May I need to install Arduino from Pardus Repo? I use AppImage launcher.
(OS is from Turkey, a Debian 12 based Linux distro.)
GNOME with classic look btw:
..And installed the OUTDATED version....
Same thing....
Dikkat: 'Arduino AVR Boards' çekirdeğindeki platform.txt, miladı dolmuş compiler.path={runtime.tools.avr-gcc.path}/bin/ içeriyordu, otomatikman compiler.path=/usr/bin/'ye çevrildi. Bu çekirdeği güncellemeye bakın.
Çalışmanız programın 2416 bayt (7 %) saklama alanını kullandı. Maksimum 32256 bayt.
Global değişkenler belleğin 186 byte kadarını (9%) kullanıyor. Yerel değişkenler için 1862 byte yer kalıyor. En fazla 2048 byte kullanılabilir.
Taslak yüklenirken bir hata oluştu
avrdude: ser_open(): can't open device "/dev/ttyUSB0": Permission denied
Did you make yourself a member of the dialout group? Look it up. After doing so, log out and log in again.
I Downloaded the zip and thanks sterretje.
Same thing again and again..
Maybe Root?
I nearly solved the issue running as root. But... It's CLI.BoardsList":[],"port":{"address":"/dev/ttyUSB0","label":"/dev/ttyUSB0","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x7523"],["serialNumber",""],["vid","0x1a86"]],"hardwareId":""}},"error":""} 2024-09-18T16:47:40.998Z root INFO [4c749b02-22ba-41eb-af2a-0f09b24286c3] Sync of 23 plugins: 1363.0 ms [Finished 6.740 s after frontend start]
A UI scaling bug is captured:
Solved by using the web editor.
Proof:
(That ChatGPT was how to ewxecute .run files in Pardus)
HI @arduino_uno534 .
There is a known bug, which is tracked by the Arduino IDE developers here:
opened 05:34AM - 23 Jul 22 UTC
topic: code
type: imperfection
### Describe the problem
### To reproduce
open the ide
file -> open recent -> filename
let the file open while small, don't fullscreen while loading.
after just done loading or at the very end of loading, fullscreen.
the screen will be stuck until you close and reopen, unless you fullscreen while loading or adjust size and reset to fullscreen
### Expected behavior
follow the set window size and fully fill.
### Arduino IDE version
#### Original report
2.0.0-rc9
#### Last verified with
1ec0a8c
### Operating system
Windows
### Operating system version
10
### Additional context
if you fullscreen while loading or give more then 10ish seconds(for me), then it will work normally.
I couldn't find a bug report similar to this, sorry if it a duplicate!
I am an extremely novice programmer, and I love arduino! Its so much fun, I love learning everything. You guys are loved and amazing and are truly saving me from complete boredom while letting me explore and create. Thank you!
#### Additional reports
- https://forum.arduino.cc/t/ide-2-doesnt-resize-contents-reliably/1171736
- https://forum.arduino.cc/t/pardus-23-1-latest-arduino-ide-2-3-2-stable-latest-dev-ttyusb0-acsess-denied/1302886/7
### Issue checklist
- [X] I searched for previous reports in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the problem still occurs when using the latest [nightly build](https://github.com/arduino/arduino-ide#nightly-builds)
- [X] My report contains all necessary details
This bug produces the fault when the window is maximized while it is still loading. It should not occur if you restart the IDE or open a new window and don't change the window dimensions during the time while the window is loading.
I just captured a thing....
you have to add youself to uucb group by listing /dev/ttyUSBX (where X is the actual USB TTY number)
Mine was
hyprlanduser@archuser ~ ls -l /dev/ttyUSB0
crw-rw---- 1 root uucp 188, 0 Ara 11 17:36 /dev/ttyUSB0
now loaded the new code to it
