Hey There,
I Am Working On A Project Of A Wireless Morse Code Communication System (AM MODULATION)
And Get Stuck With Building A Basis Tranceiver Of An Arduino Uno, The Whole System Is Working Except 1 Part The Password Login System! i Need To Have The Password Setup so if The User Logon SuccesFully The PORTB Registers Goes On (For Transmitting), And If The User Type In The Wrong Password The Arduino Will Send A message Trough The Serial Monitor Like "::ERROR:: TRY ANOTHER PASSWORD ::ERROR::" So Only Authenticated Users Can Login Via Serial Monitor (and Probably Via my Own Website/CSHARP Application) in The Future, On This Way I Can Create Base Stations And Cover A Larger Planned Communication Network That Translates The Letters Into Morse Code Transmit It And Another Arduino Can Receive It Trough A Germanium Diode + Circuit That Put Electricity Out Of The Radio Signals Of The Diode And Feed It In An DigitalRead Pin So The Arduino Can Translate It Into Plain Text Again,
With That Said I Hope You Can help Me With The Password Protection Part Of It,
Tnx Already,
Best Regards Bradley Methorst (DragonicDefson)
PS (i Got The Actual Code From This Topic: Arduino + Wire = Morse Code AM Radio Beacon - Exhibition - Arduino Forum)
PS.2 (i Combined The 2 Posted Source Codes And Modified It With SOS Function An Default Call-sign-Function(1234))
And Here Is The Modified Upgraded Source Code:
long milliseconds_at_start = 0;
long milliseconds_at_the_end = 0;
const long length_of_transmitting_period = 8;
String password;
#define LENGTH_OF_TRANSMITTING_PERIOD_OF_A_DOT 64
const int length_of_a_dot = LENGTH_OF_TRANSMITTING_PERIOD_OF_A_DOT;
const int pause_after_transmitting_of_a_dot = LENGTH_OF_TRANSMITTING_PERIOD_OF_A_DOT;
const int length_of_a_dash = 3 * LENGTH_OF_TRANSMITTING_PERIOD_OF_A_DOT;
const int pause_after_transmitting_a_dash = LENGTH_OF_TRANSMITTING_PERIOD_OF_A_DOT;
const int pause_between_words = 6 * LENGTH_OF_TRANSMITTING_PERIOD_OF_A_DOT;
void DOT (void);
void DASH (void);
void PAUSE (void);
void start_transmitting ( int N_CYCLES );
void stop_transmitting ( int N_CYCLES );
#define ASM_INC( REGISTER ) asm volatile ( "inc %0" : "=r" ( REGISTER ) : "0" ( REGISTER ) )
char * Letters[] =
".-", "-...", "-.-.", "-..", ".", "..-.", "--.", "....", "..", // A-I
".---", "-.-", ".-..", "--", "-.", "---", ".--.", "--.-", ".-.", // J-R
"...", "-", "..-", "...-", ".--", "-..-", "-.--", "--.." // S-Z
char* Numbers[] = {"-----", ".----", "..---", "...--", "....-", ".....", "-....", "--...", "---..", "----."};
String sos[] =
"DOT();", "DOT();", "DOT();", "DASH();", "DASH();",
"DASH();","DOT();", "DOT();", "DOT();", "PAUSE();"
String default_call_sign[] =
"DASH();", "DASH();", "DASH();", "DASH();", "DASH();",
"DOT();", "DASH();", "DASH();", "DASH();", "DASH();",
"DOT();", "DOT();", "DASH();", "DASH();", "DASH();",
DDRB = 0xFF;
milliseconds_at_start = millis();
DOT();
milliseconds_at_the_end = millis();
Serial.print( milliseconds_at_the_end - milliseconds_at_start );
Serial.print( " " );
Serial.print( "Frequency Transmitting On: " );
Serial.print( ( length_of_a_dot + pause_after_transmitting_of_a_dot) * length_of_transmitting_period * 256 / (milliseconds_at_the_end - milliseconds_at_start) / 2 );
Serial.print( "kHz" );
Serial.println("Please Enter Your Password And Press Send");
PORTB = 0x00;
char Letter_Number;
String add_on_modules;
if (Serial.available())
if (password == "EARTH");
Serial.println("::SUCCES:: LOGGED ON EARTH STATION TRANSMITTER ::SUCCES::");
DDRB = 0xFF;
if (password != "EARTH")
Serial.println("::ERROR:: TRY ANOTHER PASSWORD PLEASE ::ERROR::");
Letter_Number = Serial.read();
add_on_modules = Serial.read();
if (add_on_modules == "send sos")
TRANSMIT_SOS();
if (add_on_modules == "send call sign")
DEFAULT_CALL_SIGN();
if (Letter_Number >= 'a' && Letter_Number <= 'z')
transmit_sequence(Letters[Letter_Number - 'a']);
else if (Letter_Number >= 'A' && Letter_Number <= 'Z')
transmit_sequence(Letters[Letter_Number - 'A']);
else if (Letter_Number >= '0' && Letter_Number <= '9')
transmit_sequence(Numbers[Letter_Number - '0']);
else if (Letter_Number == ' ')
PAUSE();
void transmit_sequence(char * sequence)
int i = 0;
while (sequence[i] != NULL)
transmit_choice_dot_or_dash (sequence[i]);
i++;
PAUSE();
void transmit_choice_dot_or_dash(char dot_or_dash)
if (dot_or_dash == '.')
DOT();
DASH();
void DOT (void)
for ( int i = 0; i < length_of_a_dot; i++ )
start_transmitting (length_of_transmitting_period);
for ( int i = 0; i < pause_after_transmitting_of_a_dot; i++)
stop_transmitting (length_of_transmitting_period);
void DASH (void)
for ( int i = 0; i < length_of_a_dash; i++ )
for( int i = 0; i < pause_after_transmitting_a_dash; i++ )
void TRANSMIT_SOS (void)
start_transmitting(sos);
void DEFAULT_CALL_SIGN (void)
start_transmitting(default_call_sign);
void PAUSE (void)
for(int i = 0; i < pause_between_words; i++)
unsigned int port_value;
for ( int i = 0; i < N_CYCLES; i++ )
port_value = 0;
do
PORTB = port_value;
ASM_INC(port_value);
while(port_value < 255);
PORTB = 0x00;
port_value = 0;
do
asm volatile ("NOP");
