passing a pointer to an array to the function
Hi everyone, I don't know if the title is right or no, because I don't really care about the terms in programming.
please see this code below :
#include <stdio.h>
int a=1;
int b=2;
int c[1];
int main()
    test(a, b, &c);
    printf("%d", c[0]);
    return 0;
void test(int A, int B, int *C[1])
  *C[0] = A + B;
it worked if I remove the array (only using integers). but it wont work if i use the Array. is there any way to make it work? I need to use this kind of code in my project. Sorry for my bad english and not using c arduino. I just want to test it.
many thanks :slight_smile:
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
You are very likely stumbling over operator precedence (the array dereference is higher priority).
But, you are also grossly over-complicating the situation.
Try this...
#include <stdio.h>
int a=1;
int b=2;
int c[1];
int main()
    test(a, b, c);
    printf("%d", c[0]);
    return 0;
void test(int A, int B, int C[1])
  C[0] = A + B;
