passing arrays by reference
I am new to Arduino, but come from a c++ back ground in microsofts VS. I am trying to pass an array into a function by reference, so that more than one function can operare on the same array. An example of what I'm trying to do:
void function(int &);
void setup(){
void loop(){
int counter[10];
funtion(&cunter[]);
for(int i=0;i<10;i++){
Serial.println(counter*);*
    void function(int &functionary[]){
  • for(int i=0;i<10;i++){*
    funtionary_=(i10);_
    _
    }_
    _
    }_
    _
    [/quote]*_
    At least in VS. this is how I would do it, however arduino returns an error stating 'declaration of 'ary' as array of references'. I'm not really sure what to do as a work around. So far I have concluded that the prototype is needed to fix a bug in arduino's auto-prototyping, and I have found several postings saying you can not return an array from a function. Anything will help.
    rigg
Arrays (which actually are pointers) pass by reference by default.
void function(int arr[]);
void setup(){
void loop(){
  int counter[10];
  funtion(cunter);
    Serial.println(counter[i]);
void function(int arr[]){
    arr[i]=(i*10);
:slight_smile:
I corrected the spelling, the syntax and removed the extraneous semicolons:
const int arraySize = 10;
void setup(){
void loop(){
  int counter[arraySize];
  function(counter);
  for(int i=0;i<arraySize;i++){
void function(int *functionary){
  for(int i=0; i < arraySize; ++i){
    functionary[i]=(i*10);
Thank you Groove i know there are some spelling mistakes in the code. This is just a quick example of my code to clearly demonstrate the problem i was having.
AlphaBata- do the arrays pass by reference because of arduino's auto-prototype thing. Because I tryed just running code very similer to how you have it writen and did not get anything to print to the serial line. Should I leave off the prototype?
Thank you for your quick responce.
rigg
Because arrays are pointers, you're passing arrays by 'reference'.
You'll have to excuse my code, I was too quick on the Post button. It should be OK now.
int x[]; and int *x; are basically the exact same.
C++ can never pass an array by value, because of the nature of how arrays work.
The variable is just a pointer to the address of the first entry.
int x[10];
x[2] is the same as *(x+2*sizeof(int))
03:00
/me got to sleep! See you :slight_smile:
In C(++), that isn't necessary. Arrays are always passed by reference.
No, you wouldn't. This...
  function(&counter[]);
...produces this...
error C2059: syntax error : ']'
...in Visual Studio 2008.
If you change to a prototype with a named argument this is the result...
void function(int &functionary[]);
error C2234: 'functionary' : arrays of references are illegal
Try dropping the reference...
void function(int functionary[]);
void setup(){
void loop(){
  int counter[10];
  function(counter);
void function(int functionary[]){
And we arrive back to reply #1 :slight_smile:
rigg: Have you solved the problem? Got some code that does what it's supposed to do?
Yes I beleive all the input has helped me solve my problem. It is going to be a few days before I can run the code to a microcontroller, however all the compiling errors have gone away. I will let every one know how it turns out in a couple of days.
Thank you to everybody how took time to help out, this is my first time asking for help in a forum and I am very thankfull with the quick responses.
rigg
AlphaBeta,
If you have an array of, for instance, intsint x[10];And an array reference likei = x[2];Then the pointer equivalent would bei = *(x + 2);There's no need to multiply by sizeof(int) -- C does this for you automatically.
Regards,
-Mike
AIf you have an array of, for instance, intsint x[10];And an array reference likei = x[2];Then the pointer equivalent would bei = *(x + 2);There's no need to multiply by sizeof(int) -- C does this for you automatically.
Ah. True that.
I just came from a C code dealing with void pointers.
