Pass variable in IFTTT Webhook
Hello,
I’m looking for a way to push sensor data to a Google spreadsheet. Using IFTTT, I can get the webhook to trigger and create/update a spreadsheet, but I can’t figure out how to pass a variable into the webhook URL.
I can successfully trigger the webhook and create/update a spreadsheet using:
https://maker.ifttt.com/trigger//with/key/?value1=&value2=
I need the something to be my sensor variable temp that is updating to the IoT Cloud. Do I need to do something in the code or is it just a simple syntax in the URL?
hello @jld13
We have published this tutorial not long ago.
Please have a look and let us know if it helps :slight_smile:
I did get the setup in the tutorial working and that is a solution I can work with, thanks. I am still wondering if there is a way to pass a variable in the IFTTT webhook address though.
