With apologies if I have missed the solution.
Arduino 2.3.3
Board ESP32C3 Dev Module
Preferences "additional boards manager URLs :https://espressif.github.io/arduino-esp32/package_esp32_index.json
results in "downloading index...." going to about 3/4 and stopping, apparently forever. No error, just doesn't load.
What am I doing wrong?
If I delete it, it hangs downloading index:package_index.tar.bz2, whatever that is.
Thanks in advance
I had the same problem. I originally stored my sketches on D:/Projects. After allowing Arduino to updating new libraries and boards it got stuck. After copying the sketches to C:/users/ "myName"/Arduino/, everything was fine.
Hi all. It was found that Arduino IDE 2.3.3 has a bug that causes index downloads and installation/updates of boards platforms libraries to hang when Serial Monitor is open.
If you encounter these problems, the workaround is to close the Serial Monitor view until the process is finished. After that, you can open Serial Monitor again.
The Serial Monitor view is a tab in the bottom panel of the Arduino IDE window, so you might not even notice when you have it open. You can close it by clicking the X icon on the tab:
The Arduino developers are tracking the bug here:
If you have a GitHub account, you can subscribe to that thread to get notifications of any new developments related to this subject:
Please only comment on the GitHub issue thread if you have new technical information that will assist with the resolution. General discussion and support requests are always welcome here on the Arduino Forum.
to solve the problem i open a other project that uses an esp8266 (can be as ample as blink.ino) than the upload of esp32 stops. Than without quit arduino, i open again my esp32 project. (note: the esp32load problem happens even the serial monitor is closed)
Trying to compile a Nano sketch it stays so long downloading Package_esp32_index.json and never ends... Can anyone help me? I´m working with 2.3.3 version for windows
FWIW I simply downgraded to 2.3.2 and all is working fine. I don't recall what 2.3.3 was supposed to add but whatever it was, I don't have any issues without it.
