passing pointers to an array of bytes
i've been working in C# and have totally forgotten how to use pointers (to my chagrin ... and frustration)
i'm passing an array of pointers of bytes to a function and the receiving function does not know their values.
here's a code sample
String getString_WorkOut_Time(byte *bytTime[3])
  String strHours = String(*bytTime[0]);
  while (strHours.length() < 2)
    strHours = "0" + strHours;
  String strMinutes = String(*bytTime [1]);
  while (strMinutes.length() < 2)
    strMinutes = "0" + strMinutes;
  String strSeconds = String(*bytTime[2]);
  while (strSeconds.length() < 2)
    strSeconds = "0" + strSeconds;
  Serial.print(F("EditWorkOut_Time_Draw() "));
  Serial.print(strHours);
  Serial.print(F(":"));
  Serial.print(strMinutes);
  Serial.println(strSeconds);
  String strTime = strHours + ":" + strMinutes + ":" + strSeconds;
  return strTime;
bool EditWorkOut_Time()
  Serial.print(F("EditWorkOut_Time()-> before call:"));
  Serial.print(String(cWorkout.bytTimer_Hours));
  Serial.print(String(cWorkout.bytTimer_Minutes));
  Serial.println(String(cWorkout.bytTimer_Seconds));
  int intRange[] = {99, 60, 60};
  byte *bytTime[3] = { cWorkout.bytTimer_Hours, cWorkout.bytTimer_Minutes, cWorkout.bytTimer_Seconds};
  getString_WorkOut_Time(bytTime);
  Serial.print(F("EditWorkOut_Time()-> after call :"));
  return;
the results on my Serial port are
EditWorkOut_Time()-> before call:1:30:12
Hours before adding 0s000Hours after adding 0s
EditWorkOut_Time_Draw() 00:30:00
EditWorkOut_Time()-> after call :1:30:12
clearly the values of h:m:s being sent are 1:30:12
but the receiving function thinks they're 0:30:00 ?!?
the example I'm following is from C - Array of pointers
even though the example is not passing the pointers am i not using them the same way?
Live Demo
#include <stdio.h>
const int MAX = 3;
int main () {
   int  var[] = {10, 100, 200};
   int i, *ptr[MAX];
   for ( i = 0; i < MAX; i++) {
      ptr[i] = &var[i]; /* assign the address of integer. */
      printf("Value of var[%d] = %d\n", i, *ptr[i] );
   return 0;
It's hard to know, but in this snippet:
I don't see any reason to suppose that those three things are pointers, I'd expect that they're just bytes.
I assume cWorkout is a struct?
to set up aan array pointers use the & (address of) operator
byte *bytTime[3] = { &cWorkout.bytTimer_Hours, &cWorkout.bytTimer_Minutes, &cWorkout.bytTimer_Seconds};
You are setting your pointers to values, not addresses
This seems overly complicated. Why not pass the entire cWorkout object by reference and then manipulate the fields directly?
thank you for your reply.
I actually figured out the & addressing needed ...
but I'll take your idea about passing the entire class by reference as well.
happy Quararduino Day
