VLAs (variable length arrays) are not allowed. If you want to save an array to a struct, you have three main options: hard-code the size, specify the size as a template parameter, or use dynamic arrays (like std::vector).
If the array doesn't really need its own copy of the data, you can save just a pointer to an array that is stored somewhere else.
In this case, you also have to keep track of how many elements the array as.
Hence the two data members of the class: a pointer to the first element of the array, and a variable that keeps track of the length of the array:
private:
Sensors *sensors;
size_t length;
To initialize the class, you'll probably need a constructor. The constructor takes an array of N Sensors structs as a parameter. By using the "template" syntax, you tell the compiler to figure out the value of N for you. It will deduce this value from the size of the array you pass to the constructor.
You cannot pass an array by value, so you pass it by reference, indicated by the ampersand.
The array decays to a pointer, and is used to initialize the "sensors" member variable, and the number of elements N is used to initialize the "length" member variable.
public:
template <size_t N>
myclass(Sensors (&sensors_array)[N])
: sensors(sensors_array), length(N) {}
You can then use it inside of the class as follows:
[color=#00979c]struct[/color] [color=#000000]Sensors[/color] [color=#000000]{[/color]
[color=#00979c]uint8_t[/color] [color=#000000]pir[/color][color=#000000];[/color]
[color=#00979c]const[/color] [color=#00979c]char[/color] [color=#434f54]*[/color][color=#000000]loc[/color][color=#000000];[/color]
[color=#00979c]uint8_t[/color] [color=#000000]count[/color][color=#000000];[/color]
[color=#000000]}[/color][color=#000000];[/color]
[color=#000000]Sensors[/color] [color=#000000]pir[/color][color=#000000][[/color][color=#000000]][/color] [color=#434f54]=[/color] [color=#000000]{[/color]
[color=#000000]{[/color][color=#000000]6[/color][color=#434f54],[/color] [color=#005c5f]"sensor1"[/color][color=#434f54],[/color] [color=#000000]0[/color][color=#000000]}[/color][color=#434f54],[/color]
[color=#000000]{[/color][color=#000000]7[/color][color=#434f54],[/color] [color=#005c5f]"sensor2"[/color][color=#434f54],[/color] [color=#000000]0[/color][color=#000000]}[/color][color=#434f54],[/color]
[color=#000000]{[/color][color=#000000]8[/color][color=#434f54],[/color] [color=#005c5f]"sensor3"[/color][color=#434f54],[/color] [color=#000000]0[/color][color=#000000]}[/color]
[color=#00979c]class[/color] [color=#000000]myclass[/color][color=#000000]{[/color]
[color=#00979c]public[/color][color=#434f54]:[/color]
[color=#5e6d03]template[/color] [color=#434f54]<[/color][b][color=#d35400]size_t[/color][/b] [color=#000000]N[/color][color=#434f54]>[/color]
[color=#000000]myclass[/color][color=#000000]([/color][color=#000000]Sensors[/color] [color=#000000]([/color][color=#434f54]&[/color][color=#000000]sensors[/color][color=#000000])[/color][color=#000000][[/color][color=#000000]N[/color][color=#000000]][/color][color=#000000])[/color]
[color=#434f54]:[/color] [color=#000000]sensors[/color][color=#000000]([/color][color=#000000]sensors[/color][color=#000000])[/color][color=#434f54],[/color] [color=#d35400]length[/color][color=#000000]([/color][color=#000000]N[/color][color=#000000])[/color] [color=#000000]{[/color][color=#000000]}[/color]
[color=#00979c]void[/color] [color=#000000]printLocations[/color][color=#000000]([/color][color=#000000])[/color] [color=#00979c]const[/color] [color=#000000]{[/color]
[color=#5e6d03]for[/color] [color=#000000]([/color][b][color=#d35400]size_t[/color][/b] [color=#000000]i[/color] [color=#434f54]=[/color] [color=#000000]0[/color][color=#000000];[/color] [color=#000000]i[/color] [color=#434f54]<[/color] [color=#d35400]length[/color][color=#000000];[/color] [color=#434f54]++[/color][color=#000000]i[/color][color=#000000])[/color]
[b][color=#d35400]Serial[/color][/b][color=#434f54].[/color][color=#d35400]println[/color][color=#000000]([/color][color=#000000]sensors[/color][color=#000000][[/color][color=#000000]i[/color][color=#000000]][/color][color=#434f54].[/color][color=#000000]loc[/color][color=#000000])[/color][color=#000000];[/color]
[color=#00979c]private[/color][color=#434f54]:[/color]
[color=#000000]Sensors[/color] [color=#434f54]*[/color][color=#000000]sensors[/color][color=#000000];[/color]
[b][color=#d35400]size_t[/color][/b] [color=#d35400]length[/color][color=#000000];[/color]
[color=#000000]myclass[/color] [color=#000000]mySensors[/color] [color=#434f54]=[/color] [color=#000000]pir[/color][color=#000000];[/color]
[color=#00979c]void[/color] [color=#5e6d03]setup[/color][color=#000000]([/color][color=#000000])[/color] [color=#000000]{[/color]
[b][color=#d35400]Serial[/color][/b][color=#434f54].[/color][color=#d35400]begin[/color][color=#000000]([/color][color=#000000]115200[/color][color=#000000])[/color][color=#000000];[/color]
[color=#5e6d03]while[/color] [color=#000000]([/color][color=#434f54]![/color][b][color=#d35400]Serial[/color][/b][color=#000000])[/color][color=#000000];[/color]
[color=#000000]mySensors[/color][color=#434f54].[/color][color=#000000]printLocations[/color][color=#000000]([/color][color=#000000])[/color][color=#000000];[/color]
[color=#00979c]void[/color] [color=#5e6d03]loop[/color][color=#000000]([/color][color=#000000])[/color] [color=#000000]{[/color][color=#000000]}[/color]
Note how the "printLocations" function iterates over all elements of the array, using the pointer and the length.
