Paid gig for arduino led controller, build and coding
I need an arduino built that can perform a few basic functions: Illuminate a series of roughly 600 leds when the arduino is powered up. Also, provide power to the led rings around each of 10 momentary buttons. Default setting: Solid color for full led array- blue, full brightness That array of 600 or so leds will be broken down into 10 segments of roughly 60 lights. Each segment will have a momentary switch assigned to it for a total of 10 segments and 10 switches associated with each. One button for one of the 10 leg segments. When short pressed the leds in that specific section will change from blue, full brightness to red, full brightness steady on. Lights will continue to stay, steady on, in this configuration until another momentary switch is pressed and then the corresponding led segment to that switch will turn red and the previously red section will revert back to blue.
Second function: If any switch is pressed and held for more than 5 seconds, all leds in the array will turn white and an internal timer will begin. One by one, each led in sequence, will turn off until 2 minutes has elapsed and all leds are off. The final 20 seconds of the timer will result in the remaining leds that are counting down changing to red and strobing rapidly to indicate time is running out. The leds previouslt turned off will stay off and the remaining lit leds will continue to turn off, one by one, while strobing until switched off. Once all leds are out and the timer has expired the led array will return to the default setting of 9 segments being blue and one being red awaiting the next short press and change of position. The video found at the following link is similar to what I am looking to achieve, although my needs are far less complicated:
Looking to pay for prototype assembly and programming.
Located in North East Florida
Hi, this is still open for bids.
It might help if you post your budget.
Hello,
I can certainly help you with this. Are you going to be using the LED strips like shown in the Video or do you want some sort of custom mounting ?
Is this a single build project or do you intend to take into production for either large or small quantities.
I can offer my services to write the firmware, design and fabricate any custom hardware deliver a proof of concept model and then get the units into production.
I am British living in France with a customer base across Europe, Asia, and the USA.
I have just finished up a project working with Universal Studios at their Osaka and Beijing resorts to control the audio on the parade systems.
Please feel free to reach out to me if you have any questions.
Cheers Pete.
Thank you Pete. This is just for personal use. I have no plans or desires to produce them for retail. The lights are already mounted as you see in the video, under the armrail on the poker table.
OK so do you want to tell me a bit more about the existing lights on the table.
Are they a string of neopixels ?
Is it your intention to replace an existing controller or create a new system ?
You can take this to personal Email if you dont want the details here in the public forum.
Cheers Pete.
Govee 32.8ft LED Strip Lights... Amazon.com
These are the LEDs used. My idea was to create a new controller to attach to the LEDs in place.
Taking a quick look at these, the LEDs are not individually addressable but come in blocks. This would limit the resolution of the display. Also it comes with a proprietary controller that would need to be reversed engineered to make it work with an Arduino. For a fully addressable strip you need to be looking at a neopixel LED strip.
Perhaps something more like this
So if I purchase these LEDs can you incorporate a controller to power and run the program?
I thought I did when I posted the job. I honestly dont have any idea what something like this should cost, so Im hoping to get multiple bids.
Yes, it is. Thanks!
