Hello and thank you for taking the time to read this.
We are an Arcade game manufacturer and need someone to
write an arduino script or code or arduino project thing that
will tell a ticket dispenser when to give tickets out.
We are trying to incorporate this with one of our arcade racer pairs. The ticket dispenser has a 12v and a ground and a in and a out so four wires. Our only problem is how
the arduino is going to know to tell the ticket dispenser
when to kick out tickets and we can keep it simple and just
dispense tickets after a set time or it would be ideal to have
it dispense tickets when the winner of the race finishes.
Game in mind is Daytona or Mario Kart or something like that. Please send me a message or email me at tech2@creative-arcades.com Cash money for this project.
Thank you.
When the race ends, does anything happen visually or physically on the cabinet — a light that comes on, a screen that changes, a sound that plays, or a motor/solenoid that activates? Any of those is likely driven by a signal wire that the Arduino could tap into and listen for.
I dont think so. Basically the winner gets first place and other player gets second but there is no sound or flash or anything that happens differently. Unless you can find something. The three games on the cabinet are going to be
DAYTONA, OUTRUN 2, and Mario Kart
Is it using Model 2 hardware? I went through the technical manual and didn't see anything that performed any output function when the game ended. You might have to settle for dispensing tickets a random time after starting. Which should be easy enough but probably not ideal.
Is it specialized hardware or do you have a regular PC in the cabinet ? Isn’t Mario Kart only for Nintendo and their hardware ?
➜ what does actually run and are those legit licenses ?
I'd go for a linux sbc (raspberrypi/orangepi/...) and make it detect each games winning screen.
Hi, I’m Petros from Softlution. I can help with the Arduino controller and ticket-dispenser interface, including a timed mode and checking whether the cabinet exposes a usable race-finish signal. Which controller or hardware runs your current cabinets? https://product-prototype.com/
Hi, still need this? Most arcade ticket dispensers work the same way: you pull the input line low to run the motor, and the output (notch sensor) pulses once per ticket. So an Arduino Nano plus an optocoupler and a small transistor can dispense an exact number of tickets and count them so it never over-pays.
Since the cabinet doesn't give a "race finished" signal, the easiest version is: dispense X tickets after each credit or after a set time per game. If you want it tied to winning, there may be a way to tap a lamp or sound signal, but that needs a look at the board.
Can you send a photo of the dispenser's label/model and the 4 wires? Then I can give you an exact price.
My work and client reviews: https://gleeful-starlight-a67a5c.netlify.app
Orders with protected payment: LAMI - Embedded Firmware PCB Engineer STM32 ESP32 Motor Control | Profile | Fiverr
