I tried your JSON string here: [C++] gcc 6.3.0 - Wandbox
// ArduinoJson - arduinojson.org
// Copyright Benoit Blanchon 2014-2018
// MIT License
// This example shows how to deserialize a JSON document with ArduinoJson.
#include <iostream>
#include "ArduinoJson.h"
int main()
 // Memory pool for JSON object tree.
 // Inside the brackets, 200 is the size of the pool in bytes,
 // If the JSON object is more complex, you need to increase that value.
 // See https://bblanchon.github.io/ArduinoJson/assistant/
 StaticJsonBuffer<3000> jsonBuffer;
 // StaticJsonBuffer allocates memory on the stack, it can be
 // replaced by DynamicJsonBuffer which allocates in the heap.
 // DynamicJsonBuffer jsonBuffer(200);
 // JSON input string.
 // It's better to use a char[] as shown here.
 // If you use a const char* or a String, ArduinoJson will
 // have to make a copy of the input in the JsonBuffer.
 char json[] =
   R"(
 "Body" : {
   "Data" : {
    "DAY_ENERGY" : {
      "Unit" : "Wh",
      "Value" : 60.799999999999997
    "DeviceStatus" : {
      "ErrorCode" : 0,
      "LEDColor" : 2,
      "LEDState" : 0,
      "MgmtTimerRemainingTime" : -1,
      "StateToReset" : false,
      "StatusCode" : 7
    "FAC" : {
      "Unit" : "Hz",
      "Value" : 50.079999999999998
    "IAC" : {
      "Unit" : "A",
      "Value" : 0.63
    "IDC" : {
      "Unit" : "A",
      "Value" : 0.48999999999999999
    "PAC" : {
      "Unit" : "W",
      "Value" : 156
    "TOTAL_ENERGY" : {
      "Unit" : "Wh",
      "Value" : 377835.03000000003
    "UAC" : {
      "Unit" : "V",
      "Value" : 248.40000000000001
    "UDC" : {
      "Unit" : "V",
      "Value" : 348.10000000000002
    "YEAR_ENERGY" : {
      "Unit" : "Wh",
      "Value" : 377835
 "Head" : {
   "RequestArguments" : {
    "DataCollection" : "CommonInverterData",
    "DeviceClass" : "Inverter",
    "DeviceId" : "1",
    "Scope" : "Device"
   "Status" : {
    "Code" : 0,
    "Reason" : "",
    "UserMessage" : ""
   "Timestamp" : "2018-07-13T07:26:31+10:00"
 // Root of the object tree.
 // It's a reference to the JsonObject, the actual bytes are inside the
 // JsonBuffer with all the other nodes of the object tree.
 // Memory is freed when jsonBuffer goes out of scope.
 JsonObject& root = jsonBuffer.parseObject(json);
 // Test if parsing succeeds.
 if (!root.success()) {
  std::cerr << "parseObject() failed" << std::endl;
  return 1;
 // Fetch values.
 // Most of the time, you can rely on the implicit casts.
 // In other case, you can do root["time"].as<long>();
 // const char* sensor = root["sensor"];
 // long time = root["time"];
 // double latitude = root["data"][0];
 // double longitude = root["data"][1];
 // Print values.
 std::cout << root["Body"]["Data"]["PAC"]["Value"] << std::endl;
 // std::cout << time << std::endl;
 // std::cout << latitude << std::endl;
 // std::cout << longitude << std::endl;
Â
 return 0;
This is how you de-nest to get your desired value:
