt Enable; 0: Disable oscillation stop detection interrupt, 1: Enable OSDI
#define OSTDCR_OSTDE        7   // Oscillation Stop Detection Function Enable; 0: Disable the oscillation stop detection function, 1: Enable OSDF
#define SYSTEM_OSTDSR   ((volatile unsigned char *)(SYSTEM + 0xE041))  // Oscillation Stop Detection Control Register
#define OSTDSR_OSTDF        0   // Oscillation Stop Detection Flag; 0: Main clock oscillation stop not detected, 1: Main clock oscillation stop detected
#define SYSTEM_SLCDSCKCR    ((volatile unsigned char *)(SYSTEM + 0xE050))  // Segment LCD Source Clock Control Register
#define SLCDSCKCR_LCDSCKSEL_2_0  0  // LCD Source Clock Select; 000: LOCO, 001: SOSC, 010: MOSC, 100: HOCO
#define SLCDSCKCR_LCDSCKEN       7  // LCD Source Clock Out Enable; 0: LCD source clock out disabled, 1: LCD source clock out enabled
#define SYSTEM_MOCOUTCR   ((volatile unsigned char *)(SYSTEM + 0xE061))  // MOCO User Trimming Control Register
#define MOCOUTCR_MOCOUTRM_7_0   0  // MOCO User Trimming - See: 8.2.21
#define SYSTEM_HOCOUTCR   ((volatile unsigned char *)(SYSTEM + 0xE062))  // HOCO User Trimming Control Register
#define HOCOUTCR_HOCOUTRM_7_0   0  // HOCO User Trimming - See: 8.2.21
#define SYSTEM_MOSCWTCR ((volatile unsigned char *)(SYSTEM + 0xE0A2))  // Main Clock Oscillator Wait Control Register
#define MOSCWTCR_MSTS_3_0   0   // Main Clock Oscillator Wait Time Setting
#define SYSTEM_HOCOWTCR ((volatile unsigned char *)(SYSTEM + 0xE0A5))  // High-Speed On-Chip Oscillator Wait Control Register
#define HOCOWTCR_MSTS_2_0   0   // HOCO Wait Time Setting
#define SYSTEM_USBCKCR  ((volatile unsigned char *)(SYSTEM + 0xE0D0))  // USB Clock Control Register
#define USBCKCR_USBCLKSEL   0   // USB Clock Source Select; 0: PLL (value after reset), 1: HOCO
#define SYSTEM_MOMCR    ((volatile unsigned char *)(SYSTEM + 0xE413))  // Main Clock Oscillator Mode Oscillation Control Register
#define MOMCR_MODRV1        3   // Main Clock Oscillator Drive Capability 1 Switching; 0: 10 MHz to 20 MHz, 1: 1 MHz to 10 MHz
#define MOMCR_MOSEL         6   // Main Clock Oscillator Switching; 0: Resonator, 1: External clock input
#define SYSTEM_SOSCCR   ((volatile unsigned char *)(SYSTEM + 0xE480))  // Sub-Clock Oscillator Control Register
#define SOSCCR_SOSTP        0   // Sub-Clock Oscillator Stop; 0: Operate the sub-clock oscillator, 1: Stop the sub-clock osc
#define SYSTEM_SOMCR    ((volatile unsigned char *)(SYSTEM + 0xE481))  // Sub-Clock Oscillator Mode Control Register
#define SOMCR_SODRV_1_0     0   // Sub-Clock Oscillator Drive Capability Switching; 00: Normal, 01: Low-power 1, 10: Low-power 2, 11: Low-power 3
#define SYSTEM_LOCOCR   ((volatile unsigned char *)(SYSTEM + 0xE490))  // Low-Speed On-Chip Oscillator Control Register
#define LOCOCR_LCSTP        0   // LOCO Stop; 0: Operate the LOCO clock, 1: Stop the LOCO clock
#define SYSTEM_LOCOUTCR ((volatile unsigned char *)(SYSTEM + 0xE492))  // LOCO User Trimming Control Register
#define LOCOUTCR_LOCOUTRM_7_0   0  // LOCO User Trimming - See: 8.2.20
#define SYSTEM_RSTSR0   ((volatile unsigned char *)(SYSTEM + 0xE410))  // Reset Status Register 0
#define RSTSR0_PORF         0    // Power-On Reset Detect Flag
#define RSTSR0_LVD0RF       1    // Voltage Monitor 0 Reset Detect Flag
#define RSTSR0_LVD1RF       2    // Voltage Monitor 1 Reset Detect Flag
#define RSTSR0_LVD2RF       3    // Voltage Monitor 2 Reset Detect Flag
#define SYSTEM_RSTSR1   ((volatile unsigned char *)(SYSTEM + 0xE0C0))  // Reset Status Register 1
#define RSTSR1_IWDTRF       0    // Independent Watchdog Timer Reset Detect Flag
#define RSTSR1_WDTRF        1    // Watchdog Timer Reset Detect Flag
#define RSTSR1_SWRF         2    // Software Reset Detect Flag
#define SYSTEM_RSTSR2   ((volatile unsigned char *)(SYSTEM + 0xE411))  // Reset Status Register 2
#define RSTSR2_CWSF         0    // Cold/Warm Start Determination Flag - 0: Cold start, 1: Warm start
// Low Power Mode Control - See datasheet section 10
#define SYSTEM_SBYCR   ((volatile unsigned short *)(SYSTEM + 0xE00C))      // Standby Control Register
#define SYSTEM_MSTPCRA ((volatile unsigned int   *)(SYSTEM + 0xE01C))      // Module Stop Control Register A
#define MSTP 0x40040000 // Module Registers
#define MSTP_MSTPCRB   ((volatile unsigned int   *)(MSTP + 0x7000))      // Module Stop Control Register B
#define MSTPB2   2 // CAN0
#define MSTPB8   8 // IIC1
#define MSTPB9   9 // IIC0
#define MSTPB18 18 // SPI1
#define MSTPB19 19 // SPI0
#define MSTPB22 22 // SCI9
#define MSTPB29 29 // SCI2
#define MSTPB30 30 // SCI1
#define MSTPB31 31 // SCI0
#define MSTP_MSTPCRC   ((volatile unsigned int   *)(MSTP + 0x7004))      // Module Stop Control Register C
#define MSTP_MSTPCRD   ((volatile unsigned int   *)(MSTP + 0x7008))      // Module Stop Control Register D
#define MSTPD2   2 // AGT1   - Asynchronous General Purpose Timer 1 Module
#define MSTPD3   3 // AGT0   - Asynchronous General Purpose Timer 0 Module
#define MSTPD5   5 // GPT320 and GPT321 General 32 bit PWM Timer Module
#define MSTPD6   6 // GPT162 to GPT167 General 16 bit PWM Timer Module
#define MSTPD14 14 // POEG   - Port Output Enable for GPT Module Stop
#define MSTPD16 16 // ADC140 - 14-Bit A/D Converter Module
#define MSTPD19 19 // DAC8   -  8-Bit D/A Converter Module
#define MSTPD20 20 // DAC12  - 12-Bit D/A Converter Module
#define MSTPD29 29 // ACMPLP - Low-Power Analog Comparator Module
#define MSTPD31 31 // OPAMP  - Operational Amplifier Module
// The Mode Control bits are read as 1, the write value should be 1.
// Bit value 0: Cancel the module-stop state
// Bit value 1: Enter the module-stop state.
// =========== Ports ============
// 19.2.5 Port mn Pin Function Select Register (PmnPFS/PmnPFS_HA/PmnPFS_BY) (m = 0 to 9; n = 00 to 15)
// 32 bits - Use for setting pin functions to other than default pin I/O
#define P000PFS 0x0800  // Port 0 Pin Function Select Register
#define PFS_P000PFS ((volatile unsigned int *)(PORTBASE + P000PFS))            // A1 / D15 - AN00 - AMP0+ - IRQ6
#define PFS_P001PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 1 * 4))) // A2 / D16 - AN01 - AMP0- - IRQ7
#define PFS_P002PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 2 * 4))) // A3 / D17 - AN03 - AMP0O - IRQ2
#define PFS_P003PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 3 * 4))) // N/C - AN03
#define PFS_P004PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 4 * 4))) // N/C - AN04 - IRQ3
#define PFS_P005PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 5 * 4))) // N/A - AN11 - IRQ10
#define PFS_P006PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 6 * 4))) // N/A - AN12
#define PFS_P007PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 7 * 4))) // N/A - AN13
#define PFS_P008PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 8 * 4))) // N/A - AN14
// #define PFS_P009PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 9 * 4))) // Does not exist
#define PFS_P010PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (10 * 4))) // N/A - AN05
#define PFS_P011PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (11 * 4))) // N/C - AN06 - IRQ15
#define PFS_P012PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (12 * 4))) // TxLED - AN07
#define PFS_P013PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (13 * 4))) // RxLED - AN08
#define PFS_P014PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (14 * 4))) // A0 / D14 - AN09 - DAC0
#define PFS_P015PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (15 * 4))) // N/C - AN10 - IRQ7
#define P100PFS 0x0840  // Port 1 Pin Function Select Register
#define PFS_P100PFS ((volatile unsigned int *)(PORTBASE + P100PFS))            // A5 / D19 - MISOA - SCL1 - IRQ2
#define PFS_P101PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 1 * 4))) // A4 / D18 - MOSIA - SDA1 - IRQ1
#define PFS_P102PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 2 * 4))) // D5 - RSPCKA
#define PFS_P103PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 3 * 4))) // D4 - SSLA0
#define PFS_P104PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 4 * 4))) // D3 - IRQ1
#define PFS_P105PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 5 * 4))) // D2 - IRQ0
#define PFS_P106PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 6 * 4))) // D6
#define PFS_P107PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 7 * 4))) // D7
#define PFS_P108PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 8 * 4))) // SWD p2 SWDIO
#define PFS_P109PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 9 * 4))) // D11 / MOSI
#define PFS_P110PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (10 * 4))) // D12 / MISO - IRQ3
#define PFS_P111PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (11 * 4))) // D13 / SCLK - IRQ4
#define PFS_P112PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (12 * 4))) // D10 / CS
#define PFS_P113PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (13 * 4))) // N/C
#define PFS_P114PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (14 * 4))) // N/A
#define PFS_P115PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (15 * 4))) // N/A
#define P200PFS 0x0880  // Port 2 Pin Function Select Register
#define PFS_P200PFS ((volatile unsigned int *)(PORTBASE + P200PFS))           // NMI
#define PFS_P201PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (1 * 4))) // MD
#define PFS_P202PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (2 * 4))) // N/A
#define PFS_P203PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (3 * 4))) // N/A
#define PFS_P204PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (4 * 4))) // LOVE (Heart Pad on underside of board)
#define PFS_P205PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (5 * 4))) // N/C - IRQ1 - CLKOUT
#define PFS_P206PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (6 * 4))) // N/C - IRQ0
// Pins P212, P213, P214, and P215 are Crystal functions, or N/C
#define PORTBASE 0x40040000 // Port Base
#define PFS_P100PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843))   // 8 bits - A5
#define PFS_P101PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 1 * 4))) // A4
#define PFS_P102PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 2 * 4))) // D5
#define PFS_P103PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 3 * 4))) // D4
#define PFS_P104PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 4 * 4))) // D3
#define PFS_P105PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 5 * 4))) // D2
#define PFS_P106PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 6 * 4))) // D6
#define PFS_P107PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 7 * 4))) // D7
#define PFS_P108PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 8 * 4))) // SWDIO
#define PFS_P109PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 9 * 4))) // D11 / MOSI
#define PFS_P110PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + (10 * 4))) // D12 / MISO
#define PFS_P111PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + (11 * 4))) // D13 / SCLK
#define PFS_P112PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + (12 * 4))) // D10 / CS
#define PFS_P300PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3))            // SWCLK (P300)
#define PFS_P301PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3 + (01 * 4))) // D0 / RxD (P301)
#define PFS_P302PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3 + (02 * 4))) // D1 / TxD (P302)
#define PFS_P303PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3 + (03 * 4))) // D9
#define PFS_P304PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3 + (04 * 4))) // D8
// ====  Asynchronous General Purpose Timer (AGT) =====
#define AGTBASE 0x40084000
#define AGT0_AGT    ((volatile unsigned short *)(AGTBASE))         // AGT Counter Register
#define AGT1_AGT    ((volatile unsigned short *)(AGTBASE + 0x100))
#define AGT0_AGTCMA ((volatile unsigned short *)(AGTBASE + 0x002)) // AGT Compare Match A Register
#define AGT1_AGTCMA ((volatile unsigned short *)(AGTBASE + 0x102))
#define AGT0_AGTCMB ((volatile unsigned short *)(AGTBASE + 0x004)) // AGT Compare Match B Register
#define AGT1_AGTCMB ((volatile unsigned short *)(AGTBASE + 0x104))
// 8 bit registers
#define AGT0_AGTCR    ((volatile unsigned char  *)(AGTBASE + 0x008))  // AGT Control Register
#define AGT1_AGTCR    ((volatile unsigned char  *)(AGTBASE + 0x108))  //
#define AGTCR_TSTART 0  // R/W - AGT Count Start; 1: Count starts, 0: Count stops
#define AGTCR_TCSTF  1  // R   - AGT Count Status Flag; 1: Count in progress, 0: Count is stopped
#define AGTCR_TSTOP  2  // W   - AGT Count Forced Stop; 1: The count is forcibly stopped, 0: Writing 0 is invalid!!!
#define AGT0_AGTMR1   ((volatile unsigned char  *)(AGTBASE + 0x009))  // AGT Mode Register 1
#define AGT1_AGTMR1   ((volatile unsigned char  *)(AGTBASE + 0x109))  //
#define AGT0_AGTMR2   ((volatile unsigned char  *)(AGTBASE + 0x00A))  // AGT Mode Register 2
#define AGT1_AGTMR2   ((volatile unsigned char  *)(AGTBASE + 0x10A))  //
#define AGT0_AGTIOC   ((volatile unsigned char  *)(AGTBASE + 0x00C))  // AGT I/O Control Register
#define AGT1_AGTIOC   ((volatile unsigned char  *)(AGTBASE + 0x10C))  //
#define AGTIOC_TOE   2  // AGTOn Output Enable
#define AGT0_AGTISR   ((volatile unsigned char  *)(AGTBASE + 0x00D))  // AGT Event Pin Select Register
#define AGT1_AGTISR   ((volatile unsigned char  *)(AGTBASE + 0x10D))  //
#define AGT0_AGTCMSR  ((volatile unsigned char  *)(AGTBASE + 0x00E))  // AGT Compare Match Function Select Register
#define AGT1_AGTCMSR  ((volatile unsigned char  *)(AGTBASE + 0x10E))  //
#define AGT0_AGTIOSEL ((volatile unsigned char  *)(AGTBASE + 0x00F))  // AGT Pin Select Register
#define AGT1_AGTIOSEL ((volatile unsigned char  *)(AGTBASE + 0x10F))  //
// 12-Bit D/A Converter
#define DACBASE 0x40050000          // DAC Base - DAC output on A0 (P014 AN09 DAC)
#define DAC12_DADR0    ((volatile unsigned short *)(DACBASE + 0xE000))      // D/A Data Register 0
#define DAC12_DACR     ((volatile unsigned char  *)(DACBASE + 0xE004))      // D/A Control Register
#define DAC12_DADPR    ((volatile unsigned char  *)(DACBASE + 0xE005))      // DADR0 Format Select Register
#define DAC12_DAADSCR  ((volatile unsigned char  *)(DACBASE + 0xE006))      // D/A A/D Synchronous Start Control Register
#define DAC12_DAVREFCR ((volatile unsigned char  *)(DACBASE + 0xE007))      // D/A VREF Control Register
// === Local Defines
#define MAIN_CLOCK_MHz      48.00        // Set in multiples of 6 MHz i.e. 48, 54, 60, 66
#define EXT_CLOCK_MHz       12.00        // Set to external input or XTAL frequency
#define AGT0_RELOAD_48MHz   2999      // AGT0 value to give 1mS / 1kHz - with 48.0MHz/2 PCLKB
#define AGT0_RELOAD_50MHz   3124      // AGT0 value to give 1mS / 1kHz - with 50.0MHz/2 PCLKB
#define AGT0_RELOAD_55MHz   3436      // AGT0 value to give 1mS / 1kHz - with 55.0MHz/2 PCLKB - Note runs sligtly fast
#define AGT0_RELOAD_60MHz   3749      // AGT0 value to give 1mS / 1kHz - with 60.0MHz/2 PCLKB
// #define AGT0_RELOAD  AGT0_RELOAD_60MHz
#define AGT0_RELOAD  (int)((62.5 * MAIN_CLOCK_MHz ) - 1)
#define CLOCK_PLL      // Use with external clock
#define CLKOUT         // Enable clock_monitor on D11 to confirm external-clock source is active
#define DAC_RIGHT_JUST
#define FREQ_UPDATE_INTERVAL 0x04000000   // use a 0x01, 02, 04, 08 value for MSB - 0x04 gives c. 15.6 Hz
#define MIN_PLL_MULTI   1
#define MAX_PLL_MULTI  31
uint32_t currentMillis  = 0x0;
uint32_t previousMillis = 0x0;
uint32_t lastMillis = 0x0;
uint32_t print_interval_secs = 60;
uint32_t secondsCount = 0;
bool minute_flag = false;
uint16_t agt_reload_val = AGT0_RELOAD;
char pll_multiplier = 9;
char pll_divider = 2;
static bool ext_clk_good = false;
static bool wake_from_int_flag = false;
  Serial.begin(115200);      // The interrupts for the USB serial are already in place before setup() starts
  while (!Serial){};         //
  clock_pll_commands();
  setup_dac();
#ifdef CLKOUT
  sys_clock_monitor(false);
#endif
  previousMillis = lastMillis = currentMillis = millis();
  *PFS_P111PFS_BY = 0x04;        // D13 - CLEAR LED
  if(wake_from_int_flag == true)
    asm volatile("wfi");           // Stop here and wait for an interrupt
  *PFS_P111PFS_BY = 0x05;        // D13 - Set LED
  if((currentMillis - lastMillis) >= 1)  // Only do an update once per mS
   	lastMillis = currentMillis;
    calc_sine();
  if((currentMillis - previousMillis) >= 1000)
    secondsCount++;
    Serial.print(".");          // print a "." once per second - Proof of Life !
    if(secondsCount >= 60)  //
      secondsCount = 0;
      minute_flag = true;       // Change flag to Blip a LED
      if(ext_clk_good == true)
        Serial.print("\nClock = ");
        if(pll_divider == 2)
          Serial.println((float)(pll_multiplier + 1) * (float)(EXT_CLOCK_MHz / 2));
          Serial.println((float)(pll_multiplier + 1) * (float)(EXT_CLOCK_MHz / 4));
        Serial.println("\nHOCO Clock");
  if(Serial.available() > 0)
    char input_char = Serial.read();  // get one byte from serial buffer
    Serial.println(input_char);
    switch(input_char)
      case '2':
        if(pll_divider == 4)
          pll_divider = 2;
          pll_multiplier = (pll_multiplier >> 1);   // As in /2
          set_sys_clock_hoco();                     // Set to HOCO first before changing PLL settings
          ext_clk_good = sys_clock_pll_setup(pll_multiplier, pll_divider);
          secondsCount = 0;
            wake_from_int_flag = true;
//            sys_clock_monitor(ext_clk_good);
      case '4':
          pll_divider = 4;
          pll_multiplier = (pll_multiplier << 1);   // As in *2
          secondsCount = 0;
      case '+':
        pll_multiplier++;
        if(pll_multiplier > MAX_PLL_MULTI)
          pll_multiplier = MAX_PLL_MULTI;
        secondsCount = 0;
      case '-':
        pll_multiplier--;
        if(pll_multiplier < MIN_PLL_MULTI)
          pll_multiplier = MIN_PLL_MULTI;
        secondsCount = 0;
      case 's':
        pll_multiplier = (char)((MAIN_CLOCK_MHz / (float)(EXT_CLOCK_MHz / 2)) - 1);
        pll_divider = 2;
          Serial.println("Ext Clock Running.");
          Serial.println("No Ext Clock.");
        secondsCount = 0;
      case 'r':
        set_sys_clock_hoco();             // Change back to HOCO
        Serial.println("\nHOCO System clock");
        pll_multiplier = (int)((MAIN_CLOCK_MHz / (float)(EXT_CLOCK_MHz / 2)) - 1);  // Return to base PLL setting
        pll_divider = 2;
        *AGT0_AGT = AGT0_RELOAD_48MHz;
        secondsCount = 0;
        wake_from_int_flag = false;       // Disable WFI, otherwsie double tap on Reset-Button needed
      case '?':
      default:
void clock_pll_commands(void)
  Serial.println("\nPLL Clock Test");
  Serial.println("Code starts with Internal HOCO Clock");
  Serial.println("PLL Clocking uses Wake-From-Interrupt");
  Serial.println("Single Char Clock Update PLL Commands");
  Serial.println("s = Start PLL Clocking with /2 & *10 settings");
  Serial.println("r = Return to HOCO 48MHz Clocking");
  Serial.println("+ = Increase PLL Multiplier by 1");
  Serial.println("- = Decrease PLL Multiplier by 1");
  Serial.println("2 = Use /2 PLL Divider");
  Serial.println("4 = Use /4 PLL Divider");
  Serial.println("? = This Help List");
void calc_sine()
          int32_t out, a , b;
          int32_t result_taylor_sine;
   static int32_t sine_amp_local = 0x7FFFFFFF;
  static uint32_t freq_time_accumulate = 0;
//  static uint32_t freq_time_delta = 0x1 << 24;  //
  static uint32_t freq_time_delta = 0x1 << 18;  // Using a shift makes sure 0x1 value gives static repeating waveform
          int16_t result_sine;
  int32_t angle, sum, p1, p2, p3, p5, p7, p9, p11, term;
  uint32_t ph;
  uint16_t analog_write_value;
  freq_time_accumulate += FREQ_UPDATE_INTERVAL;   // Core DDS frequency-synthesis incriment
  if (freq_time_accumulate >= 0xC0000000u || freq_time_accumulate < 0x40000000u)
    *PFS_P103PFS_BY = 0x05;      // Pulse on D4 to trigger scope
    angle = (int32_t)freq_time_accumulate; // valid from -90 to +90 degrees
    *PFS_P103PFS_BY = 0x04;      // Each Port Output bit clear or set takes c. 83nS
    angle = (int32_t)(0x7FFFFFFFu - freq_time_accumulate);
  term = angle << 1;
	asm volatile("smmulr %0, %1, %2" : "=r" (p1) : "r" (term), "r" (1686629713));
	asm volatile("smmulr %0, %1, %2" : "=r" (term) : "r" (p1), "r" (p1));
  p2 = term << 3;
	asm volatile("smmulr %0, %1, %2" : "=r" (term) : "r" (p2), "r" (p1));
  p3 = term << 3;
  term = p1 << 1;
	asm volatile("smmlsr %0, %2, %3, %1" : "=r" (sum) : "r" (term), "r" (p3), "r" (1431655765));
	asm volatile("smmulr %0, %1, %2" : "=r" (term) : "r" (p3), "r" (p2));
  p5 = term << 1;
	asm volatile("smmlar %0, %2, %3, %1" : "=r" (sum) : "r" (sum), "r" (p5), "r" (286331153));
	asm volatile("smmulr %0, %1, %2" : "=r" (p7) : "r" (p5), "r" (p2));
	asm volatile("smmlsr %0, %2, %3, %1" : "=r" (sum) : "r" (sum), "r" (p7), "r" (54539267));
// Uncommet this for 25bit precision calculation
	asm volatile("smmulr %0, %1, %2" : "=r" (p9) : "r" (p7), "r" (p2));
	asm volatile("smmlar %0, %2, %3, %1" : "=r" (sum) : "r" (sum), "r" (p9), "r" (6059919));
	asm volatile("smmulr %0, %1, %2" : "=r" (p11) : "r" (p9), "r" (p2));
	asm volatile("smmlsr %0, %2, %3, %1" : "=r" (sum) : "r" (sum), "r" (p11), "r" (440721));
  result_taylor_sine = sum << 1;
#ifdef DAC_RIGHT_JUST
  result_sine = (int16_t)(result_taylor_sine >> 20);   // 32 - 12 = 20
  *DAC12_DADR0 = result_sine + 2048;
#else
  result_sine = (int16_t)(result_taylor_sine >> 16);   //
  *DAC12_DADR0 = result_sine + 32767;
#endif
void setup_dac(void)       // Note make sure ADC is stopped before setup DAC
  *MSTP_MSTPCRD &= (0xFFFFFFFF - (0x01 << MSTPD20));  // Enable DAC12 module
  *DAC12_DADPR    = 0x00;        // DADR0 Format Select Register - Set right-justified format
#else
  *DAC12_DADPR    = 0x80;        // DADR0 Format Select Register - Set left-justified format i.e. 16 bit format, 4 LSBs not used
#endif
//  *DAC12_DAADSCR  = 0x80;        // D/A A/D Synchronous Start Control Register - Enable
  *DAC12_DAADSCR  = 0x00;        // D/A A/D Synchronous Start Control Register - Default
// 36.3.2 Notes on Using the Internal Reference Voltage as the Reference Voltage
  *DAC12_DAVREFCR = 0x00;        // D/A VREF Control Register - Write 0x00 first - see 36.2.5
  *DAC12_DADR0    = 0x0000;      // D/A Data Register 0
   delayMicroseconds(10);
  *DAC12_DAVREFCR = 0x01;        // D/A VREF Control Register - Select AVCC0/AVSS0 for Vref
//  *DAC12_DAVREFCR = 0x03;        // D/A VREF Control Register - Select Internal reference voltage/AVSS0
//  *DAC12_DAVREFCR = 0x06;        // D/A VREF Control Register - Select External Vref; set VREFH&L pins used for LEDs
  *DAC12_DACR     = 0x5F;        // D/A Control Register -
   delayMicroseconds(5);         //
  *DAC12_DADR0    = 0x0800;      // D/A Data Register 0
  *PFS_P014PFS   = 0x00000000;   // Make sure all cleared
  *PFS_P014PFS  |= (0x1 << 15);  // Port Mode Control - Used as an analog pin
void set_sys_clock_hoco(void)         // Set to HOCOfirst before changing PLL settings
  *SYSTEM_SCKSCR     = 0x00;          // Select HOCO as the system clock
bool sys_clock_pll_setup(char pll_set_val, char pll_div_val)
  Serial.println("Setup MOSC - External Clock & PLL");
  *SYSTEM_MOSCCR   = 0x01;            // Make sure MOSC is stopped - 8.2.6
//  The External Input EXTAL mode does not work, leave as resonator.
//  *SYSTEM_MOMCR    = 0x40;            // MOSEL - Main Clock Oscillator Switching - 1: External clock input - 8.2.17
  *SYSTEM_MOMCR    = 0x00;            // MOSEL - Main Clock Oscillator Switching - 0: Resonator - 8.2.17
  *SYSTEM_MOSCWTCR = 0x00;            // Set stability timeout period - With External Clock not required
	asm volatile("dsb");                // Data bus Synchronization instruction
  *SYSTEM_MOSCCR   = 0x00;            // Enable External Clock
  delay(100);                         // wait for XTAL to stabilise
  char enable_ok = *SYSTEM_MOSCCR;    // Check bit
  Serial.print("SYSTEM_MOSCCR = ");
  if((int)enable_ok == 0)
    Serial.println("0: Main clock oscillator is operating");
    Serial.println("1: Main clock oscillator is stopped");
    return(false);
// PLL Setup - See Datasheet 8.2.3 and 8.2.4
  *SYSTEM_PLLCR    = 0x01;              // Disable PLL
  delayMicroseconds(4);                 // wait for PLL to stop
  *SYSTEM_PLLCCR2  = pll_div_val << 5;              // Setup PLLCCR2_PLODIV_1_0 PLL Output Frequency Division to /2
  Serial.print("PLL Divider = ");                   // 00000010 << 5 = 01000000
  Serial.println((*SYSTEM_PLLCCR2 & 0xC0) >> 5);
  *SYSTEM_PLLCCR2 |= pll_set_val;       // Setup PLLCCR2_PLLMUL_4_0 PLL PLL Frequency Multiplication
  Serial.print("PLL Frequency Multiplication = ");
  Serial.println((*SYSTEM_PLLCCR2 & 0x1F)+1);
  delayMicroseconds(1);               // wait for PLL config change
  *SYSTEM_PLLCR    = 0x00;            // Enable PLL
  delayMicroseconds(1000);            // wait for PLL to stabilise
  Serial.print("Change System Clock source from ");
  Serial.print(*SYSTEM_SCKSCR);
  Serial.print(" to ");
  *SYSTEM_SCKSCR   = 0x05;            // Select PLL as the system clock
  Serial.println(*SYSTEM_SCKSCR);
  enable_ok = *SYSTEM_OSTDSR;    // Check bit
  Serial.print("SYSTEM_OSTDSR = ");
    Serial.println("0: Main clock oscillation stop not detected");
    Serial.println("1: Main clock oscillation stop detected");
  Serial.print("Clock = ");
  if(pll_div_val == 2)
  Serial.print("AGT0_RELOAD = ");
  if(pll_div_val == 2)                //  Calculate value for AGT0 mS counter 1mS update rate
    agt_reload_val = (short int)((62.5 * ((pll_multiplier + 1) * (float)(EXT_CLOCK_MHz / 2)) ) - 1);
    *AGT0_AGT = agt_reload_val;
    Serial.println(agt_reload_val);  // Print value NOT register as this will aleady have decrimented
    agt_reload_val = (short int)((62.5 * ((pll_multiplier + 1) * (float)(EXT_CLOCK_MHz / 4)) ) - 1);
  return(true);
void sys_clock_monitor(bool source_flag)
#ifdef CLKOUT
  Serial.println("System Clock Monitor on D11");
  if(source_flag == true)
    *SYSTEM_CKOCR  =  0b00000011;     // Divide by 0, MOSC source
    *SYSTEM_CKOCR  =  0b00100000;     // Divide by 4, HOCO source
  *PFS_P109PFS   = (0b01001 << 24);   // Select PSEL[4:0] for CLKOUT - See Table 19.7
  *SYSTEM_CKOCR |=  0b10000000;       // Enable Output
  *PFS_P109PFS  |= (0x1 << 16);       // Port Mode Control - Used as an I/O port for peripheral function
#endif
Pic of HOCO>PLL setup - I have a small chip surface mount 220pF capacitor mounted across two of the crystal footprint pads.
I will take a look today
@susan-parker
Hi Susan,
ok for the AGT used for millis() and for the USB (using the HOCO), but ... what happens to UARTs and GPTs used for PWMs? Are corrections necessary there as well? :thinking:
Guglielmo
Yes, everything will run faster - some modules in the chip may NOT work at the higher speeds.
This code is a demo that the processor-core can be easily over or underclocked.
If one is going to run at 96MHz, then the easy way to keep everything the same is to update
8.2.1 System Clock Division Control Register (SCKDIVCR)
... by increasing the PCLKA/B/C/D divider ratios.
See:
Table 8.2 Clock generation circuit specifications for the internal clocks
... for what clocks what.
Faster SPI might be nice though! :slight_smile:
The Code Flash Interface seems to be running okay - but the Data Flash part would need testing:
Table 44.1 Specifications of the code flash memory and data flash memory
... I suspect that might be iffy - but it's easy enough to drop back to 48MHz if one was doing updates. It's not RAM, so it can't be used for variable storage etc, i.e. stuff that changes often.
Perfect, thanks ... I'm going to do some testing :grin:
Guglielmo
