Hello, I am working on a project that needs to use the serial channel. the data that is sent over is separated by commas so it looks like this: 200,0,0,1234,567,890,1000,2000,3000,4000,5000
(the numbers in there are made up )
I would like to take the second number and save that to a variable, how would I do that?
I saw something about strtok() but I do not know what that is.
here's my code based on the tutorial in the link that you've been sent above.
I use a slightly modified version of example 5 and while my effort isn't great it works for my application.
You may find it a starting point.
// https://forum.arduino.cc/index.php?topic=396450.0
// Serial Input Basics - updated
// Apr 25, 2016, 05:12 pm Last Edit: Apr 26, 2016, 11:27 am by Robin2
// Using Robins 'void RecvWithStartEndMarkers(') & 'void ParseData()'
// Example 5 - Receive with start- and end-markers combined with parsing
const byte NumChars = 32;
char ReceivedChars[NumChars];
char TempChars[NumChars]; // temporary array for use when parsing
// variables to hold the parsed data
char MessageFromPC[NumChars] = {0};
int IntegerFromPC1 = 0;
int IntegerFromPC2 = 0;
boolean NewData = false;
//myStuff for counting pulses
byte Pulse1=0; // output 1st pulses
byte LongPulse=0; // long or short pulse before last stream
byte Pulse2=0; // output 2nd pulses
byte Number;
byte I;
byte OutPort=8;
String myReturn = ""; // send string back to VB
byte PC=0;
digitalWrite(LED_BUILTIN, LOW);
pinMode(LED_BUILTIN, OUTPUT); // initialize ports, LEDs off
digitalWrite(OutPort, LOW);
pinMode(OutPort, OUTPUT);
RecvWithStartEndMarkers(); // test for serial input
if (NewData == true) // input received
strcpy(TempChars, ReceivedChars); // this temporary copy is necessary to protect the original data
// because strtok() used in parseData() replaces the commas with \0
ParseData(); // split the data
ReplyToInput(); // handshake / reply to input
NewData = false; // reset new data
void RecvWithStartEndMarkers()
static boolean RecvInProgress = false;
static byte ndx = 0; // index
char StartMarker = '<';
char EndMarker = '>';
char rc; // received data
while (Serial.available() > 0 && NewData == false)
rc = Serial.read(); // test for received data
if (RecvInProgress == true)
{ // found some!!
if (rc != EndMarker) // <> end marker
ReceivedChars[ndx] = rc; // 1st array position=data
ndx++; // next index
if (ndx >= NumChars) // if index>= number of chars
ndx = NumChars - 1; // index -1
else // end marker found
ReceivedChars[ndx] = '\0'; // terminate the string
ndx = 0; // reset index
NewData = true; // new data received flag
else if (rc == StartMarker) // signal start of new data
RecvInProgress = true;
void ParseData() // split the data into its parts
{ // Serial.println(MessageFromPC); ECHO data received
char * StrTokIndx; // this is used by strtok() as an index
StrTokIndx = strtok(TempChars,","); // get the first control word
//strcpy(MessageFromPC, StrTokIndx); // copy it to messageFromPC
PC = atoi(StrTokIndx);
StrTokIndx = strtok(NULL, ","); // this continues after 1st ',' in the previous call
IntegerFromPC1 = atoi(StrTokIndx); // convert this part to the first integer
StrTokIndx = strtok(NULL, ","); // this continues after 2nd ',' in the previous call
LongPulse = atoi(StrTokIndx); // convert this part to the first integer
IntegerFromPC2 = atof(StrTokIndx); // last integer
void ReplyToInput() // Handshaking with VB code.
if (PC==1) // test OK?
Pulse1=0;
LongPulse=0;
Pulse2=0;
Serial.print(String(PC) + ">"); // acknowledge
if (PC==2) // receive pulse strings
Pulse1=IntegerFromPC1;
Pulse2=IntegerFromPC2; // LongPulse = 0 or 1
myReturn=" - " + String(Pulse1) + " - " + String(LongPulse) + " - " + String(Pulse2) + ">";
Serial.print(PC + myReturn); // ask if UNO received correctly
if (PC==3) // VB Confirms OK to pulse out
PulsesOut(); // call pulse out using Pulse1 & pulse2
Serial.print(PC + myReturn); // tell VB that it's done
if (PC==4) // VB says to abort
Pulse1=0;
LongPulse=0;
Pulse2=0;
Serial.print(PC + myReturn); // confirm to VB
void PulsesOut()
Number=Pulse1;
SendPulses();
delay(180);
if (LongPulse==1)
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(OutPort, HIGH); // turn on OptoIsolator LED
delay(100); // wait for 100 mS
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
digitalWrite(OutPort, LOW); // turn off OptoIsolator LED
delay(50); // wait for 50mS
Number=Pulse2;
SendPulses();
void SendPulses()
for (I = 0; I < Number; I++)
delay(50); // wait for 50 mS
As I'm sending three numbers representing pulses to be sent into a jukebox I don't want to send incorrect numbers that could mess up the mechanism (parts are expensive). So I have 'messages' forwards and back between my VB front end and the Uno to confirm that the right numbers have been received. If it's OK the Uno pulses the output, through a opto isolator that pulses the -37 volts into the Jukebox.
If you can receive the string into a NULL-terminated char buffer (i.e. C-string) you can use something like this to parse out the values:
const char
szTest[] = "200,153954,0,1234,567,890,1000,2000,3000,4000,5000";
long
value;
char
*pszStr;
Serial.begin( 9600 );
//set the pointer to the start of the string
pszStr = szTest;
//get first number from list
value = atol( pszStr );
Serial.println( value );
//then loop through, looking for commas and the numbers that follow
while( 1 )
//find the next ','
pszStr = strchr( pszStr, ',' );
//if not found, we're done
if( pszStr == NULL )
//move the pointer one char past the ',' and convert
//what's there
value = atol( ++pszStr );
}//else
}//while
Serial.println( "\nAll done." );
}//setup
}//loop
I used atol() but atoi() could also work depending on the size of the values you're sending.
Thanks so much for both of your responses, I don't quite know how to use the jukebox code but I am away from home so I will take a look at it when I have access to the ide, as for the second response what would the output be
Let me assume that the data are coming over the serial port as ASCII characters with a preamble data byte (say: 0x03) and a postamble data byte (',' = comma = 0x2C). The possible solution to retrieve the decimal numbers from the received frame is (tested using MEGA as sender and NANO as receiver using soft serial ports):
byte n = SUART.available();
if (n != 0)
if (flag == false) //changed to == was = luberth
byte x = SUART.read();
if (x == 0x03)
flag = true; // received preamble code: 0x03
do
byte m = SUART.readBytesUntil(',', myData, 10); //receive/store every data item separtaed by comma
myData[m] = '\0'; //nul charcater
intData[counter] = atoi(myData); //retrieve original decimal number
Serial.println(intData[counter]);
counter++;
while (counter != 11);
flag = false;
counter = 0;
Serial.println("========================");
the recieve example does not work as expected
if (flag = false){
should be if (flag ==false){
spend some time figuring out why the first variable 200 whas not recieved it was always 0
my modifeid version of recieve
#include<SoftwareSerial.h>
SoftwareSerial SUART(10, 11); // SRX = DPin3, STX = DPin - 4
char myData[10];
byte counter = 0;
SUART.begin(9600);
if (SUART.available() != 0) {
if (SUART.read() == 0x03) { //recieved start flag
do {
byte m = SUART.readBytesUntil(',', myData, 10); //receive/store every data item seperated by comma
Serial.print(counter);
Serial.print(" => ");
if (counter==5){
int test=atoi(myData);
Serial.print(" intval = ");
Serial.print(test);
Serial.print(" ");
Serial.println(atoi(myData));
counter++;
counter = 0;
would like to do 2 way communicate ( mega 2560 touch lcd settings <==> esp8266 webpage settings )
for my thermostat arduino esp8266 (robotdyn mega wifi)
would this be possible with this example?
