Can't past anything into Arduino App Lab, Using latest windows 11. If I copy code from the web or notepad, or even Arduino IDE 2.3.6, It will not past into App Lab
Thanks for your report @printxii. The Arduino App Lab developers have been notified of the problem. I'll post an update here if I receive any news from them regarding a solution.
Until then, the workaround will be to use the keyboard shortcut to paste when using Arduino App Lab. The keyboard shortcut is Ctrl+V (or you can use the alternative shortcut Shift+Insert if you prefer). Once you get used to it, I think you will find the use of a keyboard shortcut for this operation that is so frequently performed when writing code is actually significantly more efficient than using the context menu.
