I want void temp to not follow void running, what should I add, break or delay?
#include <OneWire.h>
#include <DallasTemperature.h>
OneWire pin_DS18B20(5);
DallasTemperature DS18B20(&pin_DS18B20);
#include <SPI.h>
#include <DMD.h>
#include <TimerOne.h>
#include "SystemFont5x7.h"
#include "Arial_black_16.h"
#include "Arial14.h"
#define DISPLAYS_ACROSS 1
#define DISPLAYS_DOWN 1
String str;
char b[8];
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
unsigned long previousMillis1 = 0;
const long interval1 = 1000;
void ScanDMD(){
dmd.scanDisplayBySPI();
Timer1.initialize(5000);
Timer1.attachInterrupt(ScanDMD);
dmd.clearScreen(true);
DS18B20.begin();
running();
temp();
void running() {
int slen=0;
dmd.selectFont(SystemFont5x7);
str = "TEMP";
slen = str.length()+1;
str.toCharArray(b, slen );
dmd.drawMarquee( b, slen, (32*DISPLAYS_ACROSS)-1 ,1); //32 is the board size
unsigned long timing = millis();
boolean flag = false;
while (!flag) {
if ((timing + 70) < millis()) {
flag = dmd.stepMarquee(-1, 0);
timing = millis();
void temp() {
DS18B20.requestTemperatures();
if(millis() - previousMillis1 >= interval1) {
previousMillis1 = millis();
dmd.clearScreen( true );
str=DS18B20.getTempCByIndex(0);
slen= str.length()+1;
str.toCharArray(b,slen);
dmd.drawString(1,8,b,slen,GRAPHICS_NORMAL);
Then don't call it after calling the running() function
running();
// temp();
When do you want to call the temp() function, if ever ?
I want to make the first 2 text views and the second text then between the 2 texts I want one of them to be animated with running text
b707
January 29, 2023, 12:57pm
4
You start request of temperature on each call of the loop(). It hasn't time to measure.
Request temperature only AFTER reading it
bimosora:
void temp() {
// DS18B20.requestTemperatures(); // you don;t need this line in this place, move it inside if condition
DS18B20.requestTemperatures(); // << move request there
Pay attention to the picture, void temp also goes to the left even though there is no marquee code in void temp
b707
January 29, 2023, 1:13pm
6
What is you mean as "void temp" ? Are you understand what is "void" in C language?
b707
January 29, 2023, 1:15pm
7
indeed!
This library shift entire screen if you use marquee code anywhere in the screen
With that library I want to move the text "hello" from right to left, how do I do that?
b707
January 29, 2023, 1:29pm
9
Do not use marquee function. Move the text manually.
On each step clear "Hello" and print it again 1 pix left
I don't know how the code does that
b707
January 29, 2023, 2:18pm
11
I don't know another way to do what you want, sorry.
The library don't supports the running text on the part of screen
Try other libraries... in another thread you already asked about this
This is what I want, the top one is stationary and the bottom one is moving
b707
January 29, 2023, 2:42pm
13
It possible, but you have to program it yourself.
See this as example ( the library is not suited for you, but the code almost the same)
opened 11:30AM - 29 Nov 22 UTC
closed 08:59PM - 26 Jan 23 UTC
I TRY YOUR CODE TOP-LINE SCROLLING AND BOTTOM-LINE STRING MESSAGE
HOW TO REMOVE… BACKGROUND COLOUR AND FLICKERING?
PLEASE SUGGEST A CODE HERE.
void loop(void)
// create foreground colors
uint16_t col[] = {
dmd.Color888(255,0, 0), // red
dmd.Color888(0, 255, 0), // green
dmd.Color888(0, 0, 255) // blue
uint16_t bg = 0; // background - black
int col_cnt = 3; // color count
// text
char s[] = " MURUGAN CHENNAI";
// transcode message to UTF for use with GFX fonts
char k[30];
utf8_rus(k, (const unsigned char*)s);
char* m = s;
// select standard font
dmd.selectFont(&UkrRusArial_F);
// set text foreground and background colors
dmd.setTextColor(col[0], bg);
// shift steps in pixels for running text (positive - shift right, negative - left)
// running text shift interval
uint16_t interval = 25;
long prev_step = millis();
dmd.setBrightness(200);
// Cycle for tests:
// -- running texts moving at x and y axis with single and double speed
// -- vertical scrolling message
while (1) {
if ((millis() - prev_step) > interval)
dmd.drawString(8,16,"12:34:56",8,col[1]); //- fixed messAGE USED FOR CLOCK OR DATE USING DS3231
if (dmd.stepMarquee(-1, 0) & 1) { // if text is reached screen bounds
dmd.drawMarqueeX(m, 0,0);
// output mem buffer to matrix
dmd.swapBuffers(true);
Also the library is not support the marquee on the part of screen as DMD.h you used, but see on the last video of thread - lower text moving independently to upper
Don't support the DMD32 and DMD2 libraries as I provided in the image above?
b707
January 29, 2023, 3:08pm
15
Sorry, i don't understand you, my English is weak.
Please reformulate your question.
Is it true that DMD32 and DMD2 also can't make the writes go the way I want them to?
b707
January 29, 2023, 3:30pm
17
About DMD2.h I don't know exactly, but suggest so.
What is the library DMD32? Are you mean DMD_STM32 ? - yes, it doesn't support what you want.
So all the libraries don't support what I'm saying?
I saw from YouTube that something could be in the library and he wrote it like this
int slen = 0;
str = "TEMP";
str.toCharArray(b,8);
j=strlen(b)+(strlen(b)*5);
i--;
dmd.drawString(i, 9, b, strlen(b), GRAPHICS_NORMAL);
if (i<=~j) {
i=32;
sr++;
if (sr>2) sr=1;
Here's a video I found
Led scrolling display board | led display board | P10 module | led clock | Arduino uno | Rtc module
b707
January 29, 2023, 10:00pm
20
bimosora:
As can I see in your code snippet, the man do it the same as I advised you in post above - he move the string by drawing it with drawString() time by time:
bimosora:
It is exactly what I meant....
