I am having issues with the NewSoftSerial library and my RFID reader.
Using the built in SoftwareSerial library it works but I can't use that library and NewSoftSerial I can use.
However, even in the most basic sketch I can't get it to work reliably.
Code is here
#include <NewSoftSerial.h>
int val = 0;
char code[10];
int bytesread = 0;
#define rxPin 7
#define txPin 8
// RFID reader SOUT pin connected to Serial RX pin at 2400bps to pin7
Serial.begin(9600); // Hardware serial for Monitor 9600bps
pinMode(txPin,OUTPUT); // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(txPin, LOW); // Activate the RFID reader
NewSoftSerial RFID = NewSoftSerial(rxPin,53);
RFID.begin(2400);
if((val = RFID.read()) == 10)
{ // check for header
bytesread = 0;
while(bytesread<10)
{ // read 10 digit code
val = RFID.read();
if((val == 10)||(val == 13))
{ // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if(bytesread == 10)
{ // if 10 digit read is complete
Serial.print("TAG code is: "); // possibly a good TAG
Serial.println(code); // print the TAG code
bytesread = 0;
delay(1000); // wait for a second
The output I'm getting looks like this
TAG code is: ÿÿÿÿÿÿÿÿÿÿ
TAG code is: 124070FDA3
As you can see sometimes it's correct, and other times it's wrong. If i change the delay to less it seems to get worse, but I don't want to have to use delay at all. I can use debouncing to add the delay in, but I still wouldn't have to hold my tag up the the reader for 3 seconds to get a good read every time.
They are grounded together, cable is about 16 inches long.
Code changed to
int val = 0;
char code[10];
int bytesread = 0;
#define rxPin 7
#define txPin 8
RFID.begin(2400);
bytesread = 0;
while(bytesread<10)
val = RFID.read();
if(bytesread == 10)
bytesread = 0;
I still can't say why you're getting the dotted-y's but I did spot one other problem in the Sketch...
int val = 0;
char code[[glow]11[/glow]]; // <-- need space for the terminator
int bytesread = 0;
#define rxPin 7
#define txPin 8
RFID.begin(2400);
bytesread = 0;
while(bytesread<10)
val = RFID.read();
if(bytesread == 10)
[glow]code[bytesread+1] = 0; // <-- need to terminate the string[/glow]
bytesread = 0;
If I change and use SoftwareSerial with code like this
//#include <NewSoftSerial.h>
#include <SoftwareSerial.h>
int val = 0;
char code[11];
int bytesread = 0;
#define rxPin 7
#define txPin 8
//NewSoftSerial RFID = NewSoftSerial(rxPin,53);
SoftwareSerial RFID = SoftwareSerial(rxPin,53);
RFID.begin(2400);
bytesread = 0;
while(bytesread<10)
val = RFID.read();
if(bytesread == 10)
code[bytesread] = 0; // <-- need to terminate the string
bytesread = 0;
// delay(1000); // wait for a second
it works perfect. That leads me to believe there is something wrong in the NewSoftSerial library.
Sounds like it. There haven't been any similar complaints which makes me suspect the problem is with the baud rate (2400). Probably the bit time calculation.
Every time I use the SoftwareSerial library it holds the sketch waiting for serial data. I need other things to happen while there isn't any data. Also I want to have more then one thing connected via serial later on down the road.
Unfortunately, I don't know enough about the two libraries to help much more than what little I have. I know the author (Mikal Hart) has his own web site... http://arduiniana.org/libraries/newsoftserial/
This is a timing issue. You should usually check nss.available() before attempting any reads. If you try to read when no characters are available, NewSoftSerial returns -1 (unlike SoftwareSerial, which just waits until a character arrives). I know this is what's happening here, because when you try to print -1 as a character you get that umlauted-y character :y.
Assuming the data flows in groups of 10 characters terminated by a CR/LF, I think I'd architect the loop function something like this:
char code[11];
int offset = 0;
if (rfid.available() > 0)
if (offset > 10)
Serial.println("Weird: buffer overflow");
offset = 0;
char c = rfid.read();
if (c == '\r' || c == '\n')
code[offset] = 0;
if (c == '\r')
Serial.print("Tag code is ");
offset = 0;
code[offset++] = c;
Also, you shouldn't call rfid.begin() every time through the loop. That reinitializes the port, potentially losing data. Just call it once in setup().
The code I was using I grabbed from another site, not something I wrote myself. I will change it to what you have suggested and post my results when I do.
