Hello, well, I'm now retired and want to keep my brain as active as possible and thought arduino programming and circuit building was a good way to go. Anyway, I've got some books and looked on the web and I've had a go at writing a program to use the Serial monitor as an input/output screen. All is working fine when I use integers (int) but as soon as I try to use a float the output isn't showing correctly.
Here's my code. (Hope i'm doing this right)
float number1;
float number2;
float Pass_number;
float answer;
float action;
Serial.println("Enter your first number");
while (Serial.available()==0){}
number1=Serial.parseFloat();Serial.print("The first number is ");Serial.println(number1);
while (Serial.available()!=0){Pass_number=Serial.parseFloat(); }
Serial.println("Enter your second number");
number2=Serial.parseFloat();Serial.print("The second number is ");Serial.println(number2);
Serial.println("Select what you want to do");
Serial.println(" 1 add, 2 subtract, 3 multiply, 4 divide");
action=Serial.parseFloat();
Serial.print("The answer is: ");
while (Serial.available()!=0){(Pass_number)=Serial.parseFloat(); }
if (action==1){answer = number1+number2;}
if (action==2){answer = number1-number2;}
if (action==3){answer = number1*number2;}
if (action==4){answer = number1/number2;}
Serial.print(answer, 2);
exit(0);//ends loop
This is what I get as an output.
I know the numbers after the decimal are being used because the output rounds up or down depending on whether its above or below .5
I suspect its in the 'pass_number' variable but I'm not certain how to solve it. Any ideas?
Thanks.
